Updates
Currently unreleased client updates:
1) Client can now specify what port number it wants the bridge to connect to, using standard hostname with port string syntax. For those who may not know what this means:
If you do not specify a port number, the default is used (51701). The default port can be changed in the bridge config.
2) For server broadcast messages, the log line on the calculator shows up with a globe icon to indicate server message. Thanks to beckadamtheinventor for creating that particular sprite.
Currently live server updates:
1) For registration, email verification (via a regex) is added... invalid emails trigger registration failure.
2) An automated karma system for users is implemented as a form of bad-practice barring from the service. It works as such:
- User joins, initial karma is set to 10.
- Every packet the server receives from that user increments the karma by 1 (capped at 100)
- Every packet that fails one of two checks causes your karma to decrease by 2:
--- Attempting to send packet types you should only be able to send while logged in when not logged in
--- Sending a text field with special characters)
- A user (or IP) that hits 0 karma receives an IP ban.
play.titrek.us:51701
portion before the : is the hostname
portion after is the port number
