I have updated
https://www-fourier.univ-grenoble-alpes.fr/~parisse/tmp/epsilon.g3a. I have now working code to save/restore the scriptstore at startup/exit. This is done in the power off function in main.cpp and with a static bool in the home app code. I have removed the code to save/load with OFF. Additionnaly you can now save/load up to 9 calculator states from the home application with the sto key (the key above AC/ON) and the VARS key.
This is still experimental and I get crashes from time to time. If the addin crashes, delete the file nwstore.nws (auto-save) and nwstate1-9.nws.
New code for apps/home/controller.cpp
#include "controller.h"
#include "app.h"
#include <apps/home/apps_layout.h>
#include "../apps_container.h"
#include "../global_preferences.h"
#include "../exam_mode_configuration.h"
extern "C" {
#include <assert.h>
#ifdef _FXCG
#include "../../ion/src/simulator/fxcg/platform.h"
#include <gint/bfile.h>
#include <gint/display-cg.h>
#include <gint/gint.h>
#include <gint/display.h>
#include <gint/keyboard.h>
#include <stddef.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <vector>
#include <ion.h>
#include <ion/events.h>
void * storage_address(); // ion/src/simulator/shared/platform_info.cpp
static const int storage_length=8192; // 60000 in Upsilon, 32768 in Epsilon
// k_storageSize = 60000; in ion/include/ion/internal_storage.h
static const char * storage_name="nwstore.nws";
static int load_state(const char * fname){
FILE * f=fopen(fname,"rb");
if (f){
fread(storage_address(),1,storage_length,f);
fclose(f);
return 1;
return 0;
static void convert(const char * fname,unsigned short * pFile){
for ( ;*fname;++fname,++pFile)
*pFile=*fname;
*pFile=0;
static int save_state(const char * fname){
if (Ion::Storage::sharedStorage()->numberOfRecords()){
#if 0
unsigned short pFile[512];
convert(fname,pFile);
int hf = BFile_Open(pFile, BFile_WriteOnly); // Get handle
// cout << hf << endl << "f:" << filename << endl; Console_Disp();
if (hf<0){
int l=storage_length;
BFile_Create(pFile,0,&l);
if (hf < 0)
return 0;
int l=BFile_Write(hf,storage_address(),storage_length);
BFile_Close(hf);
if (l==storage_length)
return 1;
return -1;
#else
const char * ptr=(const char *)storage_address();
// find store size
int S=4;
for (ptr+=4;;){
size_t L=ptr[1]*256+ptr[0];
ptr+=L;
S+=L;
if (L==0) break;
S = ((S+1023)/1024)*1024;
FILE * f=fopen(fname,"wb");
if (f){
fwrite(storage_address(),1,S,f);
fclose(f);
return S;
return 0;
#endif
return 2;
#endif
#ifdef HOME_DISPLAY_EXTERNALS
#include "../external/external_icon.h"
#include "../external/archive.h"
#include <string.h>
#endif
namespace Home {
Controller::ContentView::ContentView(Controller * controller, SelectableTableViewDataSource * selectionDataSource) :
m_selectableTableView(controller, controller, &m_backgroundView, selectionDataSource, controller),
m_backgroundView()
m_selectableTableView.setVerticalCellOverlap(0);
m_selectableTableView.setMargins(0, k_sideMargin, k_bottomMargin, k_sideMargin);
static_cast<ScrollView::BarDecorator *>(m_selectableTableView.decorator())->verticalBar()->setMargin(k_indicatorMargin);
SelectableTableView * Controller::ContentView::selectableTableView() {
return &m_selectableTableView;
void Controller::ContentView::drawRect(KDContext * ctx, KDRect rect) const {
m_selectableTableView.drawRect(ctx, rect);
void Controller::ContentView::reloadBottomRow(SimpleTableViewDataSource * dataSource, int numberOfIcons, int numberOfColumns) {
if (numberOfIcons % numberOfColumns) {
/* We mark the missing icons on the last row as dirty. */
for (int i = 0; i < numberOfColumns; i++) {
if (i >= numberOfIcons % numberOfColumns) {
markRectAsDirty(KDRect(dataSource->cellWidth()*i, dataSource->cellHeight(), dataSource->cellWidth(), dataSource->cellHeight()));
BackgroundView * Controller::ContentView::backgroundView() {
return &m_backgroundView;
int Controller::ContentView::numberOfSubviews() const {
return 1;
View * Controller::ContentView::subviewAtIndex(int index) {
assert(index == 0);
void Controller::ContentView::layoutSubviews(bool force) {
m_selectableTableView.setFrame(bounds(), force);
m_backgroundView.setFrame(KDRect(0, Metric::TitleBarHeight, Ion::Display::Width, Ion::Display::Height-Metric::TitleBarHeight), force);
m_backgroundView.updateDataValidity();
Controller::Controller(Responder * parentResponder, SelectableTableViewDataSource * selectionDataSource, ::App * app) :
ViewController(parentResponder),
m_view(this, selectionDataSource)
m_app = app;
for (int i = 0; i < k_maxNumberOfCells; i++) {
m_cells[i].setBackgroundView(m_view.backgroundView());
m_view.backgroundView()->setDefaultColor(Palette::HomeBackground);
int index = External::Archive::indexFromName("wallpaper.obm");
if(index > -1) {
External::Archive::File image;
External::Archive::fileAtIndex(index, image);
m_view.backgroundView()->setBackgroundImage(image.data);
#endif
static constexpr Ion::Events::Event home_fast_navigation_events[] = {
Ion::Events::Seven, Ion::Events::Eight, Ion::Events::Nine,
Ion::Events::Four, Ion::Events::Five, Ion::Events::Six,
Ion::Events::One, Ion::Events::Two, Ion::Events::Three,
Ion::Events::Zero, Ion::Events::Dot, Ion::Events::EE
bool Controller::handleEvent(Ion::Events::Event event) {
#ifdef _FXCG
static bool firstrun=true;
if (firstrun){
gint_world_switch(GINT_CALL(load_state,storage_name));
firstrun=false;
if (Ion::Storage::sharedStorage()->numberOfRecords() && event == Ion::Events::Sto){
dclear(C_WHITE);
dtext(1,1, C_BLACK, "Key 1 to 9: save state");
dtext(1,17,C_BLACK,"to file nwstate1 to 9");
dtext(1,33,C_BLACK,"Press any other key to cancel");
dupdate();
#if 0
int opt=GETKEY_DEFAULT,timeout=3; key_event_t ev=getkey_opt(opt,&timeout);
#else
key_event_t ev=getkey();
#endif
int key=ev.key;
char buf[]="nwstate0.nws";
if (key>=KEY_1 && key<=KEY_9){
buf[7]='1'+(key-KEY_1);
dclear(C_WHITE);
dtext(1,1, C_BLACK, "Saving");
dtext(1,17,C_BLACK,buf);
dupdate();
int l=gint_world_switch(GINT_CALL(save_state,buf));
char buf2[]="00000";
for (int pos=0;l;l/=10,++pos){
buf2[sizeof(buf2)-1-pos] += l % 10;
dtext(1,33,C_BLACK,"Length");
dtext(1,49,C_BLACK,buf2);
dtext(1,65,C_BLACK,"Press any key");
dupdate();
getkey();
((App*)m_app)->redraw();
if (event == Ion::Events::Var) {
dclear(C_WHITE);
dtext(1,1, C_BLACK, "Key 1 to 9: load state");
dtext(1,17,C_BLACK,"from file nwstate1 to 9");
dtext(1,33,C_BLACK,"Current context will be lost!");
dtext(1,49,C_BLACK,"Press any other key to cancel");
dupdate();
#if 0
#else
#endif
int key=ev.key;
dclear(C_WHITE);
dtext(1,1, C_BLACK, "Loading");
dupdate();
int l=gint_world_switch(GINT_CALL(load_state,buf));
char buf2[]="0";
buf2[0] += l;
if (l==0)
dtext(1,33,C_BLACK,"Error reading state");
if (l==1)
dtext(1,33,C_BLACK,"Success reading state");
dupdate();
getkey();
#endif // _FXCG
if (event == Ion::Events::OK || event == Ion::Events::EXE) {
AppsContainer * container = AppsContainer::sharedAppsContainer();
int index = selectionDataSource()->selectedRow()*k_numberOfColumns+selectionDataSource()->selectedColumn()+1;
if (index >= container->numberOfApps()) {
if (GlobalPreferences::sharedGlobalPreferences()->examMode() == GlobalPreferences::ExamMode::Dutch || GlobalPreferences::sharedGlobalPreferences()->examMode() == GlobalPreferences::ExamMode::NoSymNoText || GlobalPreferences::sharedGlobalPreferences()->examMode() == GlobalPreferences::ExamMode::NoSym) {
App::app()->displayWarning(I18n::Message::ForbiddenAppInExamMode1, I18n::Message::ForbiddenAppInExamMode2);
} else {
External::Archive::File executable;
if (External::Archive::executableAtIndex(index - container->numberOfApps(), executable)) {
uint32_t res = External::Archive::executeFile(executable.name, ((App *)m_app)->heap(), ((App *)m_app)->heapSize());
switch(res) {
case 0:
break;
case 1:
Container::activeApp()->displayWarning(I18n::Message::ExternalAppApiMismatch);
break;
case 2:
Container::activeApp()->displayWarning(I18n::Message::StorageMemoryFull1);
break;
default:
Container::activeApp()->displayWarning(I18n::Message::ExternalAppExecError);
break;
return true;
} else {
#endif
::App::Snapshot * selectedSnapshot = container->appSnapshotAtIndex(index);
if (ExamModeConfiguration::appIsForbiddenInExamMode(selectedSnapshot->descriptor()->examinationLevel(), GlobalPreferences::sharedGlobalPreferences()->examMode())) {
} else {
bool switched = container->switchTo(selectedSnapshot);
assert(switched);
(void) switched; // Silence compilation warning about unused variable.
#endif
return true;
if (event == Ion::Events::Home || event == Ion::Events::Back) {
return m_view.selectableTableView()->selectCellAtLocation(0, 0);
if (event == Ion::Events::Right && selectionDataSource()->selectedRow() < numberOfRows() - 1) {
return m_view.selectableTableView()->selectCellAtLocation(0, selectionDataSource()->selectedRow() + 1);
if (event == Ion::Events::Left && selectionDataSource()->selectedRow() > 0) {
return m_view.selectableTableView()->selectCellAtLocation(numberOfColumns() - 1, selectionDataSource()->selectedRow() - 1);
// Handle fast home navigation
for(int i = 0; i < std::min((int) (sizeof(home_fast_navigation_events) / sizeof(Ion::Events::Event)), this->numberOfIcons()); i++) {
if (event == home_fast_navigation_events[i]) {
int row = i / k_numberOfColumns;
int column = i % k_numberOfColumns;
// Get if app is already selected
if (selectionDataSource()->selectedRow() == row && selectionDataSource()->selectedColumn() == column) {
// If app is already selected, launch it
return handleEvent(Ion::Events::OK);
// Else, select the app
return m_view.selectableTableView()->selectCellAtLocation(column, row);
return false;
void Controller::didBecomeFirstResponder() {
if (selectionDataSource()->selectedRow() == -1) {
selectionDataSource()->selectCellAtLocation(0, 0);
Container::activeApp()->setFirstResponder(m_view.selectableTableView());
void Controller::viewWillAppear() {
KDIonContext::sharedContext()->zoomInhibit = true;
KDIonContext::sharedContext()->updatePostProcessingEffects();
void Controller::viewDidDisappear() {
KDIonContext::sharedContext()->zoomInhibit = false;
View * Controller::view() {
return &m_view;
int Controller::numberOfRows() const {
return ((numberOfIcons() - 1) / k_numberOfColumns) + 1;
int Controller::numberOfColumns() const {
return k_numberOfColumns;
KDCoordinate Controller::cellHeight() {
return k_cellHeight;
KDCoordinate Controller::cellWidth() {
return k_cellWidth;
HighlightCell * Controller::reusableCell(int index) {
return &m_cells[index];
int Controller::reusableCellCount() const {
return k_maxNumberOfCells;
void Controller::willDisplayCellAtLocation(HighlightCell * cell, int i, int j) {
AppCell * appCell = (AppCell *)cell;
int appIndex = (j * k_numberOfColumns + i) + 1;
if (appIndex >= container->numberOfApps()) {
External::Archive::File app_file;
if (External::Archive::executableAtIndex(appIndex - container->numberOfApps(), app_file)) {
char temp_name_buffer[100];
strlcpy(temp_name_buffer, app_file.name, 94);
strlcat(temp_name_buffer, ".icon", 99);
int img_index = External::Archive::indexFromName(temp_name_buffer);
if (img_index != -1) {
External::Archive::File image_file;
if (External::Archive::fileAtIndex(img_index, image_file)) {
// const Image* img = new Image(55, 56, image_file.data, image_file.dataLength);
appCell->setExtAppDescriptor(app_file.name, image_file.data, image_file.dataLength);
} else {
appCell->setExtAppDescriptor(app_file.name, ImageStore::ExternalIcon);
} else {
appCell->setVisible(true);
} else {
appCell->setVisible(false);
#else
#endif
} else {
::App::Descriptor * descriptor = container->appSnapshotAtIndex(PermutedAppSnapshotIndex(appIndex))->descriptor();
appCell->setAppDescriptor(descriptor);
int Controller::numberOfIcons() const {
assert(container->numberOfApps() > 0);
return container->numberOfApps() - 1 + External::Archive::numberOfExecutables();
#else
return container->numberOfApps() - 1;
#endif
void Controller::tableViewDidChangeSelection(SelectableTableView * t, int previousSelectedCellX, int previousSelectedCellY, bool withinTemporarySelection) {
if (withinTemporarySelection) {
return;
/* To prevent the selectable table view to select cells that are unvisible,
* we reselect the previous selected cell as soon as the selected cell is
* unvisible. This trick does not create an endless loop as we ensure not to
* stay on a unvisible cell and to initialize the first cell on a visible one
* (so the previous one is always visible). */
int appIndex = (t->selectedColumn()+t->selectedRow()*k_numberOfColumns)+1;
if (appIndex >= this->numberOfIcons()+1) {
t->selectCellAtLocation((this->numberOfIcons()%k_numberOfColumns)-1, (this->numberOfIcons() / k_numberOfColumns));
void Controller::tableViewDidChangeSelectionAndDidScroll(SelectableTableView * t, int previousSelectedCellX, int previousSelectedCellY, bool withinTemporarySelection) {
/* If the number of apps (including home) is != 3*n+1, when we display the
* lowest icons, the other(s) are empty. As no icon is thus redrawn on the
* previous ones, the cell is not cleaned. We need to redraw a white rect on
* the cells to hide the leftover icons. Ideally, we would have redrawn all
* the background in white and then redraw visible cells. However, the
* redrawing takes time and is visible at scrolling. Here, we avoid the
* background complete redrawing but the code is a bit
* clumsy. */
if (t->selectedRow() == numberOfRows()-1) {
m_view.reloadBottomRow(this, this->numberOfIcons(), k_numberOfColumns);
SelectableTableViewDataSource * Controller::selectionDataSource() const {
return App::app()->snapshot();
New code for ion/src/simulator/fxcg/main.cpp
#include "main.h"
#include "display.h"
#include "platform.h"
#include <stddef.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <vector>
#include <ion.h>
if (f){
fclose(f);
return 1;
return 0;
if (1 || Ion::Storage::sharedStorage()->numberOfRecords()){
// find store size
int S=4;
for (ptr+=4;;){
ptr+=L;
S+=L;
if (L==0) break;
if (f){
fclose(f);
return S;
return 0;
return 2;
extern "C" {
int main() {
Ion::Simulator::Main::init();
ion_main(0, NULL);
Ion::Simulator::Main::quit();
return 0;
namespace Ion {
namespace Simulator {
namespace Main {
static bool sNeedsRefresh = false;
void init() {
Ion::Simulator::Display::init();
setNeedsRefresh();
void setNeedsRefresh() {
sNeedsRefresh = true;
void refresh() {
if (!sNeedsRefresh) {
return;
Display::draw();
void quit() {
Ion::Simulator::Display::quit();
void EnableStatusArea(int opt) {
__asm__ __volatile__ (
".align 2 \n\t"
"mov.l 2f, r2 \n\t"
"mov.l 1f, r0 \n\t"
"jmp @r2 \n\t"
"nop \n\t"
".align 2 \n\t"
"1: \n\t"
".long 0x02B7 \n\t"
".align 4 \n\t"
"2: \n\t"
".long 0x80020070 \n\t"
extern "C" void *__GetVRAMAddress(void);
uint8_t xyram_backup[16 * 1024];
uint8_t ilram_backup[4 * 1024];
void worldSwitchHandler(void (*worldSwitchFunction)(), bool prepareVRAM) {
// Back up XYRAM
uint8_t* xyram = (uint8_t*) 0xe500e000;
memcpy(xyram_backup, xyram, 16 * 1024);
// Back up ILRAM
uint8_t* ilram = (uint8_t*) 0xe5200000;
memcpy(ilram_backup, ilram, 4 * 1024);
if (prepareVRAM) {
// Copying the screen to the OS's VRAM avoids a flicker when powering on
uint16_t* dst = (uint16_t *) __GetVRAMAddress();
uint16_t* src = gint_vram + 6;
for (int y = 0; y < 216; y++, dst += 384, src += 396) {
for (int x = 0; x < 384; x++) {
dst[x] = src[x];
// Disable the status area
EnableStatusArea(3);
worldSwitchFunction();
// Restore XYRAM
memcpy(xyram, xyram_backup, 16 * 1024);
// Restore ILRAM
memcpy(ilram, ilram_backup, 4 * 1024);
void runPowerOffSafe(void (*powerOffSafeFunction)(), bool prepareVRAM) {
gint_world_switch(GINT_CALL(save_state,storage_name));
gint_world_switch(GINT_CALL(worldSwitchHandler, powerOffSafeFunction, prepareVRAM));
