Since this appears to be all up-to-date, I will gladly release it. Just have to find the time to put it all together....... Unless one of you guys want to do it, since I am (unfortunately) busy working on a HUGE ESSAY for my English teacher. Just put it all together, post it, and I will get it into SC3 and upload it from there.
» Forum
> Your Projects
I put it together within a few days, where it would he ready for release! Good luck on the essay, and I wish you a safe summer.
I've combined the two parts of the program, and the two most optimized versions come to a whopping 1600+ish bytes. This is the monochrome version (I'll sent it to PT_ for color translation). One this I want to a dress though...The AI always wins. This is obviously not fun for the user, and my AI design allows for easy dumbing down. I'm designing a menu where you select between Trivial, Easy, Medium, Hard, and Impossible, and would add a few hundred byes to data.
- NoahK
- Advanced Member (Posts: 244)
- 01 Jun 2015 03:52:49 pm
- Last edited by NoahK on 02 Jun 2015 06:16:20 am; edited 1 time in total
I and PT_ have talked a bit, and here are the difficulty levels in play, along with what they will execute:
1-Win-Block
2-Center
3-Block Double
4-Opposite Corner
5-Random Corner
6-Random Edge
7-Random Piece
Random: 7
Trivial: 1,7
Easy: 1,5,6,7
Medium: 1,2,5,6,7
Hard:1,2,4,5,6,7
Impossible: 1,2,3,4,5,6,7
[Edit]
Here is the *final* code. It works on both color and monochrome, TI-83 all the way up to TI-84+CSE/CE:
Please feel free to test the code!
1-Win-Block
2-Center
3-Block Double
4-Opposite Corner
5-Random Corner
6-Random Edge
7-Random Piece
Random: 7
Trivial: 1,7
Easy: 1,5,6,7
Medium: 1,2,5,6,7
Hard:1,2,4,5,6,7
[Edit]
:DCS
"2424FF2424FF2424BBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBB3333333333333333BBBB3BBBBBB3BBBBBBBB3BBBB2B3BBBBBBBB3B22BBB3BBBBBBBB32B2B2B3BBBBBBBB3B22B2B3BBBBBBBB3BBBBBB3BBBB3333333333333333BBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBB"
94DeltaX+Xmin!=Xmax->G
If G
TextColor(Black
AxesOff
0->O
0->N
Lbl 0
0identity(3->[A]
Menu("Tic-Tac-Toe AI","Play",1,"Quit",2
Lbl 2
ClrHome
Stop
Lbl 1
1->F
Menu("AI Difficulty","Random", A,"Trivial",B,"Easy",C,"Meduim",D,"Hard",E,"Impossible",F
Lbl F
F+1->F
Lbl E
F+1->F
Lbl D
F+1->F
Lbl C
F+1->F
Lbl B
F+1->F
Lbl A
ClrDraw
~38->Xmin
If G
~33->Xmin
61->Ymax
~1->Ymin
61->Xmax
For(A,0,60,20
If G
Then
Line(A,0,A,60,Black
Line(0,A,60,A,Black
Else
Line(A,0,A,60
Line(0,A,60,A
Text(20,0,"GAMES WON
Text(32,0,"O: ",O
Text(44,0,"X: ",N
2->A
2->B
0->W
0->R
Repeat W or theta=45 or (R=9 and not(W
min(3,B->B
Text(0,0,"O'S TURN
If G
Then
Pt-On(20A-10,20B-10,Black
Else
Pt-On(20A-10,20B-10
Repeat Ans
getKey
Ans->theta
Pt-Off(20A-10,20B-10
min(3,max(1,A+(theta=26)-(theta=24->A
min(3,max(1,B+(theta=25)-(theta=34->B
If G
Then
Else
Pt-On(20A-10,20B-10
If theta=105 and not([A](A,B
Then
R+1->R
If G
Then
Circle(20A-10,20B-10,7,Blue
Else
Cirlce(20A-10,20B-10,7
1->[A](A,B
For(C,1,3
sum(seq([A](X,C),X,1,3->D
sum(seq([A](C,X),X,1,3->E
If sum(3={D,E
1->W
If sum(12={D,E
2->W
sum(seq([A](X,X),X,1,3->D
sum(seq([A](4-X,X),X,1,3->E
sum(2(12={D,E})+(3={D,E->W
If R<9 and not(W
Then
R+1->R
Text(0,0,"X'S TURN
ClrList L1
4->U
If F>1
Then
For(S,1,3
For(Q,1,3
1+(Q=3->P
3-(Q=1->V
S-(S=2->X
S+(S=2->G
2+(S=2->T
"5(U=Ans->|u
4-S->C:4-Q->Z
[A](S,V
If [A](S,P)=Ans and [A](S,P)not([A](S,Z
S+Z[i]+|u->L1(1+dim(L1
[A](V,S
If [A](P,S)=Ans and [A](P,S)not([A](Z,S
Z+S[i]+|u->L1(1+dim(L1
[A](T,T
If [A](X,X)=Ans and [A](X,X)not([A](C,C
C+C[i]+|u->L1(1+dim(L1
[A](2-(S=2),T
If [A](4-G,X)=Ans and [A](4-G,X)not([A](S,C
S+C[i]+|u->L1(1+dim(L1
If F>3 and not(dim(L1)) and not([A](2,2
2+2[i]->L1(1
If F>5 and not(dim(L1)) and (([A](1,1)=[A](3,3) and [A](1,1)=1) or ([A](3,1)=[A](1,3) and [A](3,1)=1
Goto 6
If F>4 and not(dim(L1
Then
For(S,1,3,2
For(Q,1,3,2
If [A](4-S,4-Q)=1 and not([A](S,Q
S+Q[i]->L1(1+dim(L1
If F>2 and not(dim(L1
Then
For(S,1,3,2
For(Q,1,3,2
If not([A](S,Q
S+Q[i]->L1(1+dim(L1
Lbl 6
Then
For(S,1,3,2
If not([A](2,S
2+S[i]->L1(1+dim(L1
If not([A](S,2
S+2[i]->L1(1+dim(L1
If not(dim(L1
Then
Repeat not([A](I,J
randInt(1,3->I
randInt(1,3->J
I+J[i]->L1(1
randInt(1,dim(L1->S
real(L1(S->I
imag(L1(S->J
For(D,1,dim(L1
If 5<real(L1(D
Then
real(L1(D))-5->I
imag(L1(D->J
4->[A](I,J
If G
Then
Line(20I-3,20J-3,20I-17,20J-17,Red
Line(20I-3,20J-17,20I-17,20J-3,Red
Else
Pt-Off(20I-10,20J-10
For(C,1,3
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If sum(3={D,E
1->W
If sum(12={D,E
2->W
Text(0,0,"TIE!
If W
Then
O+(W=1->O
N+(W=2->N
Text(0,0,sub("OX",W,1)," WINS!
Text(32,14,O
Text(44,14,N
Pause
Goto 0
I think six difficulty levels is too much for a tic-tac-toe game.
Interestingly, the "Impossible" really is impossible to win against.
There are 6 because it is possible to have 6 with the code I wrote. It's not hurting to have so many levels
And thanks, I worked very hard to make it impossible.
[Edit]
After deep and academic conversation between I, Merth, Jonimus, and Runer112, it has come to conclusion that this "all-encompassing-cross-platform" program, designed to run on both color and monochrome calcs would work.
But:
Only if the program is exported my Merth's TokenIDE for the 83+, where the generated file could then be sent to *any* calculator from that computer. Sending the file from calculator to calculator will not work.
If that is a problem, then I can separate the color and monochrome programs, as so there are no issues.
[Edit]
But:
Well, it won't work properly on both the calcs. The code you give, have an icon for the color version, while I can't find the icon for the mono
. But the code looks good and I will test it (and if possible optimize
The monochrome icon is the first 16 characters of the color icon: the top row of the color icon is pink and gray, but it makes perfect sense on a monochrome as an 8x8. I think we may have to separate the programs.....
Well, can't we just put both programs in one compressed folder and clearly show the difference between the two? I could do that when I upload it.
Well, here's my optimization, I don't know whether the 4 lines at top will work.
And NoahK, instead of colors, use can use numbers, which are ignored at the mono-calc but used with the color one.
:DCS
"BBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBB3333333333333333BBBB3BBBBBB3BBBBBBBB3BBBB2B3BBBBBBBB3B22BBB3BBBBBBBB32B2B2B3BBBBBBBB3B22B2B3BBBBBBBB3BBBBBB3BBBB3333333333333333BBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBBBBBB3BBBBBB3BBBB"
:DCS6
"0810081008100810FFFF081008500B100D500B500810FFFF0810081008100810
If G
TextColor(Black
AxesOff
0->O
0->N
Lbl 0
0identity(3->[A]
Lbl 2
ClrHome
Stop
Lbl 1
1
Menu("AI Difficulty","Random",A,"Trivial",B,"Easy",C,"Medium",D,"Hard",E,"Impossible",F
Lbl F
Ans+1
Lbl E
Ans+1
Lbl D
Ans+1
Lbl C
Ans+1
Lbl B
Ans+1
Lbl A
Ans+1->F
ClrDraw
~38+5G->Xmin
61->Ymax
~1->Ymin
61->Xmax
For(A,0,60,20
Line(A,0,A,60,12
Line(0,A,60,A,12
Text(26+6G,0,"O: ",O
Text(32+12G,0,"X: ",N
2->A
2->B
0->W
0->R
min(3,B->B
Text(0,0,"O'S TURN
Pt-On(20A-10,20B-10,12
Repeat Ans
getKey
Ans->theta
Then
R+1->R
Circle(20A-10,20B-10,7,10
1->[A](A,B
For(C,1,3
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If R<9 and not(W
Then
R+1->R
Text(0,0,"X'S TURN
ClrList L1
4->U
If F>1
Then
For(S,1,3
For(Q,1,3
1+(Q=3->P
3-(Q=1->V
S-(S=2->X
S+(S=2->K
2+(S=2->T
"5(U=Ans->|u
4-S->C:4-Q->Z
[A](S,V
[A](V,S
[A](T,T
[A](2-(S=2),T
If [A](4-K,X)=Ans and [A](4-K,X)not([A](S,C
2+2[i]->L1(1
Goto 6
Then
For(S,1,3,2
For(Q,1,3,2
S+Q[i]->L1(1+dim(L1
Then
For(S,1,3,2
For(Q,1,3,2
If not([A](S,Q
S+Q[i]->L1(1+dim(L1
Lbl 6
Then
For(S,1,3,2
If not([A](2,S
2+S[i]->L1(1+dim(L1
If not([A](S,2
S+2[i]->L1(1+dim(L1
If not(dim(L1
Then
Repeat not([A](I,J
randInt(1,3->I
randInt(1,3->J
I+J[i]->L1(1
randInt(1,dim(L1->S
real(L1(S->I
imag(L1(S->J
For(D,1,dim(L1
If 5<real(L1(D
Then
real(L1(D))-5->I
imag(L1(D->J
4->[A](I,J
Line(20I-3,20J-3,20I-17,20J-17,11
Line(20I-3,20J-17,20I-17,20J-3,11
For(C,1,3
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If sum(3={D,E
1->W
If sum(12={D,E
2->W
Text(0,0,"TIE!
If W
Then
O+(W=1->O
N+(W=2->N
Text(26+6G,7+7G,O
Text(32+12G,7+7G,N
Pause
Goto 0
Can we get rid of the TextColor command? And just let the text be whatever color it wants? That would work great!
Alright, here it is:
PT_ and caleb, be sure to test in on your colors!
[Edit] I dont have a color, but I think this is it, the final edit.
:DCS
AxesOff
0->O
0->N
Lbl 0
0identity(3->[A]
Lbl 2
ClrHome
Stop
Lbl 1
1
Lbl F
Ans+1
Lbl E
Ans+1
Lbl D
Ans+1
Lbl C
Ans+1
Lbl B
Ans+1
Lbl A
Ans->F
ClrDraw
~33-5G->Xmin
61->Ymax
~1->Ymin
61->Xmax
For(A,0,60,20
Line(A,0,A,60,12
Line(0,A,60,A,12
2->A
2->B
0->W
0->R
min(3,B->B
Text(0,0,"O'S TURN
Repeat Ans
getKey
Ans->theta
Then
R+1->R
If G
Then
Else
1->[A](A,B
For(C,1,3
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If R<9 and not(W
Then
R+1->R
Text(0,0,"X'S TURN
ClrList L1
4->U
If F>1
Then
For(S,1,3
For(Q,1,3
1+(Q=3->P
3-(Q=1->V
S-(S=2->X
S+(S=2->K
2+(S=2->T
"5(U=Ans->|u
4-S->C:4-Q->Z
[A](S,V
[A](V,S
[A](T,T
[A](2-(S=2),T
2+2[i]->L1(1
Goto 6
Then
For(S,1,3,2
For(Q,1,3,2
S+Q[i]->L1(1+dim(L1
Then
For(S,1,3,2
For(Q,1,3,2
If not([A](S,Q
S+Q[i]->L1(1+dim(L1
Lbl 6
Then
For(S,1,3,2
If not([A](2,S
2+S[i]->L1(1+dim(L1
If not([A](S,2
S+2[i]->L1(1+dim(L1
If not(dim(L1
Then
Repeat not([A](I,J
randInt(1,3->I
randInt(1,3->J
I+J[i]->L1(1
randInt(1,dim(L1->S
imag([i]L1(S->I
imag(L1(S->J
For(D,1,dim(L1
If 5<imag([i]L1(D
Then
imag([i]L1(D))-5->I
imag(L1(D->J
4->[A](I,J
For(C,1,3
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If sum(3={D,E
1->W
If sum(12={D,E
2->W
Text(0,0,"TIE! "
If W
Then
O+(W=1->O
N+(W=2->N
Text(0,0,sub("OX",W,1)," WINS! "
Text(26+6G,7+7G,O
Text(32+12G,7+7G,N
Pause
Goto 0
Here's my code that I would like to add to it:
DelVar Str1:{3,3}->dim([A]):0->Z:0->P:Fill(0,[A]
Menu("TIC-TAC-TOE","PLAY",1,"QUIT",2
Lbl 1
ClrDraw:0->Xmin:60->Xmax:0->Ymin:60->Ymax:AxesOff:0->W:Zsquare
For(A,0,60,20
Line(A,0,A,60
Line(0,A,60,A
2->A:2->B
Repeat theta=45 or Z=9
getKey->theta
Text(0,0,sub("OX",P+1,1
A+(theta=26 and A<3)-(theta=24 and A>1)->A
B+(theta=25 and B<3)-(theta=34 and B>1)->B
Pt-On(20A-10,20B-10
If theta=105 and P=0:Then
If not([A](A,B
Then
1->[A](A,B):not(P)->P:Z+1->Z:0->theta
Circle(20A-10,20B-10,10
Matr>list([A],L1,L2,L3
If sum(L1)=3 or sum(L2)=3 or sum(L3)=3 or L1(1)+L2(2)+L3(3)=3 or L1(3)+L2(2)+L3(1)=3 or L1(1)+L2(1)+L3(1)=3 or L1(2)+L2(2)+L3(2)=3 or L1(3)+L2(3)+L3(3)=3
Then
9->Z:1->W
If theta=105 and P=1:Then
If not([A](A,B
Then
~1->[A](A,B):not(P)->P:Z+1->Z:0->theta
Line(20A-20,20B,20A,20B-20
Line(20A,20B,20A-20,20B-20
If sum(L1)=~3 or sum(L2)=~3 or sum(L3)=~3 or L1(1)+L2(2)+L3(3)=~3 or L1(3)+L2(2)+L3(1)=~3 or L1(1)+L2(1)+L3(1)=~3 or L1(2)+L2(2)+L3(2)=~3 or L1(3)+L2(3)+L3(3)=~3
Then
9->Z:2->W
If W!=0:Then
"PLAYER "+sub("12",W,1)+" WINS"->Str1
ClrHome:Pause Str1
DelVar Str1
ClrHome
Menu("PLAY AGAIN?","YES",1,"NO",2
Lbl 2
ClrHome:Stop
I aded your PvP mode: We use all the real variables, and we use L1 and [A]. 2315 Bytes. That's 27 variables.....
:DCS
Goto AA
Lbl A0
For(C,1,3
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If sum(3={D,E
1->W
If sum(12={D,E
2->W
If H=1
Goto A1
If H=2
Goto A2
Lbl AA
AxesOff
0->O
0->N
Lbl 0
0identity(3->[A]
0->L
Menu("Tic-Tac-Toe AI","Player-Player",3,"Player-Comp",1,"Quit",2
Lbl 2
ClrHome
Stop
Lbl 1
1
Lbl F
Ans+1
Lbl E
Ans+1
Lbl D
Ans+1
Lbl C
Ans+1
Lbl B
Ans+1
Lbl A
Ans->F
L-1->L
Lbl 3
L+1->L
ClrDraw
~33-6G->Xmin
61->Ymax
~1->Ymin
61->Xmax
For(A,0,60,20
Line(A,0,A,60,12
Line(0,A,60,A,12
2->A
2->B
2->I
2->J
0->W
0->R
min(3,B->B
Text(0,0,"O'S TURN
Repeat theta=105
Repeat Ans
getKey
Ans->theta
Then
R+1->R
If G
Then
Else
1->[A](A,B
1->H
Goto A0
Lbl A1
If R<9 and not(W
Then
R+1->R
Text(0,0,"X'S TURN
If L
Then
Pt-On(20I-10,20J-10,12
Repeat theta=105 and not([A](I,J
Repeat Ans
getKey
Ans->theta
min(3,max(1,I+(theta=26)-(theta=24->I
min(3,max(1,J+(theta=25)-(theta=34->J
Else
ClrList L1
4->U
If F>1
Then
For(S,1,3
For(Q,1,3
1+(Q=3->P
3-(Q=1->V
S-(S=2->X
S+(S=2->K
2+(S=2->T
"5(U=Ans->|u
4-S->C:4-Q->Z
[A](S,V
[A](V,S
[A](T,T
[A](2-(S=2),T
2+2[i]->L1(1
Goto 6
Then
For(S,1,3,2
For(Q,1,3,2
S+Q[i]->L1(1+dim(L1
Then
For(S,1,3,2
For(Q,1,3,2
If not([A](S,Q
S+Q[i]->L1(1+dim(L1
Lbl 6
Then
For(S,1,3,2
If not([A](2,S
2+S[i]->L1(1+dim(L1
If not([A](S,2
S+2[i]->L1(1+dim(L1
If not(dim(L1
Then
Repeat not([A](I,J
randInt(1,3->I
randInt(1,3->J
I+J[i]->L1(1
randInt(1,dim(L1->S
imag([i]L1(S->I
imag(L1(S->J
For(D,1,dim(L1
If 5<imag([i]L1(D
Then
imag([i]L1(D))-5->I
imag(L1(D->J
4->[A](I,J
2->H
Goto A0
Lbl A2
Text(0,0,"TIE! "
If W
Then
O+(W=1->O
N+(W=2->N
Text(26+6G,7+7G,O
Text(32+12G,7+7G,N
Pause
Goto 0
» Goto page Previous 1, 2, 3, 4
Page 4 of 4
