Basically what I want to do is use a microcontroller (RP2040) to serve a web interface whose backend controls a couple GPIO pins which are then connected to a TI-84+ SE's 2.5mm link port.
I have to ask, is there any real documentation out there on how exactly you're supposed to serially read and write data from the TI-84+ SE's link port? Does it use a standardized protocol such as UART? (Highly unlikely from what I've seen of TI so far)
Going a step further: is it possible, at all, for the TI-84+ SE to take keypad input via the link port? So for example, if I click a button on my microcontroller-hosted web page, then the backend of the webserver could send a specific set of signals down the link line and the TI-84+SE could somehow be "tricked" into thinking that a specific key was pressed. I am aware that this calculator has no concept of multithreading or concurrency, but what I basically want to do is build a product that hosts a webpage to a PC, that the user can interact with to remotely control the calculator connected to the product with a 2.5mm link cable. Perhaps by emulating a keyboard, like the official TI-Keyboard but simulated.
The physical layer of the link port is kind of similar to I2C, but without a clock. Both lines (the tip and ring of the 2.5mm jack) have a pull-up to Vcc, and to send a 0 bit you pull the tip low then wait for the ring to be pulled down as an achnowledgement from the other device; then release the lines and wait for both to go high before doing the next bit. To send a 1 bit instead of 0, pull the ring down and wait for the partner to acknowledge on the tip. Bytes are sent least-significant bit first.
The ArTICL library is a handy reference; in particular, check out the TICL class which seems fairly clear. I suspect there's actual documentation of the physical layer somewhere, but it was easier for me to figure it out from the ArTICL code than figure out where that is.
Fortunately for what you want to do with regard to sending keypresses, it's supported by default by the calculator OS with a set of linking-related features that are collectively referred to as "silent linking" (in contrast with older calculators where you needed to go into a menu to get into receive mode, the 83+ family is always listening for incoming commands when in the OS). All you do is send two bytes 23 87 as a command, followed by a two-byte keycode (transmitted LSB-first). You'll get back two acknowledgement packets as detailed in the linkguide's Packet Formats page.
There's even a ArTICL example that uses this feature which I expect can get you started.
It's convenient that Merth keeps a copy of the linkguide online for us to link to, but that's simply a copy of the linkguide package from ticalc.org so if you want to see everything documented there it might be easier to download a copy.
Thank you so much @Tari for the resources; given the realtime nature of the Internet and seeing how data can occasionally disappear without a trace, I now host my own copy of the linkguide at https://gitea.hdg57.eu.org/hackerdagreat57/ticalc/raw/branch/main/linkguide/index.html. Plus a few other things at https://gitea.hdg57.eu.org/hackerdagreat57/ticalc, including a version of ti83plus.inc by Brandon Wilson. Just in case, you never know when a copy might be handy.
Anyway, the things you pointed me to will immensely help with this project. The linkguide is so expansive that I also learned it is possible to passively capture screenshots of the TI-84+SE's monochrome screen after each keypress according to /linkguide/ti83+/screenshot.html!
In fact, there's an ArTICL demo of that feature as well: https://github.com/KermMartian/ArTICL/blob/master/examples/Screenshot/Screenshot.ino
Let us know if you have any additional questions as you pursue the project.
FTR, the linkguide has been at https://github.com/debrouxl/tilp-linkguide -> https://debrouxl.github.io/tilp-linkguide/ for a long time Smile
But as hinted in the description or the tilp-linkguide repo, the implementation, namely https://github.com/debrouxl/tilibs , is both more complete and more correct than the linkguide, which I basically left alone since I became the libti*/gfm/tilp stack maintainer... nearly 15 years ago.
I can believe the "more complete" part for sure. There are a few holes in the link guide itself, like the real number format for the TI-89 Titanium. And there was one section in the TI-83+ link protocol page that just had "sdf" under it LOL, I forgot which section exactly it was though.
I may try looking through the tilibs source code if I deem it necessary, thanks! (Mirrored it to my server as well)
Well, you won't find that in libti* either: these libraries deal with the file envelopes, the link cables, and the protocols, but the content they read/write/transport isn't a concern to them Smile
The generic TI-68k expression format is:
2 bytes: size of variable data, i.e. excluding the size bytes;
... expression data ...
1 (usually) or 2 bytes (for several types): EStack tag, see https://debrouxl.github.io/gcc4ti/estack.html#Tags .
For real variables, from memory, it should be [00 0A] [2 bytes exponent + 7 bytes mantissa, SMAP II BCD format] [1 byte: FLOAT_TAG=0x23]. On the computer side, that's wrapped in a 80+-byte header (variable name, variable type, etc.) and a 2-byte footer (checksum).
Ah, I see. Thanks.
