Welcome to Pixels.py - an easy to use but satisfying RGB art designer written entirely in python for the Casio Fx-CG50. Design a neat, grid style painting or an utterly chaotic scene, the possibilities are endless!
Not sure where to start? Lucky, as you can see below, there are four screenshots of the project. On top of them, you can see instructions on what to input should you want to recreate them. Have you found a great pattern you want to share? Then you can do this too! When prompted, type in 1 for seeing list of inputs at the end/AC press.
This project is SUPER lightweight. Even with all of the mentioned features and the ones I have not mentioned, it only takes up 2.8KB. That's less than this description! Unfortunately, to keep the file size so low, I had to make the code very hard to read with no notes.
This project was made an tested for MicroPython on the Cg50. Compatibility with other calculators is not guaranteed. If there are any suggestions or bugs, please tell them to me via either a private message or through a rating.
- 2.8 KB
- http://ceme.tech/DL2248
- Pixels.py - create an RGB masterpiece! (published 2 years, 7 months ago; 2022-04-22 15:41 UTC)
