- TILP: beta-testing...
- 22 Jan 2010 01:30:33 pm
- Last edited by Lionel Debroux on 02 Oct 2021 01:37:27 am; edited 2 times in total
I have uploaded at http://lpg.ticalc.org/prj_tilp/download/setup.exe a pre-version (for Windows, obviously
) of TILP II 1.14, for beta-testing
(*nix users can try https://github.com/debrouxl/tilp_and_gfm/blob/master/tilp/trunk/build/scripts/install_tilp.sh , start by looking inside the script)
Even if I'm trying to get myself the necessary infrastructure for being a decent (co-)maintainer (bought a 89T, a 83+SE and a SilverLink), it's necessary to perform wider and deeper testing than just what I did on my Vista x86 and Seven x64 VMs
In particular, I can see driver trouble on Seven x64 (complains about unsigned drivers) but not under Vista x86. I can also see that unless the UAC is completely disabled (baaaaad !), Seven forbids TILP to write tilp.ini => need to improve this (by changing the location, probably).
Since TILP II 1.13, visible changes are TI-68k bugfixes (especially for PedroM), and important bugfixes for TI-Z80 (TI-Connect is now much happier with files and groups created by TILP). TILP keeps supporting, in a transparent way, the incorrect groups created by previous versions. I think I fixed a build/packaging problem that makes TILP II 1.13 not work for many users.
This test version was compiled with MSVC 2008 and GTK+ 2.12.9 (such was the result of a multi-forum poll one year ago: 9x/ME/NT4 support is no longer guaranteed).
Therefore, you have to install the VC++ 2008 Redistributable Package ( http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf ) if you don't have it yet. I hope to find a working MSVC 6, so as to remove that dependency.
A small limitation in this test version: no French locale. Not that most of those who read this board care, though.
Thanks in advance
EDIT in 2021: updated the link to the *nix install script.
Thanks in advance
