New UPDATE!
Changes:
- Last step before dying, winning, or completing a level is now visible
- Levelpack is now external and can be changed by the user
- New levelpack format V2 which has a few improvements (V3 will finally support high score tables and stuff)
- New levels in the default level pack added
- Dialog boxes are now autosizing itself
- Konami code fixed
- Changed the UI strings
- Added UI message parser
- Saving is improved (Pressing clear while playing)
- Door block fixed
- Some other Bugfixes
Installation:
You have to extract the zip-archive and then copy both files onto your calculator. Then run the TWOSTEP program using a shell or by using Asm(prgmTWOSTEP)
Screenshot
Download:
Get it here: http://backup.bmuessig.eu/www/download.php?id=TwoStep-z80
Changes:
- Konami code fixed
- Door block fixed
Installation:
Screenshot
Download:
