There's a number of things you can do to reduce the size of a video. Firstly, by using fewer colors, you can decrease the amount of information required for each pixel. You can also use smaller dimensions and then scale the image up. I also imagine that the compression that is being used works well for video because each frame differs only slightly from the previous.
I appreciate you trying to lay out the frame...work.
Puns aside, this seems like an awesome project and look forward to seeing it come to fruition.
Jcsq6 wrote:
What the program size? How are you doing this without importing like 100 massive sprites? I thought that was impossible even with compression...
lossy compression is much more efficient than lossless compression in this scenario.
Plus it often uses less then 8 bits per pixel.
Plus it uses (I'm assuming) semi-modern video codecs.
Wow this is a really cool project! Like the comment says above, how big is the file size, and how is it not taking up the entire calculators memory? (or is it?).
Do you plan on making some audio library as well to get my anime tunes pumping along with my anime videos to create the full weeb vibe?
All jokes aside, it would be really cool to see a full on video player with sound on the calc. Maybe this thread will help, https://www.cemetech.net/forum/viewtopic.php?t=13924. Not sure, maybe I'll try this myself. Anyways, awesome project!
It pretty much is taking all the calc's memory. Most of it. The one video I still have numbers on is the 4bpp adaptive colors one that's hidden behind a link on the prior page (and this one too!). It contains 2660 96x54px frames, uses a general purpose decompression scheme (ZX7) to unpack each segment, then renders each segment to the screen by a combination of copying an entire frame to the buffer and copying only changes between the current frame and the previous frame. The size of the video in question is about 2.2MB.
I don't plan on making any audio libraries. The sort of additional hardware you'd need would mean you might as well have a fully external audio player. Not that I hadn't entertained that idea a few times. Yay for super cheap MCUs
Made some changes that were indirectly prompted by a semi-related topic about a video player on the 83+SE. I'd decided to encode the video mentioned there pretty much to see if I could. As it turned out, the X2 scaling decoder choked on that video for reasons I probably wouldn't have ever figured out had I not heavily commented the source (thanks geekboy1011 for encouraging that).
The problem itself relates to the part of the decoder that fills in 8x8 blocks in the areas that has changed between frames and how a 4:3 video at a horizontal resolution of 144 approaches the limit of how many blocks I can have (252 of 256). Some of the math I did rounded that up to 256, and representing that as a bitfield, it should've calculated the offset between the table and the frame data to be 32. Instead, the upper bit got chopped off and I ended up with an offset of 0 which caused the decoder to interpret the stream as corrupted. The "solution" I came up with was to check to see if it rounded to 0 and manually set it to 32 if so.
I also made changes to the player's UI to improve readability by increasing vertical padding in the text elements. The source was also modified to make it far easier to make additional changes to the UI. Changes which may include adjusting spacing/padding further, adding additional lines, integrating titlebar changes, or rearranging entire sections.
So... screenies. Yeah. Let's do that.
Sonic CD Intro video, 144x108 2bpp gs (4 level grayscale), ~30fps. On-calc, uses slightly more than 1300 kbytes
CEVidium UI, now with two whole pixels of additional padding in the text elements!
NOTE: The music in the Sonic CD intro video is catchy. Is something wrong with me? Have I lost it? Did I ever have "it" to begin with? I can't stop listening to this.
EDIT Had a bit of time to rework the interface a bit, or more like I wanted something easy to do and I got real sick and tired of squinting at the screen and maybe I need a new pair of glasses with a new perscription but that's neither here nor now, so I modified it for improved readability and to add a frame count field. Source code is a little more readable and maintainable. Also forgot to mention that I've started putting binaries with the source in that place somewhere on github.
New and improved interface, now with extra wide label titles and something else
Looks awesome but I noticed most of the video conversion doesn't take advantage of being 2bpp with the majority being only 2 shades mostly?
CEVIDIUM doesn't work, everytime I try to open it the screen flickers and then it just goes back to the home screen.
Has anybody made a guide on how to set up cevidium?
Whenever I try to open a command prompt in the cevplay folder and enter "make gfx" it tells me make isn't a valid command.
I'm guessing I didn't set up ce programming toolchain correctly and that has something to do with it.
There is a file in CEVPLAY\bin called CEVIDIUM.8xp
When I send the file to my calculator(with the decoders and the image files) and try to run cevidium it shows filename: B playback time: 3:37 and frame count: 6520
When i try to play the video it says "Loading video... segments expected: 0326, found: 0000 Video data corrupted/incomplete." And it doesn't allow me to choose any other videos on my calculator
I'm guessing the problem is the cevidium file/not being able to use "make gfx" but I'm not sure how to fix that
If anyone has any ideas it would be much appreciated
Sorry if this isn't written very well, I'm kinda tired.
Hi I got cevidium but the video converter wasn't working so I found an already converted bad apple video but I still want to make my own video so could you maybe either update it or make a new converter?
I picked up this project again for the purpose of making what already exists more usable. The following has been done:
* Updated the readme to reflect the fact that this project is getting worked on again.
* Updated the readme to be somewhat more complete with its instructions.
* Updated the player to build on a more modern toolchain. Tested on 12.1
* Made a maybe-kinda-sorta fix on an old conversion script to clamp framerate at 30fps
* Cleaned up the github issue tracker. Some of the stuff there was truly ancient.
Stuff to do:
* Make an actual UI and adapt the converter to it. Also. Make it run on Python 3.10.
* Then make it do what is needed. Because really, the project's unusable as it is. Pls fix.
EDIT: July 8, 2025 (original post May 23, 2025) - Because this doesn't deserve a new post. Yet.
The GUI thing has now reached the status of "It works. Kinda."
Programming the whole thing was a wild ride, akin to snowboarding in an avalanche. If ya read the confessions.md file in the repo, you'll get a firm idea as to what I mean. For those unwilling to read the sprawling mess or click on the link, here's the situation:
A week burned trying to put together a UI in Python. Then Tim went "Hey, look at this shiny tool. It's an AI thing. Here's a paid API key. Here's more words to convince you. Words words words." and decided to, well. yanno. Use AI assistance to generate at the UI. Then it turned into an experiment on just how much of the project it can write for me. The answer turns out to be a surprising amount, but still not enough to cross the finish line. Even while hovering over the thing like a nanny. Then more than two months went by between this and another project. Then I fixed the last bug that was the result of failing to understand what the old code did, then fixed the documentation to finally outline every last quirk about the video format.
Would I do it again? Yeah. Should you feel a bit disappointed? Probably. Making the AI write the crunchy algorithmic bits for me felt a bit wrong, even though there's nothing unique going on there. But the UI? My burning hatred for TKinter precludes remorse of any kind, in any way, shape, or form. UI work with TKinter can go burn in the deepest pit. Webdev using nothing but notepad.exe makes more sense that that.
If you made it down here and want to try the UI, the instructions just tell you to "run it" or somesuch. There are bits of the UI that has simply doesn't work, but the Export button really does work. If it's not enabled, it means the video settings or the name is in an unsupported state. Make some changes and try again. Drag and drop worked on my machine the last time I tried it. No, I will not support downloading videos from the internet. The user is responsible for *that* game of whack-a-mole.
EDIT2 (July 21, 2025) - Because let's keep this thread buried for just a little longer
UI achieves legacy system parity* with toolkit2.py. Certain scaffolding added to maybe improve how the adaptive palette option actually selects palettes. Actually tested drag & drop outside its virtual environment. So what's the hold up now? I've gotten me a set of new-to-me python libraries that I want to play around with first. Not sure what else to say other than maybe the UI's now a little more usable? Yeah.
* I wanted to say "feature parity" but Google had different ideas when I thought to search that term to make sure it meant what I thought it meant. Maybe it still does and I misunderstood things even worse.
I downloaded this for the first time today and after a bit of trial and error, got a 9 second video onto my calc taking up a whole megabyte. Had to use wine since I'm on Mac, and had to solve some other issues in order to set it up but overall it worked perfectly in the end. Great work!
Page 2 of 2
