So when I try to open TiLP on my Windows 7 32-bit computer while using a Silverlink Graphlink cable to connect it to my TI-83+ graphing calculator, it won't work very well and I don't know why. There are 3 female USB ports on my laptop; the 2 on the right bring up this error:
Msg: failed to open the USB device.
Cause: Check that the USB cable is plugged in and that the calculator is turned ON! Also, check libusb and usbfs for valid permissions.
The one on the left doesn't bring up the error, but when it shows the display window for TiLP, most of the buttons ("Ready?", "Dirlist", "Backup", "Restore", "Receive" specifically) are grayed out. These happen regardless of whether the is turned on or not, and also regardless of whether they are connected or not.
I have also tried opening DoorsCS with it; it shows the above error followed by this one:
The cable cannot be used.
Cause: the cable has not been initialized due to a previous/current error.
when on the right two USB ports, also regardless of whether the is on or not. The left port is even weirder: no error, but it shows the TiLP program extremely briefly (<1 second) before stopping. I have been able to confirm that nothing happens after this.
The weird thing is that, when I try to use TI-CONNECT to do stuff, it works perfectly, but only when using the right two ports. But when I want to use those same ports, TiLP basically says "Welp, time to give up and do nothing! "
I have been experimenting with it all day because Notepad++ won't let me save files as .z80 files and I can't port them as the next-best thing, .asm files. If anyone has a solution for why DoorsCS and TiLP aren't working, or knows a good way to save files from Notepad++ into the .z80 file format, both things would be much appreciated!
Also, I am able to provide any info I may have left out, except screenshots. I don't know how to take screenshots on this device; apologies in advance!
