Just some possible suggestions for ya to implement:
1) A title screen that shows up for a couple seconds, with version number, etc, maybe just bring the about screen up for the few seconds??
2) (from foamy3) Multilingual SEs. I am thinking you will need to add a section in DCS to "look" for SEs, and check mark the ones that the user wants active?? Also, all text is set to look at the default, until the SE is activated (Maybe when DCS first sees the SE, it Auto engages it, and you can turn it on/off from the menu)
3) You need to add the version/beta number somewhere in the about screen, since I have 5 copies of DCS betas on my machine...
Would also make it easier to debug for later if you knew what version they had.
