Its simple really, whenever I create a rectangle using Bdisp_Rectangle(0, 0, 10, 10, TEXT_COLOR_RED) it creates a rectangle like it says it does, however it is an empty/hollow rectangle. Does anyone know of a way to apply a fill to it and make it a solid rectangle? Thanks
OMG, thanks so much, how did u come across this function I didn't see it inside the document. Is there another document that is more comprehensive. Thanks
MateoConLechuga wrote:
I believe you can use the function Bdisp_FilledRectangle instead.
Hey, thanks for the reply but do you know how to change the position of the rectangle, because I am planning to make a game but I need the rectangle to move when a button is clicked and when I put the rectangle function in the while loop it just doesn't render, thanks
Well the header has all of them, presumably: https://github.com/Jonimoose/libfxcg/blob/master/include/fxcg/display.h
Thanks a lot this seems very helpful
I'm not entirely sure what you mean, but Bdisp_Rectangle and Bdisp_FiledRectangle both draw to the VRAM, which means that you have to call Bdisp_PutDisp_DD(), or GetKey() which calls Bdisp_PutDisp_DD() to draw the VRAM to the screen.
Hey, dr-carlos after a lot of digging and investigation I have worked it out.
For anyone who wants to draw a rectangle to the screen and move it around do this:
First you need to call
- to get information on the parameters have a look here https://prizm.cemetech.net/index.php?title=Category:Syscalls
Next you need to detect keypresses, I used
to get the input from keyboard and have a variable that changes based on whether the right key is pressed or left
Next inside the infinite loop you need to clear the VRAM (basically the screen) using
and then use the function
to draw the rectangle again, finally you need to push the VRAM to the screen through
and that's it.
Thanks a lot to everyone who helped me
Bdisp_FilledRectangle(x, y, x2, y2, TEXT_COLOR_BLACK);
GetKeyWait_OS
Bdisp_AllClr_VRAM()
Bdisp_FilledRectangle()
Bdisp_PutDisp_DD()
Hey, thanks a lot for your contribution but I have another question, whenever I have an error it just says "Aborted, press [menu] to exit" yet there is nothing about the error, do you know where I can find the logs or error report?
Not really, the calculator isn't good with errors.
What were you running before the error occured?
and that's it.
GetKeyWait_OS
Bdisp_AllClr_VRAM()
Bdisp_PutDisp_DD()
Yep, that should all work. Note that Bdisp_AllClr_VRAM() isn't very fast, so if you want better performance, consider drawing a white Bdisp_FilledRectangle where the previous one was, or read this wiki article (the Optimization section) on how to do this even faster.
Thanks dr-carlos here is the line that is causing the error:
unsigned int *hour, *minute, *second, *millisecond;
RTC_GetTime(&hour, &minute, &second, &millisecond);
When I remove the bottom line the code runs fine, is there a problem with how I am using the function.
Just so you know this is a short snippet of my entire code
Get rid of the *
Yes, Mateo is right. You have created pointers and then passed in references to those pointers.
Now you are passing in int** types, instead of int* types which the function is expecting. This will also not work because your pointers are uninitialised. This means that hour, minute, second, and millisecond are effectively null pointers and this may crash RTC_GetTime.
Instead, use:
unsigned int hour, minute, second, millisecond;
I am trying to learn C, and so here is what I understand. I am currently giving the address of a pointer which points to nothing (NULL) as I haven't told them what address to point to.
So if I understand correctly:
So what I am passing into the function is an pointer, well a parameter storing an address and that parameter points to a pointer which address stored points to NULL
Are all of my intuition correct?
int var = 0, *i = &var;
&I // This is the address of the pointer
So is the code I described below correct, as I presume what is being passed into func is actually the address of a pointer which points to 0
int func(int** i){
printf("%d", *(*i)); // Is this correct??
int main() {
func(&i);
return 0;
Thanks a lot
int func(int** i){
int main() {
func(&i);
return 0;
Thanks a lot
int func(int** i){
int main() {
func(&i);
return 0;
Thanks a lot
int func(int** i){
int main() {
func(&i);
return 0;
Thanks a lot
Yes, this would print 0.
However, in the case of RTC_GetTime, it expects unsigned int* arguments. See the code I posted previously for how this should be done.
I used your code and it works fine dr-carlos, but could you tell me how accurate is the millisecond value returned, I think I saw it somewhere and it was around 1/128th of a second for every update of that value. The reason why is because I want to know how to run a piece of code x times every second. Thanks
The base tick of the Real-Time Clock is 1/128th of a second.
Therefore, the millisecond provided is accurate to 1/128th of a second.
There are approximately 7 milliseconds per 1/128th of a second.
Another way of doing this would be to use RTC_GetTicks(), which returns the number of ticks (1/128ths of second) since midnight.
Thanks now this is completely unrelated but when specifying the color in PromtXY, is there a way to use an rgb color? Thanks
Not in PrintXY, but there is another function, PrintCXY, which does what you are looking for.
See its wiki article for details.
Note that PrintCXY uses pixels instead of columns and rows. These can be converted as follows:
x = (Row - 1) * 18
y = (Column - 1) * 24
Also note that the PrintCXY message string does not require two spaces at the start.
» Goto page 1, 2 Next
