Jimmg wrote:
Well you could always just put it in the SVN when it was the final version.
This is true. Want to send me a model? I'll put it in the map, and then, since I think this will be the last modification for a while, burn the lighting.
So Elfprince13, I mentioned that I was seeing a significant performance hit with only on the order of dozens of bricks; I think I found the problem:
Note the massive pile of shadows, probably cast by (a) the six underbed lights (b) the one overbed lamp (c) the many emitters inside the cabinet for the stars. Can I make all this stuff not actually cast shadows, for the sake of my (and others) framerates?
Ooh. In particular, the underbed lights are gonna be problematic. I think there are some datablock values that affect shadowing.
Detail Brushes don't cast shadows.
Right, but we're talking about DTSes casting shadows. We did some experimenting last night, and I made only the sun cast shadows, but it's still ugly with the sun-cast shadows, so I may try some experiments with either turn off DTS shadows from the sun, or no shadow-casting from bricks at all.
Check out bricks.cs.
elfprince13 wrote:
Check out bricks.cs. Nice, so I assume I could do something on a brick-by-brick basis in Brick::OnUse or BrickItem::OnUse, to avoid having to modify every brick datablock?
All the brick datablocks inherit their properties except for scale and the path to the model from a single parent datablock.
I've give you a hint: It begins with "2" and ends with "2"...
Actually, I think it starts with "static" and ends with "2x2"
Well they're all statics...
