big boi bump*. Is there still work on this project? I don't know why the download link was removed.
» Forum
> Your Projects
The download link wasn't removed, it's here: https://tr1p1ea.net/files/downloads/MKARTCE_pre_pre-alpha_demo_feb2021.zip
Thanks Tiny, but is there any active development? This is a super cool project and I would hate to see it die.
It's still happening ... just slowly as always ... đ.
I should note that the demo won't work on the latest TIOS unfortunately (5.6.1).
Let me know if you have any feedback ideas.
Are there any plans to make it work with 5.6.1? I sadly am stuck with 5.6.1 and this looks really fun and i wish I could play it. It's a very good-looking project! Keep it up! đ
tr1p1ea
- Cemetech Expert (Posts: 1868)
- 19 Aug 2021 09:50:05 pm
- Last edited by tr1p1ea on 23 Aug 2021 05:38:41 pm; edited 1 time in total
Hey there - sure I can make the demo work with 5.6.1 ... but keep in mind that it is just a demo that doesn't do a whole lot as yet.
OK I think I correctly added 5.6.1 support (by copying đ) - however please back up your calculator before trying out, since this is an experimental pre-alpha test version of the game:
https://tr1p1ea.net/files/downloads/MKARTCE_pre_pre-alpha_demo%28561%29_aug2021.zip
Will there be a releasable version any time soonish?
Also, I can't see the YouTube video or any of the previews, which makes me kind of sad... âšī¸
Demo not yet updated for 5.7!
I'll have to modify it again.
I plan on working on this project to add more stuff soon đ.
Raytracing, slopes and VR headset support... er I mean I can't wait for updates on this project as well as the other related thing đ I'll have to modify it again.
This is definitely way, way up there with the V3D engine (someone i forget who) is working as one of the coolest things for the CE I have ever seen! Keep up the good work; this looks amazing!
I should update for 5.7 - let me see what I can do!
EDIT - You can try this link: https://tr1p1ea.net/files/downloads/MKARTCE_pre_pre-alpha_demo_feb2022.zip
It hopefully should work? PLEASE BACK UP YOUR STUFF FIRST! as I can't test on 5.7 atm (if someone could let me know?).
Note this will be slower in places than the other demos (when lots of sprites are on screen).
Is the slowdown that you mention caused by adding compatibility with OS 5.7? EDIT - You can try this link: https://tr1p1ea.net/files/downloads/MKARTCE_pre_pre-alpha_demo_feb2022.zip
Sort of - I moved the code that was typically run from SHA RAM, which requires an unlock to use to a slower location that doesn't require an unlock. This means that It will work on any OS but there is a speed hit in certain instances. I will worry about optimising further for speed at a later date.
Page 7 of 10
