I've been working on a Celtic sudoku program lately, and it's coming together nicely. So far, you can create, edit, delete, and solve sudokus, all from within the program. It opens with an OS menu, but the actual gameplay looks closer to an assembly program.
(The blue numbers are the default ones, and the salmon-colored box is the "cursor.")
I'm currently working on adding a feature that finds mistakes in the puzzle, and I eventually want to create a sudoku generator and solver. (I think it can be done, but it's probably too ambitious for an idiot like me.) Anyway, I'd love to see some feedback from you guys. I'll be posting some more updates as I continue to code.
The colors look useful, although I imagine those particular choices might be annoying to some users- it would be cool to give a couple options of color scheme.
My old sudoku game does some moderately simple puzzle generation, and on inspection JWinslow's nice-looking implementation uses a similar algorithm: if you start with a completed puzzle, it will always remain valid if you swap rows or columns in the same group of three rows/columns. At that point you can remove numbers to make it an incomplete puzzle, where the number of entries you remove roughly correlates with the puzzle difficulty. This approach is somewhat limited though, because it's difficult to provide some of the guarantees that make a puzzle 'nice' to a typical person if you randomly remove numbers: notably that the puzzle only has one solution and it doesn't require too much guessing to make progress.
I get the impression that published sudoku puzzles are typically graded on difficulty based on the strategies required to solve them, so it's difficult to generate a puzzle of a chosen difficulty and it's more common to generate many puzzles and select one of the chosen difficulty. To ensure a puzzle has only one solution, the puzzle generator needs to implement a solver algorithm that evaluates what options a given puzzle has for solutions. That's not a terribly complex algorithm it seems, but enough so that it may be difficult to write in TI-BASIC.
A feature that I'm not sophisticated enough as a sudoku solver to make much use of but that is key to the general algorithm is being able to note what numbers are valid in a given cell, so it might be nice to offer a scratchpad for the user to enter values associated with each cell. Or if you wanted to provide more of a pencil-and-paper experience, provide a way to "pencil in" a number that you think might be correct but doesn't contribute to checking whether the puzzle is correct- possibly make it a lighter color.
Overdue update: I completely changed the color scheme, and have added the mistake-finding feature. I recently got a book of sudokus, and I plan to port 150 of them to the calculator as a default level pack. (I'll use a For( loop and randIntNoRep( to circumvent those pesky copyright laws.) I've been very busy lately and have some school assignments due soon, so I likely won't get around to it for a little while, but I plan to upload an early release at some point in the (relatively) near future.
Looks cool Shock
I've been very busy lately, but the dust is starting to settle now that THE SCHOOL YEAR IS OVER!! 🎉🎈🎆 I've ported 75 sudokus to my calculator over the past 2 days or so, and I plan to upload an early release soon.
