Port of my Catylizm game for the TI-84 Plus CE! Written in C, like the original and the Nspire version, it uses the same controls and code.
Screenshots so far:
No releases until Mateo releases a masked scaled sprite routine, though, because doing it in C with his gc_NoClipSetPixelColor(x, y, c) to draw out each sprite makes the game so incredibly slooooow. But I look forward to seeing it fully functional!
Wow, this is really exciting! I love that you were able to develop it with relatively minimal (as far as I know?) changes to the C code, and also as far as I know, that SourceCoder's C-compilation features helped you out? I look forward to the released version once the sprite routine gets sorted out; I know that the sprite routines, especially the masked and clipped ones, have been giving Mateo a lot of headaches.
Wow, I loved the original and I'm glad to see it in colors
Thanks! Yeah, there weren't too many changes besides the graphics. Since the CE has the same screen dimensions as the Nspire, I mostly used the code from that port, which is basically the same as the Prizm version with different graphics routines, so I wouldn't have to go back and forth between the two versions. I did try a couple of things to try to get the speed better (at least on the main menu and the instructions screen), but I ended up going back to the original code. And yes, it saves me the trouble of having to set up the SDK myself. I'm glad the CE has C now.
Thanks! Although, it has always been in color since I created it (although the Nspire version works on the gray scale variants as well).
Wait, I thought it was for monochrome calculators? I guess I confused your project with another Contest 13 entry. (one of them was for the TI-83+/84+)
Is the speed quite fine overall, as in somewhat smooth or just fast enough to be playable? Do you use a lower color mode such as 8 bits?
Awesome! If I remember correctly, you said you did this all without a CE to even test it on... is that correct? Either way, it looks cool. And by the way, you're not the only one waiting for some new updates to the C graphics library- I'm waiting for tilemapping
Usually, it would be, but since I don't have a fast sprite drawing routine, it's super slow (even when the emulator is at 500%).
Well, I didn't have a CE to start testing on, so most of the code that I started with was just hoping that it would work right. I borrowed a CE from a friend at school for the weekend which allowed me to set up the emulator and fix a bunch of color issues.
Looking good! What else do you plan on porting? I'd love to see Zelda in full color on my CE. But I've heard somewhere that TI-Boy CE is in dev.
Thanks! Yeah, if only.
Btw, here's a gif just in case you were wondering how slow it was:
I was on 500% speed when I captured this gif, so I'm not sure if that's what it captured it in.
That's deathly slow for 500%! I hope you can fix that without too much trouble.
Just wondering how progress on this is going! Has Mateo created the sprite routine you need yet?
So what are you using to draw the graphics with this?
Is your sprite routine in C or is it ASM?
Surely this can't be that slow?
With Mateo's routines, this is the new speed:
There are issues with the transparency, so it will only work with the red backgrounds until Mateo can fix it. I've also asked him for clipped scaled routines because otherwise there are still some graphical errors. Not sure how the clipping will effect the speed, but we'll see.
Edit: Added different gif withh less frame-skip. Also, I'm not quite sure why the side panels are transparent.
Looking good, can't wait for a release
Ok that's looking much better!
Since Mateo couldn't get the Scaled Sprites clipped, I had to compromise and only scale the sprites that didn't move off the screen. Still a decent speed, though:
The only thing that bothers me is the size of the game:
You can use compression
Should work well with those sprites.
New size with compression:
For some reason, the two bottom pixels of the flame are not displayed? It could be a bug with compression, but I feel it's negligible for now.
I will upload to the archives shortly.
Nice work! The decompression should be fine; it probably is just getting the wrong size as input
Anywho, I would also recommend making a link to the C libs in your readme
