Cross Posted From
Http://www.theorangeblock.org :
blitz_9100 wrote:
A little awhile ago i was messing around in the console and found something very interesting to test.Here are the results of the test i was doing.Maybe we could do some additions and make this vehicles customizable with blocks
Maybe until ldraw is fully implemented i could make a script to build like that
Congratulations, you have mounted a brick to a vehicle. Good luck putting bricks anywhere other than in one of the seats
I was thinking you could add mountpoints in different places allowing different mounts
I believe there is a hard engine limit of 32 mount-points.
Meh.Nvm seems to be picky about object facing
RTB did this same thing almost 10 years ago...
Seriously man, 10 years? Vanilla came out around 2005 - 2006
That's how RTB's build-on vehicle worked? I thought it was a bit more complicated than this.
You're right, it was probably more like 4 years, it just seems so much longer than that...
When someone says there is 'over 9000' x or 'a million' y, I do hope you don't believe them.
