I basically finished the converter, it's a lot nicer than my old one in every way. The code is a lot neater, and it has many more functions. It will warn you if you're converting an image that probably wont fit on the calculator without resizing it. It can also log events and tell you what went wrong if conversion failed. Most importantly: it now cleans up after itself! It does this by deleting the dozens of unnecessary files convpng creates, then it stores all the converted appvars in a named folder!
Just for fun, I gave the program a 300MB picture to convert. It actually converted the image into 26,000 files and successfully cleaned up the useless ones!
This took quite a long time to implement due to my program not being authorized to create or modify images in some directories, even if they're directories the program itself made. 🙄
I have the code up on github here: https://github.com/TheLastMillennial/HDPictureViewerConverter2 I didn't include convpng if you download the project yet so you can't really use it right now. I also haven't bothered to create a readme yet since there isn't anything that can utilize this converter. I'll get to including those soon though!
So the easy part is done now. Now I need to get cracking at C.
