This is an idea that's been floating around for a while, and one which I decided to make happen in the last 3 hours.
*Note: I am running on a netbook with integrated intel graphics, so visual quality would be much better on your own machine with a $10 GPU.
http://www.mediafire.com/?zmmwm0dynya
EDIT- map updated, link changed
😁 nice! I like this map a lot.
I don't suppose you could add support for higher resolution terrain blocks, like a new terrain block object that's 1024 units instead of 256 and uses a square size of 2 instead of 8?
https://tbg.bountysource.com/development/feature_request
Thanks for stealing my map idea....
YOUR idea was to do every country individually, MY idea was to copy the world map from GMod...
the spawn point seems a bit strange?
Looks like a fun map, too bad it can't be scaled such that it takes a few hours to fly from America to Europe in the map. 😁
this.
actually it almost can, it just would look crappy because of the low terrain block resolution...
" but why not do the whole world? (one country at a time)"
"that could get tedious... a whole-world map could be fun though, even if the scale would be waaaaaaaaaay off..."
Seeing as though you are a map designed, I would take suggestions from you rather my own inexperienced knowledge.
cool! (and its been awhile since i was here so i'm behind)
but i like this place!
Map updated, link changed:
This is the final version you can put in the core(or the official set of mods, since it's already packaged for that).
Maybe I'll do a DShiznit's map pack mod to combine them into a single archive.
