As you probably suspect, I like Minecraft, and so here is another version, this time for the Ti84+. This is a game I made in the past and decided to share here. This program is written in TIBASIC. I present...
MinecrafTI(84)
Current Features (v1)
Saving/Loading worlds saved in the B matrix
Ability to place/mine 3 different blocks:
►Tall grass
►Dirt (1st layer)
►Stone (2nd layer)[/list]
Gravity
Control menu
Controls
A control menu is also included in the program.
Arrows→move
Number pad→Action (break/place)
[y=]→Cycle selected block
[del]→Save + back to menu
[2nd]→Break mode
[alpha]→Place mode
Tell me what you think!
Download the program: >>DOWNLOAD<< (Github)
For the main menu, you should replace this:
1->A
While 1
   If A=1
   Then
      Output(4,6,">
      Output(5,6,"
      Output(6,6,"
      Output(7,6,"
   If A=2
   Then
      Output(5,6,">
      Output(4,6,"
      Output(6,6,"
      Output(7,6,"
   If A=3
   Then
      Output(6,6,">
      Output(4,6,"
      Output(5,6,"
      Output(7,6,"
   If A=4
   Then
      Output(7,6,">
      Output(4,6,"
      Output(5,6,"
      Output(6,6,"
   Repeat K
      getKey->K
   If K=25 and A!=1
   A-1->A
   If K=34 and A!=4
   A+1->A
   If K=105 and A=1
   Goto NW
   If K=105 and A=2
   Goto LD
   If K=105 and A=3
   Goto CN
   If K=105 and A=4
   Goto X
With this:
0->A
While Ans!=105
   Output(A+4,6,">
   Output(A+3,6,"
   Output(A+5,6,"
   A-(Ans=25 and A)+(Ans=34 and A!=3->A
   getKey
If A=3
Goto X
If A=1
Goto LD
If not(A
Goto NW
It seems like that on line 336 the "If [B](B,A-1)<=0" goes out of bounds if you are breaking a block on the far left of the screen. It displays an "ERR:INVALID DIM" when doing the above action.
I don't know how to fix this though.
1->A
While 1
   If A=1
   Then
      Output(4,6,">
      Output(5,6,"
      Output(6,6,"
      Output(7,6,"
   If A=2
   Then
      Output(5,6,">
      Output(4,6,"
      Output(6,6,"
      Output(7,6,"
   If A=3
   Then
      Output(6,6,">
      Output(4,6,"
      Output(5,6,"
      Output(7,6,"
   If A=4
   Then
      Output(7,6,">
      Output(4,6,"
      Output(5,6,"
      Output(6,6,"
   Repeat K
      getKey->K
   If K=25 and A!=1
   A-1->A
   If K=34 and A!=4
   A+1->A
   If K=105 and A=1
   Goto NW
   If K=105 and A=2
   Goto LD
   If K=105 and A=3
   Goto CN
   If K=105 and A=4
   Goto X
With this:
0->A
While Ans!=105
   Output(A+4,6,">
   Output(A+3,6,"
   Output(A+5,6,"
   getKey
If A=3
Goto X
If A=1
Goto LD
If not(A
Goto NW
Youre a Optimizer Genius TI-84+
