A little while back I wrote some VAT sorting routines, so right now I'm doing a little work as packaging that as a SE and debugging. I've got a bubble sort and a heap sort, but the heap is veery strange and probably extremely buggy. Here's the source for the bubble, if you feel like trying to find bugs.
It's ZDS syntax, if you're wondering.
;=================================Bubble Sort==================================
bubble_start:
ld hl,(ProgPtr)
res 0,(IY+Asm_Flags2)
bubble_start1:
push hl
ld de,OP1
call sort_getname
call getnext
jr z,bubble_next
push hl
ld de,OP2
call sort_getname
ld hl,OP1
ld de,OP2
call sort_comparename
pop hl
jr nc,bubble_next
bubble_swap:
pop de
push de
call vatswap
set 0,(IY+Asm_Flags2)
ld a,'.'
B_CALL PutC
bubble_next:
pop hl
call getnext
jr nz,bubble_start1
bit 0,(IY+Asm_Flags2)
jr nz,bubble_start
ret
sort_getname:
;Input:
;hl-> first byte of VAT entry
;Output:
;name saved to (de)
;kills DE, B, and A
push hl
ld de,-6
add hl,de
ld b,(hl)
dec hl
sort_getname1:
ld a,(hl)
ld (de),a
inc de
dec hl
djnz sort_getname1
pop hl
ret
sort_comparename:
;Input:
;HL-> name 1 (printed forwards)
;DE-> name 2
;Output:
;Carry if name 1 higher alphabetically, otherwise NC
;Kills HL, DE, B, A
ld a,(de)
cp (hl)
jr nc, sort_comparename_name2big
inc hl
inc de
jr sort_comparename
sort_comparename_name2big:
ccf
ret
