Here is a very slow plotting of Tupper's formula, from the original 543 digit value of K.
This is a slow program and to generate the screenshot, I ran the emulator at max speed for 3 hours. It might take a day or 2 to do on a real calculator.
https://www.dropbox.com/s/9bl9widcglitxjc/TupTI84CSE.rar?dl=1
Feel free to make it faster 🙂
If you want to share the program with Cemetechians more easily, feel free to upload to the Downloads archive (you'll need to put it in a zip with a README).
I have improved this program that plots Tuppers Formula on the TI-84 CSE screen.
In this latest version, I implement all of the divides by 2 in assembly directly on the string in memory, the result is a massively faster version of the same thing.
The previous version took 3 hours at maximum Emulator speed, which would have taken over a day on a real calculator.
Now this plots in under 6 minutes real time! Less than 4 minutes if you remove the text printing in TX2.8xp. 37 seconds at Max Emulator speed. Assembly is fast. Thanks for all of the help in the chat room.
https://www.dropbox.com/s/so6zrz3n72qp110/Tupp3nd.rar?dl=1
