Hello friends! I am very new to coding, but recently managed to help my friend make a well-rounded math program for ALG1-ALG2. Originally we coded this ON the TI-84PCE (very time consuming) and it took a span of about 20 Study Halls. Anyhow, I tried to give this to my friend who uses a TI-84 plus, but it gave an error in the Factor sub-program. The error is found on the line that says
:Output(Ans,1, "COEF. OF X^
Can someone please tell me how to fix this or what we did wrong? I figured since it's TI-Basic it should be compatible with all models. Thanks in advance.
(PRGM BELOW)
ClrHome
Output(3,6,"THE MATH PROGRAM
Output(5,7,"[e]CHELON CODING
Output(7,8,"Prgmr: Roy B.
Pause
Lbl N
ClrHome
Menu("CHOOSE:","QUADRATIC",1,"DISTANCE",2,"MIDPOINT",3,"SLOPE",4,"TRI DISTANCE",5,"PYTHAGOREAN",6,"FACTOR",7
Lbl 1
Disp "AX^^2+BX+C=0
Prompt A,B,C
B^^2-4AC->D
FnOff :PlotsOff
AxesOff:GridOff
ClrDraw
Text(30,1,"[x1],[x2]=-------------
Text(20,56-6(B>0),~B,"+-sqrt(",D,")
2int(log(abs(2A
Text(40,max(56,84-Ans-6(A<0)),2A
Text(90,1,"VERTEX:",~B/(2A),",",C-B^^2/(4A
Pause
AxesOn:FnOn
If D>0
sqrt(D->D
If D<0
[i]sqrt(~D->D
If imag(D) or fPart(abs(D
Then
   Disp "-NOT FACTORABLE-
   Else
   gcd(abs(A),gcd(abs(B),abs(C->E
   A/E->A
   B/E->B
   C/E->C
   D/E->D
   D-B->M
   gcd(abs(2A),abs(M->F
   M/F->M
   2A/F->N
   ~B-D->O
   gcd(abs(2A),abs(O->F
   O/F->O
   2A/F->P
   If A<0
   Then
      ~M->M
      ~N->N
      ~O->O
      ~P->P
   Output(5,1,"FACTORS:
   6->K
   Output(K,1,"~
   1+(A<0
   Output(K,Ans,E
   Ans+int(log(E)+(E!=1
   Repeat K>7
      Output(K,Ans,"(
      Output(K,Ans+1,N
      Ans+2+int(log(N)+(N!=1
      Output(K,Ans-1,"X
      If M
      Then
         Output(K,Ans,"-
         If M<0
         Output(K,Ans,"+
         Output(K,Ans+1,abs(M
         Ans+int(2+log(abs(M
      If Ans<=16
      Output(K,Ans,")
      K+1->K
      O->M
      P->N
      1
   Pause
Disp "[x1],[x2]=    ",(D-B)/(2A>Frac
Pause (~B-D)/(2A>Frac
Goto 8
Lbl 2
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
(C-A)^^2+(D-B)^^2->E
For(F,int(sqrt(E)),2,~1)
   If fPart(E/F^^2
If F
E/F^^2->E
ClrHome
Disp "DISTANCE:
1->K
Output(2,K,F
(F>1)+K+int(log(F->K
Output(2,K,"sqrt(
Output(2,K+1,E
Output(3,1,Fsqrt(E
Pause
Goto 8
Lbl 3
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
ClrHome
Disp "X=",(A+C)/2,"Y=",(B+D)/2
Pause
Goto 8
Lbl 4
0->I:rand->C
Menu("CHOOSE:","TWO POINTS",A,"POINT+SLOPE",B,"EQUATION",C
Lbl A
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
If A=C and B=D
Then
   Disp "NO LINE
   Stop
If C-A
Then
   (D-B)/(C-A->S
   D-CS->V
   If S
   ~V/S->I
Goto D
Lbl B
Input "X?",A
Input "Y?",B
Input "SLOPE?",S
B-AS->V
If S
~V/S->I
Goto D
Lbl C
Input "SLOPE?",S
Input "Y-INTERCEPT?",V
If S
~V/S->I
Lbl D
GridOff:AxesOff:FnOff :PlotsOff :ClrDraw
Text(0,0,"EQUATION:
If C-A
Then
   If S and V>=0
   Text(14,1,"Y=",S,"X+",V
   If S and V<0
   Text(14,1,"Y=",S,"X-",abs(V
   If not(S
   Text(14,1,"Y=",V
   Text(30,1,"SLOPE=",S
   Text(44,1,"Y-INTERCEPT=",V
   If S or not(V
   Text(58,1,"X-INTERCEPT=",I
   If V and not(S
   Text(58,1,"X-INTERCEPT=NONE
   Else
   Text(14,1,"X=",C
   Text(30,1,"SLOPE=UNDEFINED
   If C
   Text(44,1,"Y-INTERCEPT=NONE
   If not(C
   Text(44,1,"Y-INTERCEPT=0
   Text(58,1,"X-INTERCEPT=",C
Pause
AxesOn:FnOn
Goto 8
Lbl 5
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
Input "X3?",E
Input "Y3?",F
(A-C)^^2+(B-D)^^2->G
(C-E)^^2+(D-F)^^2->H
(A-E)^^2+(B-F)^^2->I
For(F,int(sqrt(G)),2,~1)
   If fPart(G/F^^2
If F
G/F^^2->G
ClrHome
Disp "DIST.1:
1->K
Output(2,1,F
Output(2,K,"sqrt(
Output(2,K+1,G
Output(3,1,Fsqrt(G
Pause
For(F,int(sqrt(H)),2,~1)
   If fPart(H/F^^2
If F
H/F^^2->H
ClrHome
Disp "DIST.2:
1->K
Output(2,1,F
Output(2,K,"sqrt(
Output(2,K+1,H
Output(3,1,Fsqrt(H
Pause
For(F,int(sqrt(I)),2,~1)
   If fPart(I/F^^2
If F
I/F^^2->I
ClrHome
Disp "DIST.3:
1->K
Output(2,1,F
Output(2,K,"sqrt(
Output(2,K+1,I
Output(3,1,Fsqrt(I
Pause
Goto 8
Lbl 6
rand->X
Prompt A,B,C
C->D
If C!=X
max(A,max(B,C->C
If C!=D and A=C
D->A
If C!=D and B=C
D->B
0->D
If A=X
C^^2-B^^2->D
If B=X
C^^2-A^^2->D
If C=X
A^^2+B^^2->D
If A=X and B=X
C^^2/2->D
If C=X and (B=X or A=X
0->D
If D>0
Then
   Disp sqrt(D
   fPart(sqrt(D
   If Ans=round(Ans,3
   Goto 8
   Disp "Or","
   1->E
   fPart(D
   If |E~4>=min(Ans,1-Ans
   Then
      round(D,0->D
      For(F,int(sqrt(D/2)),2,~1
         If not(fPart(D/F^^2
         Then
            D/F^^2->D
            F->E
            2->F
   1->G
   Output(6,G,E
   G+(E>1)+int(log(E->G
   Output(6,G,"sqrt(
   Output(6,G+1,D
   Else
   If A^^2+B^^2=C^^2
   Then
      Disp "Right triangle
      Else
      Disp "Not a right","triangle
Goto 8
Lbl 7
DelVar L1DelVar L2DelVar L3DelVar L4DelVar L5ClrHome
ClrDraw:AxesOff
FnOff :PlotsOff
Input "DEGREE?",D
0->dim(L1
For(I,D,0,~1
   2(D-I+1
   If Ans>10
   10
   Output(Ans,1,"COEF. OF X^
   Output(Ans,12,I
   Disp "
   Input C
   C->L1(D-I+1
D+1->D
0->C
0->R
0->Z
0->theta
While not(L1(D
   D-1->D
   Z+1->Z
If 0>L1(1
Then
   Text(R,C,"~
   C+6->C
   ~L1->L1
L1(1->A
For(I,2,dim(L1
   gcd(A,abs(L1(I->A
If A
L1/A->L1
If A>1
Then
   Text(R,C,A
   C+8+8int(log(A->C
If Z
Then
   Text(R,C,"X
   C+8->C
   If Z=2
   Then
      Text(R,C,"^^2
      C+8->C
   If Z>2
   Then
      Text(R,C,"^
      Text(R,C+8,Z
      C+16+8int(log(Z->C
If D=1
Goto 12
Lbl 9
1->Q
1->I
For(J,1,2
   abs(L1(I->A
   {1->L2
   2->B
   While 2<Anot(fPart(A/2
      Lbl 10
      A/B->A
      If fPart(max(L2)/B
      L2->L4
      augment(L4,BL2->L2
   For(G,B+(B=2),sqrt(A),2)
      If fPart(A/G
   G->B
   A->G
   If B^^2<=A
   Goto 10
   augment(L2,AL2->L2
   If I=1
   L2->L3
   D->I
0->dim(L4
For(I,1,dim(L2
   For(J,1,dim(L3
      L2(I)/L3(J->L4(1+dim(L4
0->dim(L2
0->dim(L3
SortA(L4
0->dim(L5
L4(1->L5(1
For(I,2,dim(L4
   If L4(I-1)!=L4(I
   L4(I->L5(1+dim(L5
0->dim(L4
dim(L5->B
For(I,max(1,int(B/2)),B
   L5(I->L4(1+dim(L4
   B-I-1->J
   If J>0 and J!=I
   L5(J->L4(1+dim(L4
0->dim(L5
1->A
Lbl 11
1->B
Repeat B=2
   D->E
   L1(1->L2(1
   For(I,2,D
      L1(I)+L2(I-1)L4(A->L2(I
   If not(L2(D
   Then
      abs(L4(A->Y
      1->N
      While Y>|E~7N
         N/Y->N
         fPart(Y^^-1->Y
      If 1>fPart(N
      iPart(N->N
      round(N,0->N
      round(NL4(A),0->F
      Text(R,C,"(
      C+6->C
      If N>1
      Then
         Text(R,C,N
         C+8+8int(log(N->C
      Text(R,C,"X
      If theta
      Text(R,C,"X^^2
      If theta
      C+8->C
      C+8->C
      Text(R,C,"-
      If F<0
      Text(R,C,"+
      C+8->C
      If C>=220
      DelVar CR+14->R
      Text(R,C,abs(F
      C+8+8int(log(abs(F->C
      Text(R,C,")
      C+6->C
      D-1->D
      D->dim(L2
      L2/N->L1
      NQ->Q
   If D=E or D=1
   2->B
If A<=dim(L4
Then
   If 0>L4(A
   Then
      A+1->A
      Else
      ~L4(A->L4(A
If D>1 and Q<10 and A<=dim(L4
Goto 11
If D>1 and A<=dim(L4
Goto 9
theta+1->theta
If D>1 and theta=1
Then
   For(I,D,2,~1
      If L1(I) and fPart((I-1)/2
      3->theta
   If theta=1
   Then
      {L1(1->L2
      For(I,3,D,2
         L1(I->L2(1+dim(L2
      L2->L1
      0->dim(L2
      dim(L1->D
If D>1 and theta=1
Goto 9
If D>1 and theta=2
Then
   {L1(1),0->L2
   For(I,2,D
      augment(L2,augment({L1(I)},{0->L2
   dim(L2)-1->dim(L2
   L2->L1
   0->dim(L2
   dim(L1->D
If D>1
Then
   Text(R,C,"(
   C+6->C
   For(I,1,dim(L1
      D-I->J
      L1(I->A
      If A
      Then
         If A<0 and I=1
         Then
            Text(R,C,"~
            C+8->C
         If I>1
         Then
            Text(R,C,"-
            If 0<A
            Text(R,C,"+
            C+8->C
         If C>=200
         DelVar CR+14->R
         If 1<abs(A) or not(J
         Then
            Text(R,C,abs(A
            C+8+8int(log(abs(A->C
         If J
         Then
            Text(R,C,"X
            C+8->C
         If J=2
         Then
            Text(R,C,"^^2
            C+8->C
         If J>2
         Then
            Text(R,C,"^
            Text(R,C+8,J
            C+16+8int(log(J->C
   Text(R,C,")
Lbl 12
Text(120,100,"READY
Pause
AxesOn:FnOn
SetUpEditor
Lbl 8
Output(1,1,"
Firstly, you should enclose your code in
[code]code brackets[/code]
. Secondly, my guess would be that your trying to display characters off the screen, since the CE screen is larger than the normal TI-84+ screen.
I'll try that rn, thanks.
That didn't fix it but it did make it a bit faster
It is indeed what Ivoah said, the screen of the TI-84+ is smaller. Where the CE have 10 lines on the homescreen, the 84+ only 8 lines. So your code
2(D-I+1
If Ans>10
10
Output(Ans,2,"bla
will return an error if Ans>8, because there are only 8 lines on the homescreen. You could easily change the variables to 8, so it would be
2(D-I+1
If Ans>8
8
Output(...
or even better:
min(8,2(D-I+1
I hope this helps! Very Happy
Okay, this line will cause an error because of the Ans part, in your code, I see that at that point, Ans=10, however, as stated by Ivoah, on the monochrome 84, you can only display 8 rows of characters with the output command. I haven't read through your whole code (which really should be in code brackets by the way), but if it is possible to make that text show up at row 8 or lower, then you should do that, which should solve the problem. In fact, you should go over it and make sure that you don't output anything over row 8.
Okay thanks I'm so new to coding! But I really enjoy it! I've just been learning by watching my friend and taking apart and putting programs back together. Thanks a million!!! Razz
2(D-I+1
If Ans>10
10
Output(Ans,2,"bla
2(D-I+1
If Ans>8
8
Output(...
or even better:
min(8,2(D-I+1
You helped me figure that out and I am very thankful! But now I am receiving an error on the 327th line
Text(R,C,"X
I'm sorry to burden you with such simple questions but I would greatly appreciate some more help Confused Smile
Also the graph screen is much smaller. Instead of 264*150, it is now 95*63 pixels, so you need to adjust that coördinates as well Smile
how would I go about doing that?
