- TI-84 Plus CE Programs
- TI-84 Plus CE Assembly Graphics Programs
An editor for sprites, icons, fonts, tilesets and tilemaps. Including useful tools for programming in ICE.
TOOLS: color picker, key value, RGB for palettes, character table, brightness changer, zoom, tabs, quit and restart without re-import, export directly to/from source code, ...
NEW: better font editor, RLET sprites, tilemap editor, decimal to hex to bin, a few improvements
Bugs and suggestions:
https://www.cemetech.net/forum/viewtopic.php?p=291644
Designer v4.7/DESIGNER (white-gray).8xp | 26.0 KB |
Designer v4.7/DESIGNER (white-black).8xp | 26.0 KB |
Designer v4.7/ReadMe.txt | 1.6 KB |
Designer v4.7/clibs (v9.0).8xg | 17.4 KB |
Designer v4.7/DESIGNER (gray-white).8xp | 26.0 KB |
Designer v4.7/Source/DSGN4TAB.8xp | 1.7 KB |
Designer v4.7/Source/DSGN4SVE.8xp | 1.6 KB |
Designer v4.7/Source/DSGN4SRC.8xp | 5.5 KB |
Designer v4.7/Source/DSGN4MNU.8xp | 4.4 KB |
Designer v4.7/Source/DSGN4INF.8xp | 1.2 KB |
Designer v4.7/Source/DSGN4IMP.8xp | 2.8 KB |
Designer v4.7/Source/DSGN4GET.8xp | 3.7 KB |
Designer v4.7/Source/DSGN4DRW.8xp | 1.4 KB |
- 54.5 KB
- http://ceme.tech/DL2128
- Frederik
- 8.3/10 (4 votes)
- ↳ this version
- 570
- ↳ this version
- 2340
Designer V5 has got to be the best icon creator I have ever used. Unlike most, that are slow, broken, unintuitive, or require other apps (like Celtic) to run, Designer clearly overdelivers. The ability to create sprites, along with icons, tile maps, fonts, and RLET's is not found in any other program.
I suppose this is a good program, but I don't actually know, because it uses outdated clibs.
There's a download included in the zip but personally I do not want to use those because it will affect other programs I have on my calculator.
The actual program works, so does the color pickers and other things within the program, but the actual designer for icons and sprites does not function.
Is there a way to export the sprite from the calc to a computer as a png file?
This is a very good program, however you should update it to use with the latest clibs, I downgraded mine to use the program, and launched a different program and had to wipe my calculator.
This program is awesome, and it has a ton of nice features and a great UI. I absolutely love it! Great program, great job, and I recommend this for all your spriting needs.
This is definitely the best on-calc sprite editor/creator for the TI 84 Plus CE and TI 83 Premium CE. It even allows you to create and/or edit and save the icons of pre-existing programs! You can save sprite data into whatever type of file you want, and the sprite editor automatically saves your work if you exit the program before saving! Also, the response is very fast and smooth!
- Designer v5 (published 8 months, 3 weeks ago; 2024-09-19 11:41 UTC)
- Designer v4.7 (published 3 years, 7 months ago; 2021-11-05 16:51 UTC)
- Designer v4.6 (published 4 years ago; 2021-06-11 13:50 UTC)
- Designer v4.5 (published 4 years, 2 months ago; 2021-04-12 09:32 UTC)
- Designer v4.4 (published 4 years, 2 months ago; 2021-03-20 13:38 UTC)
- Designer v4.3 (published 4 years, 3 months ago; 2021-03-09 11:28 UTC)
