I have currently implemented 2 different methods for a binary search tree in pure TI-Basic, both a fairly speedy, and far speedier than having to traverse a list in order.
the first one can hold any real values, but is limited to 98 entries.
the second can hold as many entries as will fit in memory (6 bytes/entry) but can only hold values from 0 to 1368 (this limit is expandable to t2-1, where t is the number of legal tokens in TI-Basic, at the cost of the space available for the tree).
/me glances right and left.
No sample code?
Good for you, that's quite impressive.
Kermizzle wrote:
No sample code?
fear not, I shall arrive home rather shortly.
thanks, 3xN matrices make good trees rather surprisingly as do Strings and lists.
[edit]
OH SNAP!!!!!!!! I had an idea for a third implementation using lists. that would be sortof a middle ground between the 2.
/me is still vainly waiting for the source code to this impressive feat to arrive, but alas, I fear est absum.
whoops forgot to post that, Ill finish up my lists version and post all 3.
Eeexcellent. As a matter of fact, I bet this might help some of the people working on 3D stuff for the contest.
you mean for drawing front-to-back for doing solid rendering?
'xactly; much better, certainly, than slow manual flipping through the poly array.
just released it to these very archives.
http://www.cemetech.net/programs/archives.php?mode=file&path=/83plus/basic/graphics/BST.zip
along with a mergesort algorithm, D-Term, and some other helpful stuff.
BASIC Code wrote:
:If θ=1337.1337
:Then
:¦ If not(A
:¦ 2→A
:¦ dim([A]
:¦ If 1=Ans(1
:¦ Then
:¦ ¦ 0
:¦ ¦ Return
:¦ End
:¦ If I=[A](A,1
:¦ Then
:¦ ¦ 1
:¦ ¦ Else
:¦ ¦ If I<[A](A,1
:¦ ¦ Then
:¦ ¦ ¦ [A](A,2→A
:¦ ¦ ¦ Else
:¦ ¦ ¦ [A](A,3→A
:¦ ¦ End
:¦ ¦ If A
:¦ ¦ Then
:¦ ¦ ¦ prgmBST
:¦ ¦ ¦ Else
:¦ ¦ ¦ 0
:¦ ¦ End
:¦ End
:¦ Return
:End
:If θ=42.1337
:Then
:¦ dim([A]
:¦ If 1=Ans(1
:¦ Then
:¦ ¦ 2,3→dim([A]
:¦ ¦ I→[A](2,1
:¦ ¦ Else
:¦ ¦ Ans(1→L
:¦ ¦ L+1→L
:¦ ¦ L,3→dim([A]
:¦ ¦ I→[A](L,1
:¦ ¦ 2→A
:¦ ¦ [A](A,1
:¦ ¦ While ([A](A,2) and I≤Ans) or ([A](A,3) and I>Ans
:¦ ¦ ¦ If I≤[A](A,1
:¦ ¦ ¦ Then
:¦ ¦ ¦ ¦ [A](A,2→A
:¦ ¦ ¦ ¦ Else
:¦ ¦ ¦ ¦ [A](A,3→A
:¦ ¦ ¦ End
:¦ ¦ ¦ [A](A,1
:¦ ¦ End
:¦ ¦ If I≤Ans
:¦ ¦ Then
:¦ ¦ ¦ L→[A](A,2
:¦ ¦ ¦ Else
:¦ ¦ ¦ L→[A](A,3
:¦ ¦ End
:¦ End
:¦ Return
:End
:If θ=1337.42
:Then
:¦ If not(A
:¦ Then
:¦ ¦ 2→A
:¦ ¦ A→L
1
:¦ ¦ 1→I
:¦ ¦ 0→dim(L
2
:¦ End
:¦ If [A](A,2
:¦ Then
:¦ ¦ [A](A,2→A
:¦ ¦ I+1→I
:¦ ¦ A→L
1(I
:¦ ¦ prgmBST
:¦ ¦ I-1→I
:¦ ¦ L
1(I→A
:¦ End
:¦ [A](A,1→L
2(1+dim(L
2
:¦ If [A](A,3
:¦ Then
:¦ ¦ [A](A,3→A
:¦ ¦ I+1→I
:¦ ¦ A→L
1(I
:¦ ¦ prgmBST
:¦ ¦ I-1→I
:¦ ¦ L
1(I→A
:¦ End
:¦ Return
:End
:1,3→dim([A]
:Fill 0,[A]
Generated by
SourceCoder, © 2005
Cemetech
Holy cow, dude, your icons look amazingly pwny! Props for that.
thanks
Hate to be a nuisance,a but what is a binary tree (Is it similar to a minimax tree or whatever those move arrays are called?)?
http://en.wikipedia.org/wiki/Binary_Search_Tree (this lends itself quite nicely to a treesort and searching for values)
and before anyone asks what mergesort is:
http://en.wikipedia.org/wiki/Mergesort
