It seems like Source Coder 3 doesn't detect all tokens of TI Connect CE: https://github.com/TIny-Hacker/language-ti-basic/files/14040053/TOKENS.8xp.zip
» Forum
> SourceCoder
Tari wrote:
TIny_Hacker wrote:
It seems that the "ExecLib " and "getDtStr(" tokens are not properly loaded when opening a program in SC3. Instead, they're loaded as "ExecLib" and "getDtStr".
Looks like this error is inherited from TokenIDE, but should be fixed now.Thanks for the quick fix! I'm also noticing this issue with "2-Var Stats " not having the trailing space at the end.
Edit: "stdDev(" also needs a "(" at the end, and "AxesOn " needs a space.
My 83+ ROM doesn't have a space after AxesOn so I haven't changed that, but updated the other two. Edit: "stdDev(" also needs a "(" at the end, and "AxesOn " needs a space.
My 83+ ROM doesn't have a space after AxesOn so I haven't changed that, but updated the other two.Edit: "stdDev(" also needs a "(" at the end, and "AxesOn " needs a space.
AxesOn didn't get a space until the CSE.
Maker of things. Co-founder of TI-Toolkit.
The reason is that AxesOn was the only pre-existing token in that category that got a new color argument for the CSE; GridOn splintered into GridLine and GridDot, and obviously you don't need an argument to turn anything off.
Tari, could you check this file please? https://github.com/TIny-Hacker/language-ti-basic/files/14040053/TOKENS.8xp.zip
TI Connect CE loads this just fine.
Error: Unable to load TOKENS.8xp. Are you sure it's a valid file type?
More Information: TOKENS: Detokenization process failed at ...0xef, 0x3f, ...Prevous context was: T] [CLASSIC] [n/d] [Un/d] [AUTO] [DEC] [FRAC] (backtrack was [239,63])
The error message says it doesn't know what the byte sequence EF 3F is, and I agree. Looks like that file walks through tokens ordered by byte value since the last one before that is [FRAC] which is EF 3D, but TI-Toolkit/tokens agrees that EF 3F doesn't exist.
Looks like TI Connect CE shows it as "STATWIZARD ON" (and then following that is "STATWIZARD OFF").
Edit:
I've added them to the tokens xml.
Well, all I know is that TI Connect CE has them:
- Mode: STATWIZARD ON" and "STATWIZARD OFF"
- Catalog: "SEQ(n)", "SEQ(n+1)" and "SEQ(n+2)"
- Math > Math: "piecewise(", Source Coder uses the token from v5.2.0-v5.3.0
Edit:
- https://github.com/TI-Toolkit/tokens/blob/dcf13fdd8af3afbaadd6096fa908f39f139c5560/8X.xml#L10003C3-L10041C11
- https://github.com/TI-Toolkit/tokens/blob/dcf13fdd8af3afbaadd6096fa908f39f139c5560/8X.xml#L10222C3-L10233C11
The "Í" character cannot be exported. It is also in the "default" tab, instead of the "accented characters" tab.
Repeated error on every file i try to load:
Error: Unable to load MINECE.8xp. Are you sure it's a valid file type?
More Information: MINECE: Detokenization process failed at ...0xef, 0x7b, ...Prevous context was: (backtrack was [239,123])
SourceCode3 cannot open compiled assembly programs. You will have to grab the source code itself.
On Google Chrome on Chrome OS, trying to import a ROM into jsTIfied from SourceCoder3 results in the skin changing appropriately, but it still complains about not having a ROM loaded. I can still export the JPEG-encoded ROM "image", but it returns to the same screen as before. If I now try this on the jsTIfied page itself, it suddenly starts behaving the same way. The only quick fix is clearing cookies.
» Goto page Previous 1, 2, 3 ... 30, 31, 32
Page 32 of 32
