I think this is the easiest way, I made an example with a 5*5 sprite, saved into appvar "A"
Code: [i]B
det(0)
sum(0)
sum(1,"A","r")→SLOT
DefineSprite(5,5)→SPR // allocates data for your sprite (the program has to save the sprite anywhere)
sum(5,SPR,27,1,SLOT) // reads/copies the data into SPR (size is 2 bytes for width and height, 25 bytes for the pixels)
det(57,SPR,10,10)
Pause
det(1)
When trying to use the program, I start up the editor itself (after setting up the width and height), and instead of seeing a drawing screen, a mostly black box, with a rainbowy static in some places. Is there any fix for this
the quality is much better on the calc itself. everything seems to look fine but the drawing area itself.
I noticed this problem a while ago; the program needs clibs version 9.0 (not higher). I think I also know now how to fix it for other clibs versions but I haven't done that yet, so you would have to wait or to use the lower clibs.
I have just downloaded version 9 and I still seem to have the same glitch
8.8 has it as well.
I will improve the program for the newer clibs, hopefully this will fix it
Hey, is this still a thing? it hasn't been updated in years and there are no good alternatives.
Personally I design all my sprites on the PC but when i need to do it on-calc, I like TIny_Hacker's Spriter program in particular:
https://www.cemetech.net/downloads/files/2383/x2825 . It requires installing the Celtic CE app.
https://www.cemetech.net/downloads/files/2373/x2916
Hello everyone, it's been quite a while and thanks to Lai I've got some new motivation to actually finish this project...
I'm very happy to announce:
Designer v5!
It is now compatible with newer clibs and contains a lot of improvements, especially for font design and custom color palettes. Also, I was able to create a sprite to png converter!
I would be very interested to hear on your opinion (and if there are any bugs I couldn't find).
This is probably the last update for Designer because I decided to continue my programming journey with other programming languages. Thanks to everyone who helped me with my projects, and especially to PT_ for the awesome opportunities ICE provides.
Have fun!
Can you please add an option to the font editor to display the characters in the preview window right next to each other without any padding/spacing?
