I'm building a diy GSM module with PlutoSDR, and I was wondering how far it can transceive at.
DUDE. WOW. Okay. That's quite a lot more than the BladeRF x40! Not like it's a bad thing, though.
What about with additional hardware, like TX and RX low noise amplifiers?
Which side of the GSM connection are you trying to build with the PlutoSDR? A UE or a BTS?
GSM is limited to ~ 40 km(?) of range via protocol timing limits. This is dependent on what's between the two antennas. for 40 km, you'd need a BTS antenna at 100m and a UE antenna that's line of sight, so flat terrain and no trees between the two.
You'd also need a license to transmit that kind of power on those frequencies. If you jam someones cellphone, unpleasant things can happen to you, so keep it to 50 yards.....
