I spent a few days working on this to dust off my TI-BASIC skills, and here is the result. If there are any problems with the code, PM me or make a post with the offending code!
This was written on a TI-84+ CE, so it may not work on other calculators.
This uses a list named lPONG.
:ClrHome
:Menu("OPTIONS","PLAY!",AA,"VIEW STATS",BB,"LEAVE",CC
:Lbl BB
:Output(1,1,"PLAYER 1:
:Output(2,1,LPONG(1)
:Output(2,5,"WINS
:Output(4,1,"PLAYER 2:
:Output(5,1,LPONG(2)
:Output(5,5,"WINS
:Output(7,1,"HIGH SCORE:
:Output(7,13,LPONG(3)
:Lbl CC
:Stop
:Lbl AA
:Menu("-----CHOOSE-----","1 PLAYER",BC,"2 PLAYER",BD
:Lbl BC
:0-->E
:Goto F
:Lbl BD
:1-->E
:Lbl F
:prgmGRAPH       //all this does is clear graph and take out X&Y axis, Just put a standard fnOff, axisOff, GridOff, BackgroundOff, ect
:0-->Xmin
:-62-->Ymin
:1-->ΔX
:1-->ΔY
:-23-->A
:-23-->B
:47-->C
:-30-->D
:-2-->M
:0-->N
:Line(91,B,91,B+9
:Lbl A
:While M=-2
:Pt-On(C,D,2
:Line(3,A,3,A+9
:getKey-->K
:A+4(K=72)-4(K=92-->A
:For(X,A-4,A-1
:Pt-Off(3,X
:End
:For(X,A+9,A+13
:Pt-Off(3,X
:End
:Pt-Off(C,D,2
:C+M-->C
:D+N-->D
:If D≥-2 or D≤-60
:-N-->N
:If C<2
:Goto P2
:If pxl-Test(-D,C-2
:2-->M
:End
:T+1-->T
:randInt(-3,3-->N
:While M=2
:Pt-On(C,D,2
:Line(91,B,91,B+9
:getKey-->K
:B+4(K=74)-4(K=94-->B
:For(X,B-4,B-1
:Pt-Off(91,X
:End
:For(X,B+10,B+13
:Pt-Off(91,X
:End
:Pt-Off(C,D,2
:C+M-->C
:D+N-->D
:If D≥-2 or D≤-60
:-N-->N
:If C>92
:Goto P1
:If pxl-Test(-D,C+2)
:-2-->M
:End
:randInt(-3,3-->N
:T+.01-->T
:Goto A
:Lbl P1
:If E=1
:Then
:Disp "PLAYER 1 WINS!
:LPONG(1)+1-->LPONG(1)
:End
:If E=0
:Then
:Disp iPart(T)+100fPart(T)
:If iPart(T)+100fPart(T)>LPONG(3)
:iPart(T)+100fPart(T)>LPONG(3)
:End
:Stop
:Lbl P2
:If E=1
:Then
:Disp "PLAYER 2 WINS!
:LPONG(2)+1-->LPONG(2)
:End
:If E=0
:Then
:iPart(T)+100fPart(T)-->H
:Disp H
:If H>LPONG(3)
:H-->LPONG(3)
:End
I see some room for optimization, but you will need to provide PrgmGRAPH in order for me to be able to help you fully (it's preferable to be able to run the program and test things out)
I haven't taken the time to play with the entire thing, but here is the last 200 or so bytes, which can easily be optimized down to about 100 (it could probably be optimized a little more, but this is what I came up with)
Lbl P1
If E=1
Then
LPONG(1)+1->LPONG(1)
If E=0
Then
Stop
Lbl P2
If E=1
Then
LPONG(2)+1->LPONG(2)
If E=0
Then
iPart(T)+100fPart(T)->H
Disp H
If H>LPONG(3)
H->LPONG(3)
                  //could be
Lbl P1
DelVar HGoto P3
Lbl P2
1->H
Lbl P3
If E
Disp "PLAYER "+eval(H+1)+" WINS!
If not(E
Then
iPart(T)+100fPart(T
Disp Ans
If Ans>LPONG(3
Ans->LPONG(3
LPONG+{Enot(H),EH,0->LPONG
By taking a closer look at the code, I noticed that the variable T had something awkward about what it was doing. Every time the ball hits a paddle, it would add 1 or 0.01 depending on which paddle it hit. However, the only other time T shows up is in the iPart(T)+100fPart(T).This means that
1) Every 100 right paddle hits, it will add 1 to the score of the left, and overflow the right back to 0.
2) Since these scores are combined at the end, there is no use for this overcomplicating of T.
Therefore,
you can replace
T+.01-->T
With this
T+1-->T
And replace all occurences of
with this
T
And if you choose to do so, you can obviously also replace the iPart(T)+100fPart(T) in the code I provided yesterday.
prgmGraph:
fnOff
AxisOff
GridOff
BackgroundOff
ClrDraw
ClrGraph
Lbl P1
If E=1
Then
If E=0
Then
Stop
Lbl P2
If E=1
Then
If E=0
Then
Disp H
If H>LPONG(3)
H->LPONG(3)
                  //could be
Lbl P1
DelVar HGoto P3
Lbl P2
1->H
Lbl P3
If E
If not(E
Then
iPart(T)+100fPart(T
Disp Ans
If Ans>LPONG(3
Ans->LPONG(3
Thanks! I Put prgmGraph up and will test your optimizations when I have time, and if they work, and if you are ok w/ it, I will revise the post and code!
Thanks (Again)!
I made a Pong game for the CE in BASIC some while back, just for fun. I didnt really work on optimizing the code when I made it, but here it is:
:Lbl 2
:ClrHome:5->A:5->B:0->C:0->D
:Output(1,3,"--PONG by Cal[e]b Hill--
:Lbl 1
:Output(V,W,"
:randInt(3,9->V:randInt(8,12->W:
:1->M:1->N
:Output(1,1,C
:Output(1,26,D
:If C>D:"bolduparrowbolddownarrow->Str1
:If C"bolddownarrowbolduparrow->Str1
:If C=D:"--->Str1
:Output(1,2,sub(Str1,1,1
:Output(1,25,sub(Str1,2,1
:DelVar EDelVar K
:Repeat K=45 or C=5 or D=5
:   getKey->K
:   If K=21 and A>2:Then:Output(A+1,1,"
:   A-1->A
:   End
:   If K=31 and A<9:Then:Output(A,1,"
:   A+1->A
:   End
:   If K=25 and B>2:Then:Output(B+1,26,"
:   B-1->B
:   End
:   If K=34 and B<9:Then:Output(B,26,"
:   B+1->B
:   End
:   Output(A,1,"|
:   Output(A+1,1,"|
:   Output(B,26,"|
:   Output(B+1,26,"|
:   If not((W=2 and (A=V or A+1=V)) or (W=25 and (B=V or B+1=V))) and (W=2 or W=25)
:   Then
:   If W=25:C+1->C
:   If W=2:D+1->D
:   2->E
:   End
:   If E=2:Goto 1
:   If W=25 or W=2:N*~1->N
:   If V=2 or V=10:M*~1->M
:   Output(V,W,"
:   V+M->V
:   W+N->W
:   Output(V,W,"theta
:End
:If C=5:Output(5,5,"L Play[e]r Won!
:If D=5:Output(5,5,"R Play[e]r Won!
:Output(6,5,"To Play Again, hit 1"
:Repeat K
:   getKey->K
:End
:If K=92:Goto 2
:ClrHome
It uses the Home Screen/Calculator Screen, not the graph screen.
:Lbl 2
:Lbl 1
:Output(V,W,"
:1->M:1->N
:Output(1,1,C
:Output(1,26,D
:If C=D:"--->Str1
:DelVar EDelVar K
:   getKey->K
:   A-1->A
:   End
:   A+1->A
:   End
:   B-1->B
:   End
:   B+1->B
:   End
:   Output(A,1,"|
:   Output(A+1,1,"|
:   Output(B,26,"|
:   Output(B+1,26,"|
:   Then
:   If W=25:C+1->C
:   If W=2:D+1->D
:   2->E
:   End
:   If E=2:Goto 1
:   Output(V,W,"
:   V+M->V
:   W+N->W
:   Output(V,W,"theta
:End
:Repeat K
:   getKey->K
:End
:If K=92:Goto 2
:ClrHome
Cool! I decided to use the graph screen because I felt it would present more of a challenge, but this is better looking...
I tried this with the optimizations and it doesn’t work. I will reread my code to make sure I typed it in right.
Hey Franzee Tank,
You do realize that you could have just copied and pasted the code into TI Connect CE?
That is a free software offered by Texas Instruments that allows you to import programs from sites like Cemetech and Ticalc, and paste them into your calculator. You could have done the same when typing in the program manually.
Please help! I can't move my paddles. i double checked the code and it is all correct! Does anyone no a fix?
Wowiie this isn't a recent thread 😄
The controls should be 2nd and ALPHA for the left paddle and the up/down arrows for the right paddle. Are you using a TI-84 plus CE? And did you actually manually punch in all the code into your calc?
