[Doors CS 6.1+] Password Protection v2.0
  3. TI-83 Plus/TI-84 Plus Assembly Programs
  4. TI-83 Plus/TI-84 Plus Assembly Shells
  5. TI-83 Plus/TI-84 Plus ASM Shell Modules
This program, for Doors CS v6.1 and higher, will install a Shell Expansion (SE) that protects your programs from unauthorized users. Once installed, takes up a mere 100 bytes of memory, and prevents Doors CS from being launched if the user does not know a password you set during installation.
Screenshot #4514
PWDSETUP.8XP 704 bytes
readme.txt 877 bytes
pwdsetup.asm 5.0 KB
2.8 KB
8/10 (2 votes)
This is a very effective password protector, it just has one big flaw. ***PROS: *Still works with Doors CS 7 *Easy to set up *If you set doors to run at startup, you effectively password protect your whole calc when people turn it on *If you delete the program, DCS still asks for the password (this is also a con) ***CONS: *The biggest con is there's no built-in way to remove the protection! Like I said before, you can't just delete the program. The only way I've got it to remove the password protector is by running the program, not entering a password, then clicking OK. This removes the password, but also causes a RAM clear. *A lesser con is you are required to use the mouse to select every text box and button, it's not that big of a deal, but it's still slow. ***CONCLUSION: Although you can't easily remove the protection, if you plan on keeping it in place forever, this is definitely the best password protector for the TI-84 Plus. [8/10]
  1. [Doors CS 6.1+] Password Protection v2.0 (published 15 years, 1 month ago; 2010-04-29 22:12 UTC)
