mets11rap wrote:
2: Website memory storage. Sometimes, the site keeps the files on the ROM, and sometimes, it doesn't. I'd really like to see this improved because I have to have DoorsCSE in my downloads folder taking up unnecessary space on my PC in case for some reason it's not saved.
In regards to this... jsTIfied utilizes DOM storage in the browser to avoid any legal issues with keeping the ROM on our server. Since files like DoorCSE are uploaded to the ROM, not to the server, we can't keep the state of the calculator if you reupload the ROM.
Since the DOM Storage is part of the browser cache there's really nothing we can do. The cache may also be purged when the computer is restarted, or by quitting the browser. :/
I got a problem with jsTIfied:
Every time I pause the calculator (with a breakpoint or by stepping over a call/bcall), the screen doesn't update to what it should be. This only happens after the first pause, probably.
I am calling _PutS but stepping over it in the debugger because I currently don't care what that BCALL is doing. After the call finished, the screen does not get updated but instead, it darkens. If this happens multiple times, the screen goes completely black.
This also applies to the screenshot feature.
I am running jsTIfied on Waterfox on Ubuntu 16.04. The calculator is an 84+ with OS version 2.55 MP. I also tested it on Firefox and it happens too.
PS: I tested it with TI's flash debugger and it works there.
When emulating a TI-83 Plus today, I discovered that the . key on the numeric keypad doesn't respond. I can type numbers on both the number keypad and top row keys, and the period key in the home section works, but the period key on the numpad does not. That's a bit inconvenient. Smile
Also, the appearance of the Toggle Fast Speed toolbar button looks reversed from its presumed operation. When the lightning bolt is dark, the calculator runs at normal speed, but when it's light with a slash through it, the calculator runs faster. Logically I'd expect the appearance to be the other way around, with the (slower) normal speed being represented by the dimmed lightning bolt with a slash through it.
Thanks for reminding me about this. This is due to how jsTIfied computes the timing of when to refresh the screen, and is certainly fixable.
Boo, that's annoying. I'll look into this.
Yeah, that's always been a complicated issue: I've gotten people complaining about both ways around. I'll try the opposite.
Hmm, maybe it would be less confusing if the on/off icons were more distinct from each other. Like, say a CPU (or something representing speed) and have the lightning bolt appear when it's not throttled and have no lightning bolt at all when at normal speed? Any usability experts around here? Smile
Using this today on the latest stable Opera and the latest stable Chrome on Windows 10, the keys are occasionally "sticking" with both silver edition and color TI-84 roms. The key gets highlighted red, then stays highlighted red after letting go, and won't let me enter anything else until clicking it again. If the key that sticks is something like the up arrow, then it continuously scrolls upward until clicking again.
I tested with MS Edge as well, and it happened once but much less often (though I did manage to crash my color rom at some point on Edge, but that may be another report if it happens again). I do not have Firefox currently installed to test.
It appears my sticky keys issue may at least partially relate to the way I use the trackpad on my dell laptop, where I tend to use the tap-to-click rather than the full press-click. If I press click or use the laptop's touchscreen, the problem appears to go away.
I assume the trackpad isn't always sending the mouseUp signal correctly or is sending it more quickly than the javascript allows. I don't get this problem other places that I've noticed, but maybe that's just been my good luck so far.
jsTified is bugging out the TI 84 Plus's screen when I open it through the app-shortcut. It's seems to stretch out the text and is only fixed by resetting the emulator. I've got an iPhone SE running iOS 11.3 . Here's a gif of what I'm seeing:
[disjax] [LogicalJoe] wrote:
I've been having that problem too.
1. See https://cemetech.net/forum/viewtopic.php?p=305914#305914
2. The JPEG-encoded ROM "image" references https://ceme.tech/emu but that redirects to a 404.
3. When pausing jsTIfied, pressing the 'Step Over' button causes the screen to dim. The same thing also happens when I 'Continue' to another breakpoint. This goes away whenever it runs for long enough. It makes it hard to debug drawing routines, where I have to call an LCD delay routine.
#1 is still broken. I was able to replicate it in Firefox on Linux, and the issue still persisted when disabling my adblocker and Enhanced Tracking Protection.
Video: https://usercontent.irccloud-cdn.com/file/lrmfmW55/cemetech.mp4 Logs: https://www.irccloud.com/pastebin/bCnZLNbM/console.log
I think that was because you were on cemetech.net rather than www.cemetech.net, and in the last few days I made a change to automatically redirect you to www- so at the time you've posted this it should be fine, but apparently (looking at the clock in your video) you recorded that nearly a week ago. I don't know what it is that makes jstified in particular sensitive to the domain it's served from, but that shouldn't be a problem anymore.
On Firefox 133.0.3, the jsTIfied screen stays solid black (not off) even when a ROM is loaded and the calculator is running. I can blindly create variables, and they show up in the variable list. Perhaps this is a problem with manipulating canvases?
  1. The contrast for the emulated TI-83 Plus is way too low.
  2. The screen dims whenever the following occur when stepping through instructions
    • You press Play or Continue when the current instruction is a breakpoint
    • You press Step Over
  3. You cannot transfer a program from SourceCoder3, even if it is from the currently opened project.
https://usercontent.irccloud-cdn.com/file/8tkNzHXK/Screen%20recording%202025-02-11%207.26.35%20PM.webm
https://usercontent.irccloud-cdn.com/file/yPDX421Z/Screen%20recording%202025-02-13%206.31.14%20PM.webm
I tested this, and it worked fine - in your video, I didn't see you ever actually check the virtual calculator for the program. I also failed to replicate that "From Emulator" didn't work for you. However, I did verify that jsTIfied doesn't show anything in the "Transfer files from SourceCoder" section.
Yes, this is a known issue, and could be worked around if it was a priority.
Oh? Can you explain your reasoning? I see it goes from all white to all black as expected.
I do however note that the issue we've been discussing with a blank LCD after loading a ROM remains, also as expected.
I was able to reproduce the contrast bug after clearing my cookies. I was unable to reproduce this with the emulated 84+.
https://usercontent.irccloud-cdn.com/file/6Rtm4Iy0/Screen%20recording%202025-02-19%201.51.55%20PM.webm
Page 4 of 4
