I have two scripts on my Prime. When the first one is finished, it imports the second one and runs it. How do I stop it? Doesn't do this on my Casio TI Nspire, 48+ CE or Numworks.
impressive collection of calculators. It would be helpful to have more information about the problem (like screenshots), since the information is pretty vague.
Cone program. Calculates the sheet metal size for a rolled cone.
from math import *
import math
major = input("major dia=")
major = float(major)
#print(major)
minor = input("minor dia=")
minor = float(minor)
#print(minor)
height = input("height=")
height = float(height)
#print(height)
o = math.sqrt((height*major/(major-minor))**2+(major/2)**2)
i = math.sqrt((height*minor/(major-minor))**2+(minor/2)**2)
angle = 360*major/(2*o)
r_angle = angle*(pi/180)
if angle >180:
x = o+o*sin(((angle-180)*(pi/180))/2)
y = 2*o
else:
x = o-i*cos((angle/2*(pi/180)))
y = 2*o*sin((angle/2*(pi/180)))
print("radius 1 = {0:6.3f}".format(o))
print("radius 2 = {0:6.3f}".format(i))
print("angle = {0:6.2f}".format(angle))
print("b height = {0:6.3f}".format(x))
print("b width = {0:6.3f}".format(y))
if y>144:
print("blank oversized")
red.py is a list of the magic eight ball responses that comes up randomly when pressing enter.
from micropython import *
from urandom import *
from urandom import random
import random
eightlist = ["It is certain ",
"Reply hazy, try again",
"Don’t count on it",
"It is decidedly so",
"Ask again later",
"My reply is no",
"Without a doubt",
"Better not tell you now",
"My sources say no",
"Yes definitely",
"Cannot predict now",
"Outlook not so good",
"You may rely on it",
"Concentrate and ask again",
"Very doubtful",
"As I see it, yes",
"Most likely",
"Outlook good",
"Yes",
"Signs point to yes" ]
shake = ""
while True:
shake = input("Shake for answer ")
if shake == "":
print (random.choice(eightlist)
#print (eightlist[eightball])
else:
print ("Thanks for playing")
break
Cone runs then at the end, it displays <import> red.py and runs that program.
from math import *
import math
#print(major)
#print(minor)
#print(height)
if angle >180:
y = 2*o
else:
if y>144:
import random
"Ask again later",
"My reply is no",
"Without a doubt",
"Yes definitely",
"Very doubtful",
"As I see it, yes",
"Most likely",
"Outlook good",
"Yes",
shake = ""
while True:
if shake == "":
else:
break
The Prime calculator has a feature called "Autostart" that automatically executes a specific script when the calculator is turned on or reset. If the second script is set to automatically execute through this feature, you can disable it. To do this, go to the "Programs" menu, select the second script, press the "Shift" key, and then press the "Menu" key. Look for an option related to autostart or automatic execution and disable it. This should prevent the second script from running after the first one finishes.
Shift Plot calls up that menu. It has a blanket autorun check box that I switched off.
