Can I apply to the BASIC elite?
You can apply to be an apprentice.
Oh, whoops, never mind. The link is dead...
It used to be:
http://cemetech.designerz-core.com/projects/basicelite/application.html
It used to be:
Yeah, now it's http://cemetech.net/projects/basicelite/application.html
well, actually apply for Basic Elite. You are then evaluated on your greatness or potential. If you are worthy, you become a member, if you show potential, apprenticeship, or, you can be denied also if you are not found worthy of either positions.
I have to say, from what Ive seen of his coding he shows a lot of potential, has a quick mind, and understands a fair bit about the language, but needs to learn a few more optimization tricks and get a slightly better command over some of the more advanced function before full membership. Id like to recommend him for apprenticeship.
Speaking of which... I was so close to BE membership with the last contest >.< hopefully it will work this time (I had better go optimize it soon, which in my case will end up being the day before =P)
I'm not close to finishing my entry, but if Kerm doesn't feel like he has to finish DCS on time, I don't have to finish my entry.
don't think that way. I want to see these entries. Also, I will make a note to Kerm if I see something that is really good in code. Some of points of these contests is to promote better coding.
calc84maniac wrote:
Mine isn't that good anyway. I've given up.
Unless you're as bad as me, it's good enough to try.
And yes, I am that bad with TIBasic. You notice I showed up here in the first place 'cause of Tablet 83.
Harq wrote:
Get the entries from River and learn from them.
Half the reason I'm bad is I don't want to learn .
- Kllrnohj
- ☢ PH34R |\/|3 (Posts: 8196)
- 21 Dec 2006 10:38:01 pm
- Last edited by Kllrnohj on 21 Dec 2006 11:08:06 pm; edited 1 time in total
from cemetech_users import rivereye
while "python" not in rivereye.languages:
print "Learn python already, rivereye!"
