You love the game of Tetris on every platform, from your computer to your GameBoy to your TI calculator, so why not enjoy it in brilliant color on your Casio Prizm calculator? Featuring fast-paced gameplay, four play modes, high score tracking, and much more, this game is sure to be a permanent addition to your Prizm. In Marathon mode, try to complete lines for as long as possible as your score and the speed increase. High Speed mode ups the ante with faster drops at lower levels. If you want to start out in a bad situation, try Touchdown mode. With Collapse mode, you can set up giant stacks of tetrominos to score many lines at once. And to really torture yourself, see how long you can last with no line pieces in Sadistic mode.
tetrizm.g3a | 204.0 KB |
readme.txt | 873 bytes |
- 46.2 KB
- http://ceme.tech/DL659
Works great on my CG50, but there are 2 things I noticed that I think should be changed:
1. The icon is black. This means it was designed to blend in with the CG10 and CG20 OS, but doesn't work out with the CG50's light user interface. This is something I can get over with, I'm nitpicking here.
2. The hard drop speed is way too fast (pressing down). You can barely react. It's a lose button if you hold it down and you aren't a pro Super Smash Bros. Melee player. On further examination, this is further proof that the game was designed for the CG-10/20. You must use Ptune3 to underclock your calculator (press F2, for F3 is not sufficient as a underclock). This could be solved by running the game logic at a fixed rate (60 ticks per second), instead of the calculator's clock speed.
Other than those, this game's great. The modes are cool, and the graphics are great, even if you compare it to say, other Tetris ports, or other calculator games.
Works well on my CG50 with no bugs that I've seen.
I downloaded this program over a year ago and since then I had taken a break from my Casio calculator.
I re-downloaded it recently and it only took a minute or two for the nostalgia and fun that I had with my school friends to come back. Very fast, and very well done!
Very good job!
- [Prizm] Tetrizm v1.1 (published 7 years, 9 months ago; 2017-08-18 17:58 UTC)
