Today, I wanted to make a periodic table application. There IS another periodic table program floating around, but it lacked a certain... Niceless of interface. I hope to fix this?
Let me tell you though, finding easily computer-parsable periodic table data can be a hassle. I settled on using GPeriodic to give me their data tables.
Anyways, here's version 1. It's a full table, and it provides some basic properties when you hit ENTER. Also, you can use touch to move around as well as the arrow keys. Here's some pictures:
I hope to add features like a listview and easy numerical export soon.
And finally, here's the source code:
EXPORT periodic_table = {{1,1,"H",1,1,"Hydrogen",1.00794,0.0899_g/1_cm^3,13.81_K,20.28_K,2.08_Å,14.304_J/(1_g*1_K),"1","1s1",2.1,14.1_cm^3/1_mol,13.598,0.1815_W/(1_m*1_K)},{18,1,"He",5,2,"Helium",4.0026,0.1785_g/1_cm^3,0.95_K,4.216_K,"n/a",5.193_J/(1_g*1_K),"n/a","1s2",0,31.8_cm^3/1_mol,24.587,0.152_W/(1_m*1_K)},{1,2,"Li",2,3,"Lithium",6.941,0.53_g/1_cm^3,453.7_K,1615_K,1.55_Å,3.582_J/(1_g*1_K),"1","1s2 2s1",0.98,13.1_cm^3/1_mol,5.392,84.7_W/(1_m*1_K)},{2,2,"Be",3,4,"Beryllium",9.01218,1.85_g/1_cm^3,1560_K,3243_K,1.12_Å,1.825_J/(1_g*1_K),"2","1s2 2s2",1.57,5_cm^3/1_mol,9.322,200_W/(1_m*1_K)},{13,2,"B",6,5,"Boron",10.811,2.34_g/1_cm^3,2365_K,4275_K,0.98_Å,1.026_J/(1_g*1_K),"3","1s2 2s2 p1",2.04,4.6_cm^3/1_mol,8.298,27_W/(1_m*1_K)},{14,2,"C",1,6,"Carbon",12.011,2.26_g/1_cm^3,3825_K,5100_K,0.91_Å,0.709_J/(1_g*1_K),"+/-4, 2","1s2 2s2 p2",2.55,5.3_cm^3/1_mol,11.26,155_W/(1_m*1_K)},{15,2,"N",1,7,"Nitrogen",14.0067,1.251_g/1_cm^3,63.15_K,77.344_K,0.92_Å,1.042_J/(1_g*1_K),"+/-3, 5, 4, 2","1s2 2s2 p3",3.04,17.3_cm^3/1_mol,14.534,0.02598_W/(1_m*1_K)},{16,2,"O",1,8,"Oxygen",15.9994,1.429_g/1_cm^3,54.8_K,90.188_K,0.65_Å,0.92_J/(1_g*1_K),"-2","1s2 2s2 p4",3.44,14_cm^3/1_mol,13.618,0.2674_W/(1_m*1_K)},{17,2,"F",4,9,"Fluorine",18.9984,1.696_g/1_cm^3,53.55_K,85_K,0.57_Å,0.824_J/(1_g*1_K),"-1","1s2 2s2 p5",3.98,17.1_cm^3/1_mol,17.422,0.0279_W/(1_m*1_K)},{18,2,"Ne",5,10,"Neon",20.1797,0.900_g/1_cm^3,24.55_K,27.1_K,0.51_Å,1.03_J/(1_g*1_K),"n/a","1s2 2s2 p6",0,16.9_cm^3/1_mol,21.564,0.0493_W/(1_m*1_K)},{1,3,"Na",2,11,"Sodium",22.98977,0.97_g/1_cm^3,371_K,1156_K,1.9_Å,1.23_J/(1_g*1_K),"1","[Ne] 3s1",0.93,23.7_cm^3/1_mol,5.139,141_W/(1_m*1_K)},{2,3,"Mg",3,12,"Magnesium",24.305,1.74_g/1_cm^3,922_K,1380_K,1.6_Å,1.02_J/(1_g*1_K),"2","[Ne] 3s2",1.31,14_cm^3/1_mol,7.646,156_W/(1_m*1_K)},{13,3,"Al",7,13,"Aluminum",26.98154,2.7_g/1_cm^3,933.5_K,2740_K,1.43_Å,0.9_J/(1_g*1_K),"3","[Ne] 3s2 p1",1.61,10_cm^3/1_mol,5.986,237_W/(1_m*1_K)},{14,3,"Si",6,14,"Silicon",28.0855,2.33_g/1_cm^3,1683_K,2630_K,1.32_Å,0.70_J/(1_g*1_K),"4","[Ne] 3s2 p2",1.9,12.1_cm^3/1_mol,8.151,148_W/(1_m*1_K)},{15,3,"P",1,15,"Phosphorus",30.97376,1.82_g/1_cm^3,317.3_K,553_K,1.28_Å,0.769_J/(1_g*1_K),"+/-3, 5, 4","[Ne] 3s2 p3",2.19,17_cm^3/1_mol,10.486,0.235_W/(1_m*1_K)},{16,3,"S",1,16,"Sulfur",32.066,2.07_g/1_cm^3,392.2_K,717.82_K,1.27_Å,0.71_J/(1_g*1_K),"+/-2, 4, 6","[Ne] 3s2 p4",2.58,15.5_cm^3/1_mol,10.36,0.269_W/(1_m*1_K)},{17,3,"Cl",4,17,"Chlorine",35.4527,3.214_g/1_cm^3,172.17_K,239.18_K,0.97_Å,0.48_J/(1_g*1_K),"+/-1, 3, 5, 7","[Ne] 3s2 p5",3.16,18.7_cm^3/1_mol,12.967,0.0089_W/(1_m*1_K)},{18,3,"Ar",5,18,"Argon",39.948,1.784_g/1_cm^3,83.95_K,87.45_K,0.88_Å,0.52_J/(1_g*1_K),"n/a","[Ne] 3s2 p6",0,24.2_cm^3/1_mol,15.759,0.0177_W/(1_m*1_K)},{1,4,"K",2,19,"Potassium",39.0983,0.86_g/1_cm^3,336.8_K,1033_K,2.35_Å,0.757_J/(1_g*1_K),"1","[Ar] 4s1",0.82,45.3_cm^3/1_mol,4.341,102.5_W/(1_m*1_K)},{2,4,"Ca",3,20,"Calcium",40.078,1.55_g/1_cm^3,1112_K,1757_K,1.97_Å,0.647_J/(1_g*1_K),"2","[Ar] 4s2",1,29.9_cm^3/1_mol,6.113,200_W/(1_m*1_K)},{3,4,"Sc",8,21,"Scandium",44.9559,2.99_g/1_cm^3,1814_K,3109_K,1.62_Å,0.568_J/(1_g*1_K),"3","[Ar] 3d1 4s2",1.36,15_cm^3/1_mol,6.54,15.8_W/(1_m*1_K)},{4,4,"Ti",8,22,"Titanium",47.88,4.54_g/1_cm^3,1945_K,3560_K,1.45_Å,0.523_J/(1_g*1_K),"4, 3","[Ar] 3d2 4s2",1.54,10.6_cm^3/1_mol,6.82,21.9_W/(1_m*1_K)},{5,4,"V",8,23,"Vanadium",50.9415,6.11_g/1_cm^3,2163_K,3650_K,1.34_Å,0.489_J/(1_g*1_K),"5, 4, 3, 2","[Ar] 3d3 4s2",1.63,8.35_cm^3/1_mol,6.74,30.7_W/(1_m*1_K)},{6,4,"Cr",8,24,"Chromium",51.996,7.19_g/1_cm^3,2130_K,2945_K,1.3_Å,0.449_J/(1_g*1_K),"6, 3, 2","[Ar] 3d5 4s1",1.66,7.23_cm^3/1_mol,6.766,93.7_W/(1_m*1_K)},{7,4,"Mn",8,25,"Manganese",54.938,7.44_g/1_cm^3,1518_K,2335_K,1.35_Å,0.48_J/(1_g*1_K),"7, 6, 4, 2, 3","[Ar] 3d5 4s2",1.55,7.39_cm^3/1_mol,7.435,7.82_W/(1_m*1_K)},{8,4,"Fe",8,26,"Iron",55.847,7.874_g/1_cm^3,1808_K,3023_K,1.26_Å,0.449_J/(1_g*1_K),"2, 3","[Ar] 3d6 4s2",1.83,7.1_cm^3/1_mol,7.87,80.2_W/(1_m*1_K)},{9,4,"Co",8,27,"Cobalt",58.9332,8.9_g/1_cm^3,1768_K,3143_K,1.25_Å,0.421_J/(1_g*1_K),"2, 3","[Ar] 3d7 4s2",1.88,6.7_cm^3/1_mol,7.86,100_W/(1_m*1_K)},{10,4,"Ni",8,28,"Nickel",58.6934,8.9_g/1_cm^3,1726_K,3005_K,1.24_Å,0.444_J/(1_g*1_K),"2, 3","[Ar] 3d8 4s2",1.91,6.6_cm^3/1_mol,7.635,90.7_W/(1_m*1_K)},{11,4,"Cu",8,29,"Copper",63.546,8.96_g/1_cm^3,1356.6_K,2840_K,1.28_Å,0.385_J/(1_g*1_K),"2, 1","[Ar] 3d10 4s1",1.9,7.1_cm^3/1_mol,7.726,401_W/(1_m*1_K)},{12,4,"Zn",8,30,"Zinc",65.39,7.13_g/1_cm^3,692.73_K,1180_K,1.38_Å,0.388_J/(1_g*1_K),"2","[Ar] 3d10 4s2",1.65,9.2_cm^3/1_mol,9.394,116_W/(1_m*1_K)},{13,4,"Ga",7,31,"Gallium",69.723,5.91_g/1_cm^3,302.92_K,2478_K,1.41_Å,0.371_J/(1_g*1_K),"3","[Ar] 3d10 4s2 p1",1.81,11.8_cm^3/1_mol,5.999,40.6_W/(1_m*1_K)},{14,4,"Ge",6,32,"Germanium",72.61,5.32_g/1_cm^3,1211.5_K,3107_K,1.37_Å,0.32_J/(1_g*1_K),"4","[Ar] 3d10 4s2 p2",2.01,13.6_cm^3/1_mol,7.899,59.9_W/(1_m*1_K)},{15,4,"As",6,33,"Arsenic",74.9216,5.78_g/1_cm^3,1090_K,876_K,1.39_Å,0.33_J/(1_g*1_K),"+/-3, 5","[Ar] 3d10 4s2 p3",2.18,13.1_cm^3/1_mol,9.81,50_W/(1_m*1_K)},{16,4,"Se",1,34,"Selenium",78.96,4.79_g/1_cm^3,494_K,958_K,1.4_Å,0.32_J/(1_g*1_K),"-2, 4, 6","[Ar] 3d10 4s2 p4",2.55,16.5_cm^3/1_mol,9.752,2.04_W/(1_m*1_K)},{17,4,"Br",4,35,"Bromine",79.904,3.12_g/1_cm^3,265.95_K,331.85_K,1.12_Å,0.226_J/(1_g*1_K),"+/-1, 5","[Ar] 3d10 4s2 p5",2.96,23.5_cm^3/1_mol,11.814,0.122_W/(1_m*1_K)},{18,4,"Kr",5,36,"Krypton",83.8,3.75_g/1_cm^3,116_K,120.85_K,1.03_Å,0.248_J/(1_g*1_K),"n/a","[Ar] 3d10 4s2 p6",0,32.2_cm^3/1_mol,13.999,0.00949_W/(1_m*1_K)},{1,5,"Rb",2,37,"Rubidium",85.4678,1.532_g/1_cm^3,312.63_K,961_K,2.48_Å,0.363_J/(1_g*1_K),"1","[Kr] 5s1",0.82,55.9_cm^3/1_mol,4.177,58.2_W/(1_m*1_K)},{2,5,"Sr",3,38,"Strontium",87.62,2.54_g/1_cm^3,1042_K,1655_K,2.15_Å,0.3_J/(1_g*1_K),"2","[Kr] 5s2",0.95,33.7_cm^3/1_mol,5.695,35.3_W/(1_m*1_K)},{3,5,"Y",8,39,"Yttrium",88.9059,4.47_g/1_cm^3,1795_K,3611_K,1.78_Å,0.3_J/(1_g*1_K),"3","[Kr] 4d1 5s2",1.22,19.8_cm^3/1_mol,6.38,17.2_W/(1_m*1_K)},{4,5,"Zr",8,40,"Zirconium",91.224,6.51_g/1_cm^3,2128_K,4682_K,1.6_Å,0.278_J/(1_g*1_K),"4","[Kr] 4d2 5s2",1.33,14.1_cm^3/1_mol,6.84,22.7_W/(1_m*1_K)},{5,5,"Nb",8,41,"Niobium",92.9064,8.57_g/1_cm^3,2742_K,5015_K,1.46_Å,0.265_J/(1_g*1_K),"5, 3","[Kr] 4d4 5s1",1.6,10.8_cm^3/1_mol,6.88,53.7_W/(1_m*1_K)},{6,5,"Mo",8,42,"Molybdenum",95.94,10.22_g/1_cm^3,2896_K,4912_K,1.39_Å,0.25_J/(1_g*1_K),"6, 5, 4, 3, 2","[Kr] 4d5 5s1",2.16,9.4_cm^3/1_mol,7.099,138_W/(1_m*1_K)},{7,5,"Tc",8,43,"Technetium",98,11.5_g/1_cm^3,2477_K,4538_K,1.36_Å,0.24_J/(1_g*1_K),"7","[Kr] 4d5 5s2",1.9,8.5_cm^3/1_mol,7.28,50.6_W/(1_m*1_K)},{8,5,"Ru",8,44,"Ruthenium",101.07,12.37_g/1_cm^3,2610_K,4425_K,1.34_Å,0.238_J/(1_g*1_K),"2, 3, 4, 6, 8","[Kr] 4d7 5s1",2.2,8.3_cm^3/1_mol,7.37,117_W/(1_m*1_K)},{9,5,"Rh",8,45,"Rhodium",102.9055,12.41_g/1_cm^3,2236_K,3970_K,1.34_Å,0.242_J/(1_g*1_K),"2, 3, 4","[Kr] 4d8 5s1",2.28,8.3_cm^3/1_mol,7.46,150_W/(1_m*1_K)},{10,5,"Pd",8,46,"Palladium",106.42,12_g/1_cm^3,1825_K,3240_K,1.37_Å,0.244_J/(1_g*1_K),"2, 4","[Kr] 4d10",2.2,8.9_cm^3/1_mol,8.34,71.8_W/(1_m*1_K)},{11,5,"Ag",8,47,"Silver",107.868,10.5_g/1_cm^3,1235.08_K,2436_K,1.44_Å,0.232_J/(1_g*1_K),"1","[Kr] 4d10 5s1",1.93,10.3_cm^3/1_mol,7.576,429_W/(1_m*1_K)},{12,5,"Cd",8,48,"Cadmium",112.41,8.65_g/1_cm^3,594.26_K,1040_K,1.71_Å,0.233_J/(1_g*1_K),"2","[Kr] 4d10 5s2",1.69,13.1_cm^3/1_mol,8.993,96.8_W/(1_m*1_K)},{13,5,"In",7,49,"Indium",114.82,7.31_g/1_cm^3,429.78_K,2350_K,1.66_Å,0.233_J/(1_g*1_K),"3","[Kr] 4d10 5s2 p1",1.78,15.7_cm^3/1_mol,5.786,81.6_W/(1_m*1_K)},{14,5,"Sn",7,50,"Tin",118.71,7.31_g/1_cm^3,505.12_K,2876_K,1.62_Å,0.228_J/(1_g*1_K),"4, 2","[Kr] 4d10 5s2 p2",1.96,16.3_cm^3/1_mol,7.344,66.6_W/(1_m*1_K)},{15,5,"Sb",6,51,"Antimony",121.757,6.69_g/1_cm^3,903.91_K,1860_K,1.59_Å,0.207_J/(1_g*1_K),"+/-3, 5","[Kr] 4d10 5s2 p3",2.05,18.4_cm^3/1_mol,8.641,24.3_W/(1_m*1_K)},{16,5,"Te",6,52,"Tellurium",127.6,6.24_g/1_cm^3,722.72_K,1261_K,1.42_Å,0.202_J/(1_g*1_K),"-2, 4, 6","[Kr] 4d10 5s2 p4",2.1,20.5_cm^3/1_mol,9.009,2.35_W/(1_m*1_K)},{17,5,"I",4,53,"Iodine",126.9045,4.93_g/1_cm^3,386.7_K,457.5_K,1.32_Å,0.145_J/(1_g*1_K),"+/-1, 5, 7","[Kr] 4d10 5s2 p5",2.66,25.7_cm^3/1_mol,10.451,0.449_W/(1_m*1_K)},{18,5,"Xe",5,54,"Xenon",131.29,5.9_g/1_cm^3,161.39_K,165.1_K,1.24_Å,0.158_J/(1_g*1_K),"n/a","[Kr] 4d10 5s2 p6",2.6,42.9_cm^3/1_mol,12.13,0.00569_W/(1_m*1_K)},{1,6,"Cs",2,55,"Cesium",132.9054,1.87_g/1_cm^3,301.54_K,944_K,2.67_Å,0.24_J/(1_g*1_K),"1","[Xe] 6s1",0.79,70_cm^3/1_mol,3.894,35.9_W/(1_m*1_K)},{2,6,"Ba",3,56,"Barium",137.33,3.59_g/1_cm^3,1002_K,2078_K,2.22_Å,0.204_J/(1_g*1_K),"2","[Xe] 6s2",0.89,39_cm^3/1_mol,5.212,18.4_W/(1_m*1_K)},{4,9,"La",9,57,"Lanthanum",138.9055,6.15_g/1_cm^3,1191_K,3737_K,1.38_Å,0.19_J/(1_g*1_K),"3","[Xe] 5d1 6s2",1.1,22.5_cm^3/1_mol,5.58,13.5_W/(1_m*1_K)},{5,9,"Ce",9,58,"Cerium",140.12,6.77_g/1_cm^3,1071_K,3715_K,1.81_Å,0.19_J/(1_g*1_K),"3, 4","[Xe] 4f1 5d1 6s2",1.12,21_cm^3/1_mol,5.47,11.4_W/(1_m*1_K)},{6,9,"Pr",9,59,"Praseodymium",140.9077,6.77_g/1_cm^3,1204_K,3785_K,1.82_Å,0.193_J/(1_g*1_K),"3, 4","[Xe] 4f3 6s2",1.13,20.8_cm^3/1_mol,5.42,12.5_W/(1_m*1_K)},{7,9,"Nd",9,60,"Neodymium",144.24,7.01_g/1_cm^3,1294_K,3347_K,1.82_Å,0.19_J/(1_g*1_K),"3","[Xe] 4f4 6s2",1.14,20.6_cm^3/1_mol,5.49,16.5_W/(1_m*1_K)},{8,9,"Pm",9,61,"Promethium",145,7.22_g/1_cm^3,1315_K,3273_K,"n/a","n/a","3","[Xe] 4f5 6s2",1.13,22.4_cm^3/1_mol,5.55,17.9_W/(1_m*1_K)},{9,9,"Sm",9,62,"Samarium",150.36,7.52_g/1_cm^3,1347_K,2067_K,1.81_Å,0.197_J/(1_g*1_K),"3, 2","[Xe] 4f6 6s2",1.17,19.9_cm^3/1_mol,5.63,13.3_W/(1_m*1_K)},{10,9,"Eu",9,63,"Europium",151.965,5.24_g/1_cm^3,1095_K,1800_K,1.99_Å,0.182_J/(1_g*1_K),"3, 2","[Xe] 4f7 6s2",1.2,28.9_cm^3/1_mol,5.67,13.9_W/(1_m*1_K)},{11,9,"Gd",9,64,"Gadolinium",157.25,7.9_g/1_cm^3,1585_K,3545_K,1.8_Å,0.236_J/(1_g*1_K),"3","[Xe] 4f7 5d1 6s2",1.2,19.9_cm^3/1_mol,6.15,10.6_W/(1_m*1_K)},{12,9,"Tb",9,65,"Terbium",158.9253,8.23_g/1_cm^3,1629_K,3500_K,1.8_Å,0.18_J/(1_g*1_K),"3, 4","[Xe] 4f9 6s2",1.1,19.2_cm^3/1_mol,5.86,11.1_W/(1_m*1_K)},{13,9,"Dy",9,66,"Dysprosium",162.5,8.55_g/1_cm^3,1685_K,2840_K,1.8_Å,0.173_J/(1_g*1_K),"3","[Xe] 4f10 6s2",1.22,19_cm^3/1_mol,5.93,10.7_W/(1_m*1_K)},{14,9,"Ho",9,67,"Holmium",164.9303,8.8_g/1_cm^3,1747_K,2968_K,1.79_Å,0.165_J/(1_g*1_K),"3","[Xe] 4f11 6s2",1.23,18.7_cm^3/1_mol,6.02,16.2_W/(1_m*1_K)},{15,9,"Er",9,68,"Erbium",167.26,9.07_g/1_cm^3,1802_K,3140_K,1.78_Å,0.168_J/(1_g*1_K),"3","[Xe] 4f12 6s2",1.24,18.4_cm^3/1_mol,6.101,14.3_W/(1_m*1_K)},{16,9,"Tm",9,69,"Thulium",168.9342,9.32_g/1_cm^3,1818_K,2223_K,1.77_Å,0.16_J/(1_g*1_K),"3, 2","[Xe] 4f13 6s2",1.25,18.1_cm^3/1_mol,6.184,16.8_W/(1_m*1_K)},{17,9,"Yb",9,70,"Ytterbium",173.04,6.97_g/1_cm^3,1092_K,1469_K,1.94_Å,0.155_J/(1_g*1_K),"3, 2","[Xe] 4f14 6s2",1.1,24.8_cm^3/1_mol,6.254,34.9_W/(1_m*1_K)},{18,9,"Lu",9,71,"Lutetium",174.967,9.84_g/1_cm^3,1936_K,3668_K,1.75_Å,0.15_J/(1_g*1_K),"3","[Xe] 4f14 5d1 6s2",1.27,17.8_cm^3/1_mol,5.43,16.4_W/(1_m*1_K)},{4,6,"Hf",8,72,"Hafnium",178.49,13.31_g/1_cm^3,2504_K,4875_K,1.67_Å,0.14_J/(1_g*1_K),"4","[Xe] 4f14 5d2 6s2",1.3,13.6_cm^3/1_mol,6.65,23_W/(1_m*1_K)},{5,6,"Ta",8,73,"Tantalum",180.9479,16.65_g/1_cm^3,3293_K,5730_K,1.49_Å,0.14_J/(1_g*1_K),"5","[Xe] 4f14 5d3 6s2",1.5,10.9_cm^3/1_mol,7.89,57.5_W/(1_m*1_K)},{6,6,"W",8,74,"Tungsten",183.85,19.3_g/1_cm^3,3695_K,5825_K,1.41_Å,0.13_J/(1_g*1_K),"6, 5, 4, 3, 2","[Xe] 4f14 5d4 6s2",2.36,9.53_cm^3/1_mol,7.98,174_W/(1_m*1_K)},{7,6,"Re",8,75,"Rhenium",186.207,21_g/1_cm^3,3455_K,5870_K,1.37_Å,0.137_J/(1_g*1_K),"7, 6, 4, 2, -1","[Xe] 4f14 5d5 6s2",1.9,8.85_cm^3/1_mol,7.88,47.9_W/(1_m*1_K)},{8,6,"Os",8,76,"Osmium",190.2,22.6_g/1_cm^3,3300_K,5300_K,1.35_Å,0.13_J/(1_g*1_K),"2, 3, 4, 6, 8","[Xe] 4f14 5d6 6s2",2.2,8.43_cm^3/1_mol,8.7,87.6_W/(1_m*1_K)},{9,6,"Ir",8,77,"Iridium",192.22,22.6_g/1_cm^3,2720_K,4700_K,1.36_Å,0.13_J/(1_g*1_K),"2, 3, 4, 6","[Xe] 4f14 5d7 6s2",2.2,8.54_cm^3/1_mol,9.1,147_W/(1_m*1_K)},{10,6,"Pt",8,78,"Platinum",195.08,21.45_g/1_cm^3,2042.1_K,4100_K,1.39_Å,0.13_J/(1_g*1_K),"2, 4","[Xe] 4f14 5d9 6s1",2.28,9.1_cm^3/1_mol,9,71.6_W/(1_m*1_K)},{11,6,"Au",8,79,"Gold",196.9665,19.3_g/1_cm^3,1337.58_K,3130_K,1.46_Å,0.128_J/(1_g*1_K),"3, 1","[Xe] 4f14 5d10 6s1",2.54,10.2_cm^3/1_mol,9.225,317_W/(1_m*1_K)},{12,6,"Hg",8,80,"Mercury",200.59,13.55_g/1_cm^3,234.31_K,629.88_K,1.6_Å,0.140_J/(1_g*1_K),"2, 1","[Xe] 4f14 5d10 6s2",2,14.8_cm^3/1_mol,10.437,8.34_W/(1_m*1_K)},{13,6,"Tl",7,81,"Thallium",204.383,11.85_g/1_cm^3,577_K,1746_K,1.71_Å,0.129_J/(1_g*1_K),"3, 1","[Xe] 4f14 5d10 6s2 p1",2.04,17.2_cm^3/1_mol,6.108,46.1_W/(1_m*1_K)},{14,6,"Pb",7,82,"Lead",207.2,11.35_g/1_cm^3,600.65_K,2023_K,1.75_Å,0.129_J/(1_g*1_K),"4, 2","[Xe] 4f14 5d10 6s2 p2",2.33,18.3_cm^3/1_mol,7.416,35.3_W/(1_m*1_K)},{15,6,"Bi",7,83,"Bismuth",208.9804,9.75_g/1_cm^3,544.59_K,1837_K,1.7_Å,0.122_J/(1_g*1_K),"3, 5","[Xe] 4f14 5d10 6s2 p3",2.02,21.3_cm^3/1_mol,7.289,7.87_W/(1_m*1_K)},{16,6,"Po",6,84,"Polonium",209,9.3_g/1_cm^3,527_K,"n/a",1.67_Å,"n/a","4, 2","[Xe] 4f14 5d10 6s2 p4",2,22.7_cm^3/1_mol,8.42,20_W/(1_m*1_K)},{17,6,"At",4,85,"Astatine",210,"n/a",575_K,610_K,1.45_Å,"n/a","+/-1, 3, 5, 7","[Xe] 4f14 5d10 6s2 p5",2.2,"n/a","n/a",1.7_W/(1_m*1_K)},{18,6,"Rn",5,86,"Radon",222,9.73_g/1_cm^3,202_K,211.4_K,1.34_Å,0.094_J/(1_g*1_K),"n/a","[Xe] 4f14 5d10 6s2 p6",0,50.5_cm^3/1_mol,10.748,0.00364_W/(1_m*1_K)},{1,7,"Fr",2,87,"Francium",223,"n/a",300_K,950_K,2.7_Å,"n/a","1","[Rn] 7s1",0.7,"n/a",0,15_W/(1_m*1_K)},{2,7,"Ra",3,88,"Radium",226.0254,5_g/1_cm^3,973_K,1413_K,2.33_Å,0.094_J/(1_g*1_K),"2","[Rn] 7s2",0.89,45.2_cm^3/1_mol,5.279,18.6_W/(1_m*1_K)},{4,10,"Ac",10,89,"Actinium",227,10.07_g/1_cm^3,"n/a",3470_K,1.88_Å,0.12_J/(1_g*1_K),"3","[Rn] 6d1 7s2",1.1,22.5_cm^3/1_mol,5.17,12_W/(1_m*1_K)},{5,10,"Th",10,90,"Thorium",232.0381,11.72_g/1_cm^3,2028_K,5060_K,1.8_Å,0.113_J/(1_g*1_K),"4","[Rn] 6d2 7s2",1.3,19.9_cm^3/1_mol,6.08,54_W/(1_m*1_K)},{6,10,"Pa",10,91,"Protactinium",231.0359,15.4_g/1_cm^3,1845_K,4300_K,1.61_Å,"n/a","5, 4","[Rn] 5f2 6d1 7s2",1.5,15_cm^3/1_mol,5.88,47_W/(1_m*1_K)},{7,10,"U",10,92,"Uranium",238.029,18.95_g/1_cm^3,1408_K,4407_K,1.38_Å,0.12_J/(1_g*1_K),"6, 5, 4, 3","[Rn] 5f3 6d1 7s2",1.38,12.5_cm^3/1_mol,6.05,27.6_W/(1_m*1_K)},{8,10,"Np",10,93,"Neptunium",237.0482,20.2_g/1_cm^3,912_K,4175_K,1.3_Å,"n/a","6, 5, 4, 3","[Rn] 5f4 6d1 7s2",1.36,21.1_cm^3/1_mol,6.19,6.3_W/(1_m*1_K)},{9,10,"Pu",10,94,"Plutonium",244,19.84_g/1_cm^3,913_K,3505_K,1.51_Å,0.13_J/(1_g*1_K),"6, 5, 4, 3","[Rn] 5f6 7s2",1.28,12.32_cm^3/1_mol,6.06,6.74_W/(1_m*1_K)},{10,10,"Am",10,95,"Americium",243,13.7_g/1_cm^3,1449_K,2880_K,1.84_Å,"n/a","6, 5, 4, 3","[Rn] 5f7 7s2",1.3,20.8_cm^3/1_mol,6,10_W/(1_m*1_K)},{11,10,"Cm",10,96,"Curium",247,13.5_g/1_cm^3,1620_K,"n/a","n/a","n/a","3","[Rn] 5f7 6d1 7s2",1.3,18.3_cm^3/1_mol,6.02,10_W/(1_m*1_K)},{12,10,"Bk",10,97,"Berkelium",247,"n/a","n/a","n/a","n/a","n/a","4, 3","[Rn] 5f9 7s2",1.3,"n/a",6.23,10_W/(1_m*1_K)},{13,10,"Cf",10,98,"Californium",251,"n/a",1170_K,"n/a","n/a","n/a","3","[Rn] 5f10 7s2",1.3,"n/a",6.3,10_W/(1_m*1_K)},{14,10,"Es",10,99,"Einsteinium",252,"n/a",1130_K,"n/a","n/a","n/a","n/a","[Rn] 5f11 7s2",1.3,"n/a",6.42,10_W/(1_m*1_K)},{15,10,"Fm",10,100,"Fermium",257,"n/a",1800_K,"n/a","n/a","n/a","n/a","[Rn] 5f12 7s2",1.3,"n/a",6.5,10_W/(1_m*1_K)},{16,10,"Md",10,101,"Mendelevium",258,"n/a",1100_K,"n/a","n/a","n/a","n/a","[Rn] 5f13 7s2",1.3,"n/a",6.58,10_W/(1_m*1_K)},{17,10,"No",10,102,"Nobelium",259,"n/a",1100_K,"n/a","n/a","n/a","n/a","[Rn] 5f14 7s2",1.3,"n/a",6.65,10_W/(1_m*1_K)},{18,10,"Lr",10,103,"Lawrencium",262,"n/a",1900_K,"n/a","n/a","n/a","n/a","[Rn] 5f14 6d1 7s2","n/a","n/a","n/a",10_W/(1_m*1_K)},{4,7,"Rf",8,104,"Rutherfordium",261,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d2 7s2","n/a","n/a","n/a","n/a"},{5,7,"Db",8,105,"Dubnium",262,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d3 7s2","n/a","n/a","n/a","n/a"},{6,7,"Sg",8,106,"Seaborgium",263,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d4 7s2","n/a","n/a","n/a","n/a"},{7,7,"Bh",8,107,"Bohrium",262,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d5 7s2","n/a","n/a","n/a","n/a"},{8,7,"Hs",8,108,"Hassium",265,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d6 7s2","n/a","n/a","n/a","n/a"},{9,7,"Mt",8,109,"Meitnerium",266,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d7 7s2","n/a","n/a","n/a","n/a"},{10,7,"Uun",8,110,"ununnilium",269,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d8 7s2","n/a","n/a","n/a","n/a"},{11,7,"Uuu",8,111,"unununium",272,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d9 7s2","n/a","n/a","n/a","n/a"},{12,7,"Uub",8,112,"ununbium",277,"n/a","n/a","n/a","n/a","n/a","n/a","[Rn] 5f14 6d10 7s2","n/a","n/a","n/a","n/a"},{13,7,"Uut",7,113,"Ununtrium","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a"},{14,7,"Uuq",7,114,"Ununquadium","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a"},{15,7,"Uup",7,115,"Ununpentium","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a"},{16,7,"Uuh",7,116,"Ununhexium","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a"},{17,7,"Uus",4,117,"Ununseptium","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a"},{18,7,"Uuo",5,118,"Ununoctium","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a","n/a"}};
ext_disp_used = CONCAT(4,MAKELIST(X,X,7,18));
ext_disp_names = {"Group", "Atomic Weight", "Density", "Melting Point", "Boiling Point", "Atomic Radius", "Specific Heat", "Oxidation States", "Electron Configuration", "Electronegativity", "Atomic Volume", "Ionization Potential", "Thermal Conductivity"};
cell_size = 16;
clear_color = RGB(0,0,0,255);
border_color = RGB(0,0,0);
group_colors = {RGB(0,255,0),RGB(255,255,0),RGB(256,128,0),RGB(0,255,255),RGB(0,128,255),RGB(128,255,128),RGB(128,255,0),RGB(128,128,0),RGB(128,128,128),RGB(64,64,64)};
group_names = {"Nonmetal", "Alkali Metal", "Alkaline Earth Metal", "Halogen", "Noble Gas", "Metalliod", "Post-Transition Metal", "Transition Metal", "Lanthanoid", "Actinoid"};
selX;
selY;
RENDER_CELL(cell)
BEGIN
   RECT_P(G1, cell[1]*cell_size, cell[2]*cell_size, (cell[1]+1)*cell_size-1, (cell[2]+1)*cell_size-1, border_color, group_colors[cell[4]]);
   TEXTOUT_P(cell[3],G1,cell[1]*cell_size+2, cell[2]*cell_size+4, 1, border_color);
   IF selX==cell[1] AND selY==cell[2] THEN
      INVERT_P(G1, cell[1]*cell_size, cell[2]*cell_size, (cell[1]+1)*cell_size-1, (cell[2]+1)*cell_size-1);
      TEXTOUT_P(cell[5] + " - " + cell[6], G1, 20, 200);
   END;
END;
DISPLAY_LINE(cell,I)
BEGIN
   IF I==1 THEN
      TEXTOUT_P(ext_disp_names[I]+":",G1,20,15+16*I);
      TEXTOUT_P(group_names[cell[ext_disp_used[I]]],G1,70,15+16*I,0,group_colors[cell[ext_disp_used[I]]]);
      RETURN;
   END;
   TEXTOUT_P(ext_disp_names[I]+": "+cell[ext_disp_used[I]],G1,20,15+16*I);
END;
RENDER_TABLE()
BEGIN
   DIMGROB_P(G1,320,240);
   RECT_P(G1);
   MAKELIST(RENDER_CELL(periodic_table[X]),X,1,SIZE(periodic_table));
END;
CHEM_DATA_MENU(cell)
BEGIN
   LOCAL I = cell[5];
   WHILE 1 DO
      RECT(G1);
      TEXTOUT_P(I+" - "+cell[6]+" ("+cell[3]+")",G1,10,0,5);
      MAKELIST(DISPLAY_LINE(cell,X),X,1,SIZE(ext_disp_used));
      BLIT(G1);
      LOCAL input2 = WAIT(0);
      CASE
         IF input2==4 THEN //escape
            BREAK;
         END
         IF input2==7 THEN //left
            I:=I-1;
            IF I==0 THEN I:=118; END;
            cell := periodic_table[I];
         END
         IF input2==8 THEN //right
            I:=I+1;
            IF I==119 THEN I:=1; END;
         END
      END;
   END;
END;
EXPORT PERIODIC()
BEGIN
   selX:=0; selY:=0;
   WHILE 1 DO
      RENDER_TABLE();
      BLIT(G1);
      DRAWMENU("About");
      //get input
      LOCAL input = WAIT(-1);
      IF TYPE(input)==6 THEN //mouse input
         IF input[1]==#3 THEN
            IF input[2]<(320/6) AND input[3]>220 THEN
                  MSGBOX("HP Prime Periodic Table. Written by iconmaster.
Data taken from GPeriodic and jquery-pte.
www.github.com/iconmaster5326");
            END;
         END;
         IF input[1]==#0 THEN
            IF input[3]>200 THEN
            ELSE
               LOCAL mx = FLOOR(input[2]/cell_size);
               LOCAL my = FLOOR(input[3]/cell_size);
               LOCAL I;
               FOR I FROM 1 TO SIZE(periodic_table) DO
                  LOCAL cell = periodic_table[I];
                  IF mx==cell[1] AND my==cell[2] THEN
                     selX := mx;
                     selY := my;
                     BREAK;
                  END;
               END;
            END;
         END;
      ELSE //key input
         CASE
            IF input==30 THEN //enter
               LOCAL I;
               LOCAL cell;
                     BREAK;
                  END;
               END;
               CHEM_DATA_MENU(cell);
            END
            IF input==4 THEN //escape
               BREAK;
            END
            IF input==7 THEN //left
               IF selX==0 THEN
                  selX := 1;
                  selY := 1;
               ELSE
                  selX := selX - 1;
                  CASE
                     IF selY==1 AND selX==17 THEN
                        selX := 1;
                     END
                     IF (selY==2 OR selY==3) AND selX==12 THEN
                        selX := 2;
                     END
                     IF (selY==6 OR selY==7) AND selX==3 THEN
                        selX := 2;
                     END
                     IF (selY==9 OR selY==10) AND selX==3 THEN
                        selX := 18;
                     END
                     IF selX==0 THEN
                        selX := 18;
                     END
                  END;
               END;
            END
            IF input==8 THEN //right
               IF selX==0 THEN
                  selX := 1;
                  selY := 1;
               ELSE
                  selX := selX + 1;
                  CASE
                     IF selY==1 AND selX==2 THEN
                        selX := 18;
                     END
                     IF (selY==2 OR selY==3) AND selX==3 THEN
                        selX := 13;
                     END
                        selX := 4;
                     END
                     IF (selY==9 OR selY==10) AND selX==19 THEN
                        selX := 4;
                     END
                     IF selX==19 THEN
                        selX := 1;
                     END
                  END;
               END;
            END
            IF input==2 THEN //up
               IF selX==0 THEN
                  selX := 1;
                  selY := 1;
               ELSE
                  selY := selY - 1;
                  CASE
                     IF selX==1 AND selY==0 THEN
                        selY := 7;
                     END
                     IF selX==2 AND selY==1 THEN
                        selY := 7;
                     END
                     IF selX==3 AND selY==3 THEN
                        selY := 5;
                     END
                     IF (selX>=4 AND selX<=12) AND selY==3 THEN
                        selY := 10;
                     END
                     IF (selX>=13 AND selX<=17) AND selY==1 THEN
                        selY := 10;
                     END
                     IF selX==18 AND selY==0 THEN
                        selY := 10;
                     END
                     IF selX>=4 AND selY==8 THEN
                        selY := 7;
                     END
                  END;
               END;
            END
            IF input==12 THEN //down
               IF selX==0 THEN
                  selX := 1;
                  selY := 1;
               ELSE
                  selY := selY + 1;
                  CASE
                     IF selX==1 AND selY==8 THEN
                        selY := 1;
                     END
                     IF selX==2 AND selY==8 THEN
                        selY := 2;
                     END
                     IF selX==3 AND selY==6 THEN
                        selY := 4;
                     END
                     IF (selX>=4 AND selX<=12) AND selY==11 THEN
                        selY := 4;
                     END
                     IF (selX>=13 AND selX<=17) AND selY==11 THEN
                        selY := 2;
                     END
                     IF selX==18 AND selY==11 THEN
                        selY := 1;
                     END
                        selY := 9;
                     END
                  END;
               END;
            END
         END;
      END;
   END;
END;
EDIT: I made an update that uses the power of a second database, jquery-pte, to provide you with more chemical data. Cheers!
EDIT 2: Bugfixes, and a new feature: Try pressing left and right in the dataset view.
Oooo, I love me a good periodic table app. Given the screen space available, I'd recommend putting common info on the table screen.
Mainly my recommendations would basically end up requesting a clone of Yapt for the m68k calcs (on TI calc), which has a very good set of features and data.
Yes, I'm for sure planning on a lot of the things in YAPT. My biggest issue is that I've discovered that the data set I used isn't complete, or even accurate in some places. I chose it because it was easy to convert to an HPPL table, but it looks like I'm going to have to look for something better...
Wow, that looks really spiffy indeed! The clean interface reminds me of Merthsoft's Periodic Table for the Prizm, although I think I prefer the colorful table with that black background. I second AHelper's suggestions, and I'm sorry that you're having trouble finding a reliable dataset. Perhaps some of the existing periodic tables (TI's, Merth's, etc) can help?
This looks amazing, and I hope you add it to the Cemetech archives when you get it in a closer to final form Very Happy
And thanks for the source code! I keep meaning to fire up my Prime to learn more coding for it, but distractions :<
Keep up the fantastic work!
I didn't think it would be so much of a hassle, but everyone seems to have only slightly incomplete datasets available. I think I'm good now on data, luckily.
Yes, the dark background IS nice looking, but you'll have to switch you Prime's Color Theme to see it Razz
This is a really nice application. Great program!
