Hello, long time no see!
I've had a very busy winter, and I haven't been able to do as much programming and etching as I would've liked (gCn, I'm looking at you). The weather has been too cold to etch effectively and I've had my weekends filled with coaching ski lessons.
Now that winter is slowly fading, I can get back to whats important: Rockets!
If any of you need a refresher from last year:
Anyway, I have a better idea for my rockets. Instead of just building more and more ridiculous things for the lolz, I have an actual goal in mind. I want to create a guided rocket using off the shelf parts.
It will work like this. An arduino or arduino-like board will be in the body, serving as the brain. It will be powered by a battery and control canards, most likely 4 of them. I plan on using servos for this. Also included will be a 9DOF board, and hopefully a GPS and maybe a small bluetooth adapter if I can find one small enough (so I can build many of them and program them after the fact).
This project will go in hand with my 3dof launch pad I'm creating (I have the circuitry, I just need to build it). This pad will launch anywhere from 1 to 9 rockets from launch tubes or rods, which may or may not be guided.
I have a new 3D printer I got a few days ago just for this project. Here's the preliminary test fit:
I'll fix the dimensions later to get the servos just right. This is a test bed of sorts right now, the final product will use smaller servos and use a smaller body. Large rocket motors aren't cheap!
I feel very confident that I will be able to at least make this have a rocket go straight up and stable; I work heavily with head tracking here at work and I have the resources to help me out with the code should I hit snags.
Tell me what you think!
Also, I have no clue how I'm going to do the parachute part of the rocket.
