- TI-84 Plus CE Programs
- TI-84 Plus CE Assembly Graphics Programs
This program gives you near full control over the LCD brightness!
*You can quickly get the current brightness value by simply starting the program.
*You can now brighten and darken the screen over the limits of the OS.
*You can also increase brightness in smaller increments.
*You can now set a custom brightness for your display!
*You can use the subprograms for your own needs! (Read ReadMe.txt for credit instructions)
Big thanks to MateoConLechuga for helping me with the C program!
Warning, this was made for the TI 84 Plus CE, it will not work on the TI 84 Plus CSE or any monochrome calculators.
BRIGHT.8xp | 725 bytes |
GETLCD.8xp | 548 bytes |
SETLCD.8xp | 91 bytes |
ReadMe.txt | 2.0 KB |
- 2.4 KB
- http://ceme.tech/DL1751
- TheLastMillennial
- 8.7/10 (3 votes)
installed it a while ago and worked amazingly but a reinstall made it so it doesn't do anything.
Edit: Randomly started working again
Great utility, but once updated to past 5.5.1, even with Cesium shell and ARTIFICE exploit, it doesn't work.
- Advanced Brightness Utility (published 7 years, 1 month ago; 2018-04-04 20:46 UTC-04:00)
