There's a number of things you can do to reduce the size of a video. Firstly, by using fewer colors, you can decrease the amount of information required for each pixel. You can also use smaller dimensions and then scale the image up. I also imagine that the compression that is being used works well for video because each frame differs only slightly from the previous.
I appreciate you trying to lay out the frame...work.
Puns aside, this seems like an awesome project and look forward to seeing it come to fruition.
Jcsq6 wrote:
What the program size? How are you doing this without importing like 100 massive sprites? I thought that was impossible even with compression...
lossy compression is much more efficient than lossless compression in this scenario.
Plus it often uses less then 8 bits per pixel.
Plus it uses (I'm assuming) semi-modern video codecs.
Wow this is a really cool project! Like the comment says above, how big is the file size, and how is it not taking up the entire calculators memory? (or is it?).
Do you plan on making some audio library as well to get my anime tunes pumping along with my anime videos to create the full weeb vibe?
All jokes aside, it would be really cool to see a full on video player with sound on the calc. Maybe this thread will help, https://www.cemetech.net/forum/viewtopic.php?t=13924. Not sure, maybe I'll try this myself. Anyways, awesome project!
It pretty much is taking all the calc's memory. Most of it. The one video I still have numbers on is the 4bpp adaptive colors one that's hidden behind a link on the prior page (and this one too!). It contains 2660 96x54px frames, uses a general purpose decompression scheme (ZX7) to unpack each segment, then renders each segment to the screen by a combination of copying an entire frame to the buffer and copying only changes between the current frame and the previous frame. The size of the video in question is about 2.2MB.
I don't plan on making any audio libraries. The sort of additional hardware you'd need would mean you might as well have a fully external audio player. Not that I hadn't entertained that idea a few times. Yay for super cheap MCUs
Made some changes that were indirectly prompted by a semi-related topic about a video player on the 83+SE. I'd decided to encode the video mentioned there pretty much to see if I could. As it turned out, the X2 scaling decoder choked on that video for reasons I probably wouldn't have ever figured out had I not heavily commented the source (thanks geekboy1011 for encouraging that).
The problem itself relates to the part of the decoder that fills in 8x8 blocks in the areas that has changed between frames and how a 4:3 video at a horizontal resolution of 144 approaches the limit of how many blocks I can have (252 of 256). Some of the math I did rounded that up to 256, and representing that as a bitfield, it should've calculated the offset between the table and the frame data to be 32. Instead, the upper bit got chopped off and I ended up with an offset of 0 which caused the decoder to interpret the stream as corrupted. The "solution" I came up with was to check to see if it rounded to 0 and manually set it to 32 if so.
I also made changes to the player's UI to improve readability by increasing vertical padding in the text elements. The source was also modified to make it far easier to make additional changes to the UI. Changes which may include adjusting spacing/padding further, adding additional lines, integrating titlebar changes, or rearranging entire sections.
So... screenies. Yeah. Let's do that.
Sonic CD Intro video, 144x108 2bpp gs (4 level grayscale), ~30fps. On-calc, uses slightly more than 1300 kbytes
CEVidium UI, now with two whole pixels of additional padding in the text elements!
NOTE: The music in the Sonic CD intro video is catchy. Is something wrong with me? Have I lost it? Did I ever have "it" to begin with? I can't stop listening to this.
EDIT Had a bit of time to rework the interface a bit, or more like I wanted something easy to do and I got real sick and tired of squinting at the screen and maybe I need a new pair of glasses with a new perscription but that's neither here nor now, so I modified it for improved readability and to add a frame count field. Source code is a little more readable and maintainable. Also forgot to mention that I've started putting binaries with the source in that place somewhere on github.
New and improved interface, now with extra wide label titles and something else
Looks awesome but I noticed most of the video conversion doesn't take advantage of being 2bpp with the majority being only 2 shades mostly?
CEVIDIUM doesn't work, everytime I try to open it the screen flickers and then it just goes back to the home screen.
Has anybody made a guide on how to set up cevidium?
Whenever I try to open a command prompt in the cevplay folder and enter "make gfx" it tells me make isn't a valid command.
I'm guessing I didn't set up ce programming toolchain correctly and that has something to do with it.
There is a file in CEVPLAY\bin called CEVIDIUM.8xp
When I send the file to my calculator(with the decoders and the image files) and try to run cevidium it shows filename: B playback time: 3:37 and frame count: 6520
When i try to play the video it says "Loading video... segments expected: 0326, found: 0000 Video data corrupted/incomplete." And it doesn't allow me to choose any other videos on my calculator
I'm guessing the problem is the cevidium file/not being able to use "make gfx" but I'm not sure how to fix that
If anyone has any ideas it would be much appreciated
Sorry if this isn't written very well, I'm kinda tired.
Hi I got cevidium but the video converter wasn't working so I found an already converted bad apple video but I still want to make my own video so could you maybe either update it or make a new converter?
Page 2 of 2
