I've seen a few USB C mods for the TI-84 Plus CE but they all seem to have the same issue: they're charge only. This mod replaced the USB port. This mod simply added a secondary port.
Even if the mods above could get data transfer working, as I understand it, the breakout boards would only support either transmitting data or receiving data; OTG functionality would be lost.
I'd like to keep OTG functionality so I went on Amazon and searched for OTG adapters I could take apart. It took a bit of digging but I found this adapter which claims to retain OTG functionality! I noticed there's a catch though:
For those that understand USB better than I do, is the ideal USB C conversion mod (charging + OTG at the same time) possible? I'd like to get a clear understanding of why this may or may not work before I hack my calculator apart again.
This Adapter only supports charging from wall charger or car charger, It will start OTG function once connecting computer or other devices. OTG function and charging function could not be used at the same time.
