It's a language i have created it works and it is pretty simple.
<versascript>
menu.add
menu=main,test1/t1/,test2/t2/"
t1=Lbl
lbl.T1
print."Hello world"
end.T1
t2=Lbl
lbl.T2
print."Goodbye world"
end.T2
</Versascript>
looks fancy. what else can it do?
EDIT: why is this in the graphix forum.
Moved to Community News.
is this for calculators or what?
It looks like it, but he provided no data whatsoever, so who knows?
Is there a reason for the use of labels? Personally I think any new language should completely disallow any use of labels/gotos or so strongly hide them that they are near-impossible to find (eg, C/C++, Python, PHP....)
If you go to my site
www.greencini.co.nr and look at my versascript school and other pages you will under stand.
It looks very convoluted and poorly designed....
for the idiotic remark can you make viruses out of it, well the answear is yes because it is so tied in with the windows system and config that it is easy to destroy major files and to wipe the hardrive accidentally.
Is there away where i could simplify it to go on ti-83+?
ZOMGWOWNOWAI! Why are you so obsessed with viruses?
That is an INCREDIBLY stupid reason to use this language...
If you want to talk about being able to delete files because it is so tied into Windows, just use a bat file
I'm not someone asked if it was possible on the talkbox and i posted yes in here.
If you read the script it should make sence on what it does but if you are dumb then I will tell you, it ask for your name and age and display's them together.
Code: <versascript>
print."Welcome"
Input.box"enter name"[" "],Str@
print."hello:",Str@
Input.box"Age"[" "],Str@
print."You are" Str@ "Years old."
Display.All
Pause.Ok",.CMD
</versascript>
"Erase any unwanted files"
//You may see a lot of Cont"(continue protocol of it was not in there it would erase hardrive)
Code: <versascript>
new.exe"
while exe.new
else
stop.script
If.exe=new
Then
Cont"
defragment.sky
Cont"
If code=.bat"[check]
If code=True[del.check]
If code=false[Cont"]
Then"
If code=.c++/C Lang{[check}]
If code=True.Del[[del.Check]]"
If code=false[Cont".loop]
Then"
additem.list
display.del"[items] //displays any items deleted
If false.item
Then"
Item.del[Restore].original
</Versascript>
What does that even do? Just saying "erase all viruses" is not very descriptive, because that program could NOT do that.
This code is messed up tell me why.
Code: <versascript>
registry=new.hidden
exe.registry"
copy.loop",extend
extend=none.all
nme="versa.reg"
extend.nme=Name
copy.loop"
stop.false
end.true
while loop=090989
stop.script=false"
</versascript>
omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!! omfg im not obsessed adout viruses!!
I don't know and I don't care. Why do you carry on though... Really... Tell us something about the specs of the language, what it can do, what it can't do, some of its commands.
-_-
EDIT: well stop mentioning viruses in everything you do here
Simple Commands
1.CMD = Command
2.Print = Display text/or item ,EXP[Print."Hello" or Print.Item1]
3.<versa>" = add a program to the original script ,EXP[<versa>"<Program1>
4.(%&^) = auto exit , this will exit the code no matter what.
5.system = there are thousands of sytem codes ,EXP[Sytem.Model]displays model number
6.additem = add's and item ,EXP[table.additem]
7.Envoir.rule = makes a rule that prgm must follow ,EXP[Envoir.rule"Stop,Break"] code won't stop.
8.input.box = adds a input box that you will enter info in.
9.<del.versa> = this is used as a deleting script.
a simple clock
<versascript>
additem.circle
circle=20x20
circle.nme=clock
clock=time
time.var=0-60
var.edit
second.a
minute.b
hour.c
A=1-60.timer=1
B=1-60.timer=60
C=1-12.timer=5120
additem.cmd="OK"
display.clock.A.B.C
stop.end
</versascript>
