UPDATE !
The zip is no longer called SuperStarFox because MetaKnight is in... but also Jigglypuff !
Don't get overexcited on those two characters though. They have even less moves than Falco.
Now for real changes since last update:
-doubly linked list instead of table for object creation/deletion
-added falco's blaster (doesn't do damages but still fires)
-added falco's clone (for testing purposes, will not be in final version so have fun while you can
-moved menu sprites into appvar (be sure to update SSBODATA !)
-limited horizontal airspeed if in a state where we can control speed (probably too restrictive but at least enough)
-added halfpivot for Jigglypuff and MetaKnight's air jumps, and also for regular groundjumps (allows you to dash and jump backwards)
-hitboxes did not want to work so I reverted them back to a state where they worked with a bit of precision loss
Note: I don't know if Multi still works, I don't have two calcs with me at the moment -.-
edit Forget about this.
I found batteries for my 83+.fr and was able to test, find out what was wrong and correct it so now Multi is back
Download at the same place
