- Basic Program Compatibility TI-84PCE > TI-84P
- 18 Jan 2016 03:59:46 pm
- Last edited by Andathral on 18 Jan 2016 04:05:25 pm; edited 1 time in total
Hello friends! I am very new to coding, but recently managed to help my friend make a well-rounded math program for ALG1-ALG2. Originally we coded this ON the TI-84PCE (very time consuming) and it took a span of about 20 Study Halls. Anyhow, I tried to give this to my friend who uses a TI-84 plus, but it gave an error in the Factor sub-program. The error is found on the line that says
:Output(Ans,1, "COEF. OF X^
Can someone please tell me how to fix this or what we did wrong? I figured since it's TI-Basic it should be compatible with all models. Thanks in advance.
(PRGM BELOW)
(PRGM BELOW)
ClrHome
Output(3,6,"THE MATH PROGRAM
Output(5,7,"[e]CHELON CODING
Output(7,8,"Prgmr: Roy B.
Pause
Lbl N
ClrHome
Menu("CHOOSE:","QUADRATIC",1,"DISTANCE",2,"MIDPOINT",3,"SLOPE",4,"TRI DISTANCE",5,"PYTHAGOREAN",6,"FACTOR",7
Lbl 1
Disp "AX^^2+BX+C=0
Prompt A,B,C
B^^2-4AC->D
FnOff :PlotsOff
AxesOff:GridOff
ClrDraw
Text(30,1,"[x1],[x2]=-------------
Text(20,56-6(B>0),~B,"+-sqrt(",D,")
2int(log(abs(2A
Text(40,max(56,84-Ans-6(A<0)),2A
Text(90,1,"VERTEX:",~B/(2A),",",C-B^^2/(4A
Pause
AxesOn:FnOn
If D>0
sqrt(D->D
If D<0
[i]sqrt(~D->D
If imag(D) or fPart(abs(D
Then
Disp "-NOT FACTORABLE-
Else
gcd(abs(A),gcd(abs(B),abs(C->E
A/E->A
B/E->B
C/E->C
D/E->D
D-B->M
gcd(abs(2A),abs(M->F
M/F->M
2A/F->N
~B-D->O
gcd(abs(2A),abs(O->F
O/F->O
2A/F->P
If A<0
Then
~M->M
~N->N
~O->O
~P->P
Output(5,1,"FACTORS:
6->K
Output(K,1,"~
1+(A<0
Output(K,Ans,E
Ans+int(log(E)+(E!=1
Repeat K>7
Output(K,Ans,"(
Output(K,Ans+1,N
Ans+2+int(log(N)+(N!=1
Output(K,Ans-1,"X
If M
Then
Output(K,Ans,"-
If M<0
Output(K,Ans,"+
Output(K,Ans+1,abs(M
Ans+int(2+log(abs(M
If Ans<=16
Output(K,Ans,")
K+1->K
O->M
P->N
1
Pause
Disp "[x1],[x2]= ",(D-B)/(2A>Frac
Pause (~B-D)/(2A>Frac
Goto 8
Lbl 2
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
(C-A)^^2+(D-B)^^2->E
For(F,int(sqrt(E)),2,~1)
If fPart(E/F^^2
If F
E/F^^2->E
ClrHome
Disp "DISTANCE:
1->K
Output(2,K,F
(F>1)+K+int(log(F->K
Output(2,K,"sqrt(
Output(2,K+1,E
Output(3,1,Fsqrt(E
Pause
Goto 8
Lbl 3
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
ClrHome
Disp "X=",(A+C)/2,"Y=",(B+D)/2
Pause
Goto 8
Lbl 4
0->I:rand->C
Menu("CHOOSE:","TWO POINTS",A,"POINT+SLOPE",B,"EQUATION",C
Lbl A
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
If A=C and B=D
Then
Disp "NO LINE
Stop
If C-A
Then
(D-B)/(C-A->S
D-CS->V
If S
~V/S->I
Goto D
Lbl B
Input "X?",A
Input "Y?",B
Input "SLOPE?",S
B-AS->V
If S
~V/S->I
Goto D
Lbl C
Input "SLOPE?",S
Input "Y-INTERCEPT?",V
If S
~V/S->I
Lbl D
GridOff:AxesOff:FnOff :PlotsOff :ClrDraw
Text(0,0,"EQUATION:
If C-A
Then
If S and V>=0
Text(14,1,"Y=",S,"X+",V
If S and V<0
Text(14,1,"Y=",S,"X-",abs(V
If not(S
Text(14,1,"Y=",V
Text(30,1,"SLOPE=",S
Text(44,1,"Y-INTERCEPT=",V
If S or not(V
Text(58,1,"X-INTERCEPT=",I
If V and not(S
Text(58,1,"X-INTERCEPT=NONE
Else
Text(14,1,"X=",C
Text(30,1,"SLOPE=UNDEFINED
If C
Text(44,1,"Y-INTERCEPT=NONE
If not(C
Text(44,1,"Y-INTERCEPT=0
Text(58,1,"X-INTERCEPT=",C
Pause
AxesOn:FnOn
Goto 8
Lbl 5
Input "X1?",A
Input "Y1?",B
Input "X2?",C
Input "Y2?",D
Input "X3?",E
Input "Y3?",F
(A-C)^^2+(B-D)^^2->G
(C-E)^^2+(D-F)^^2->H
(A-E)^^2+(B-F)^^2->I
For(F,int(sqrt(G)),2,~1)
If fPart(G/F^^2
If F
G/F^^2->G
ClrHome
Disp "DIST.1:
1->K
Output(2,1,F
Output(2,K,"sqrt(
Output(2,K+1,G
Output(3,1,Fsqrt(G
Pause
For(F,int(sqrt(H)),2,~1)
If fPart(H/F^^2
If F
H/F^^2->H
ClrHome
Disp "DIST.2:
1->K
Output(2,1,F
Output(2,K,"sqrt(
Output(2,K+1,H
Output(3,1,Fsqrt(H
Pause
For(F,int(sqrt(I)),2,~1)
If fPart(I/F^^2
If F
I/F^^2->I
ClrHome
Disp "DIST.3:
1->K
Output(2,1,F
Output(2,K,"sqrt(
Output(2,K+1,I
Output(3,1,Fsqrt(I
Pause
Goto 8
Lbl 6
rand->X
Prompt A,B,C
C->D
If C!=X
max(A,max(B,C->C
If C!=D and A=C
D->A
If C!=D and B=C
D->B
0->D
If A=X
C^^2-B^^2->D
If B=X
C^^2-A^^2->D
If C=X
A^^2+B^^2->D
If A=X and B=X
C^^2/2->D
If C=X and (B=X or A=X
0->D
If D>0
Then
Disp sqrt(D
fPart(sqrt(D
If Ans=round(Ans,3
Goto 8
Disp "Or","
1->E
fPart(D
If |E~4>=min(Ans,1-Ans
Then
round(D,0->D
For(F,int(sqrt(D/2)),2,~1
If not(fPart(D/F^^2
Then
D/F^^2->D
F->E
2->F
1->G
Output(6,G,E
G+(E>1)+int(log(E->G
Output(6,G,"sqrt(
Output(6,G+1,D
Else
If A^^2+B^^2=C^^2
Then
Disp "Right triangle
Else
Disp "Not a right","triangle
Goto 8
Lbl 7
DelVar L1DelVar L2DelVar L3DelVar L4DelVar L5ClrHome
ClrDraw:AxesOff
FnOff :PlotsOff
Input "DEGREE?",D
0->dim(L1
For(I,D,0,~1
2(D-I+1
If Ans>10
10
Output(Ans,1,"COEF. OF X^
Output(Ans,12,I
Disp "
Input C
C->L1(D-I+1
D+1->D
0->C
0->R
0->Z
0->theta
While not(L1(D
D-1->D
Z+1->Z
If 0>L1(1
Then
Text(R,C,"~
C+6->C
~L1->L1
L1(1->A
For(I,2,dim(L1
gcd(A,abs(L1(I->A
If A
L1/A->L1
If A>1
Then
Text(R,C,A
C+8+8int(log(A->C
If Z
Then
Text(R,C,"X
C+8->C
If Z=2
Then
Text(R,C,"^^2
C+8->C
If Z>2
Then
Text(R,C,"^
Text(R,C+8,Z
C+16+8int(log(Z->C
If D=1
Goto 12
Lbl 9
1->Q
1->I
For(J,1,2
abs(L1(I->A
{1->L2
2->B
While 2<Anot(fPart(A/2
Lbl 10
A/B->A
If fPart(max(L2)/B
L2->L4
augment(L4,BL2->L2
For(G,B+(B=2),sqrt(A),2)
If fPart(A/G
G->B
A->G
If B^^2<=A
Goto 10
augment(L2,AL2->L2
If I=1
L2->L3
D->I
0->dim(L4
For(I,1,dim(L2
For(J,1,dim(L3
L2(I)/L3(J->L4(1+dim(L4
0->dim(L2
0->dim(L3
SortA(L4
0->dim(L5
L4(1->L5(1
For(I,2,dim(L4
If L4(I-1)!=L4(I
L4(I->L5(1+dim(L5
0->dim(L4
dim(L5->B
For(I,max(1,int(B/2)),B
L5(I->L4(1+dim(L4
B-I-1->J
If J>0 and J!=I
L5(J->L4(1+dim(L4
0->dim(L5
1->A
Lbl 11
1->B
Repeat B=2
D->E
L1(1->L2(1
For(I,2,D
L1(I)+L2(I-1)L4(A->L2(I
If not(L2(D
Then
abs(L4(A->Y
1->N
While Y>|E~7N
N/Y->N
fPart(Y^^-1->Y
If 1>fPart(N
iPart(N->N
round(N,0->N
round(NL4(A),0->F
Text(R,C,"(
C+6->C
If N>1
Then
Text(R,C,N
C+8+8int(log(N->C
Text(R,C,"X
If theta
Text(R,C,"X^^2
If theta
C+8->C
C+8->C
Text(R,C,"-
If F<0
Text(R,C,"+
C+8->C
If C>=220
DelVar CR+14->R
Text(R,C,abs(F
C+8+8int(log(abs(F->C
Text(R,C,")
C+6->C
D-1->D
D->dim(L2
L2/N->L1
NQ->Q
If D=E or D=1
2->B
If A<=dim(L4
Then
If 0>L4(A
Then
A+1->A
Else
~L4(A->L4(A
If D>1 and Q<10 and A<=dim(L4
Goto 11
If D>1 and A<=dim(L4
Goto 9
theta+1->theta
If D>1 and theta=1
Then
For(I,D,2,~1
If L1(I) and fPart((I-1)/2
3->theta
If theta=1
Then
{L1(1->L2
For(I,3,D,2
L1(I->L2(1+dim(L2
L2->L1
0->dim(L2
dim(L1->D
If D>1 and theta=1
Goto 9
If D>1 and theta=2
Then
{L1(1),0->L2
For(I,2,D
augment(L2,augment({L1(I)},{0->L2
dim(L2)-1->dim(L2
L2->L1
0->dim(L2
dim(L1->D
If D>1
Then
Text(R,C,"(
C+6->C
For(I,1,dim(L1
D-I->J
L1(I->A
If A
Then
If A<0 and I=1
Then
Text(R,C,"~
C+8->C
If I>1
Then
Text(R,C,"-
If 0<A
Text(R,C,"+
C+8->C
If C>=200
DelVar CR+14->R
If 1<abs(A) or not(J
Then
Text(R,C,abs(A
C+8+8int(log(abs(A->C
If J
Then
Text(R,C,"X
C+8->C
If J=2
Then
Text(R,C,"^^2
C+8->C
If J>2
Then
Text(R,C,"^
Text(R,C+8,J
C+16+8int(log(J->C
Text(R,C,")
Lbl 12
Text(120,100,"READY
Pause
AxesOn:FnOn
SetUpEditor
Lbl 8
Output(1,1,"
