So, the first step is that you need an SVN client.
This is actually a SVN management system type thing, and we will be using TortoiseSVN.
1) So, first, get TortoiseSVN from http://tortoisesvn.net/. Its about 20mb.
2) Second, install it. It's relatively straightforward. Follow the prompts.
3) Third, create a new folder somewhere.
4) Fourth, open this folder, and right click. Hit RepoBrowser.
5) Fifth, put https://svn.bountysource.com/tbg/trunk/ in it.
6) Sixth, export
7) Seventh, wait for the download
Don't forget to update regularly. Thanks, Elrune. Stickied.
cool! I remember using tortoise for getting the stuff for dolphin to work properly.
but later found out my computer graphics cannot handle dolphin...O_o
I'll probably figure this out, but is there a simple way to update, only downloading files that have been added or changed?
Right click and hit "SVN Update"...
Why do we have to download it like this?
Also TortoiseSVN won't work for me.
because it hasn't been released yet. This is a dev build we've all been playing...
I have no "update SVN" option, and exporting to that folder again re-downloaded everything.
I have this problem too.
What option do you have when you right click?
Same options as any other folder I right-click.
Well then you didn't install TortoiseSVN properly.
It has the TortoiseSVN options. Just no Update, Commit, or anything else that would apply to an SVN folder.
So then you didn't tell me what options you had. Please, tell me EXACTLY what options you have, one by one, no matter how unimportant they seem. Also please tell me what you have in the TortoiseSVN menu.
Code: SVN Checkout...
TortoiseSVN
- Repo-Browser
- Export...
- Create repository here...
- Import...
- Settings
- Help
- About
Ah, that's the problem, did you checkout the first time, or just drag+drop all the files over from the repo browser?
I blame elrune for saying "Export"
Is this normal:
Error REPORT of '/tbg/!svn/vcc/default': Could not read response body: Secure
Error connection truncated (https://svn.bountysource.com)
