So I recently started learning how to program hex assembly for the TI-84 plus CE and was wondering if there was a full list of Hex Syscalls for it.
right here
Do you have access to an assembler you can use, even if it's SourceCoder (https://www.cemetech.net/sc)? You can then use your favorite hex editor (like XVI32, or if you can't install things on your computer, https://hexed.it/) to view the hex and type it into your calculator, assuming you can't connect your calculator to your computer. You'll be throwing a lot of extra roadblocks in your way to try to program assembly by hand-assembling it: it doesn't make you any cooler or more impressive, if you're trying to do it for style.
If you really need the addresses of the bcalls(), c.f. https://github.com/CE-Programming/CEmu/blob/master/tests/ti84pce.inc .
