I have recently came across this link to be able to compile C files to be compatible with the CE. I followed all of the the instructions three times, but I still get the same results.
The result is 'no rule to make target'
Here is the link to the compiler:
https://github.com/CE-Programming/toolchain/releases
If anyone has any idea what is wrong, then please reply.
This is likely because the makefile is pointing to a directory that doesn't contain the source file. Are your source files under an "src" folder?
The structure should be:
Code: [root]
-makefile
-src
-yourmain.c
-another.c
