Yep, I did it the afternoon I posted that! My calculator randomly crashed about five minutes after, while I was still walking around, and now ram resets whenever it doesn't get used for 24hrs or so, but I don't know if that is the program's fault, or a faulty battery. If I make an HD version, should I post it?
That is weird, have you tried doing a full memory reset to see if it still plays up after that? Nothing like this has been reported previously and I haven't had the issue myself (having played through the game dozens of times during testing).
If you mod the game and decide to release it that's fine, as long as you credit the original
That was my fault. I realized that some of the wires in the cord had been ripped out, so if the calculator was plugged in, it would turn on and then use just a little bit more battery than it was receiving from the charger. I got out another cord and it's working just fine.
On a side note, I was messing around with Hexaedit on the Bancgfx appvar, and ended up breaking it so it looks really weird. Each tile now is half another tile, like the offsets of the sprites in the tilemaps are broken. I only changed like eight bytes, and I didn't add any null characters. Do you have the format for how the appvar stores everything?
I'm on a trip right now, and I didn't bring my CE, so I can't try anything out or elaborate until like Wednesday.
Yeah you won't be able to just rip or edit the graphics data straight out of the appvar as they're Huffman compressed. You'd need to change the .png files (located in the source/gfx folder) and then recompile.
In the source\design folder there is a spreadsheet called "banchor design.xlsx" that has a bunch of info about file formats, memory layout during execution, world layout, tile definitions, etc.
JamesV wrote:
xMarminq_ wrote:
Where are the winged boots?
I'll send you a PM
I ended up putting together a full walkthrough (including maps), which you can grab from here:
http://ceme.tech/DL2131
In short though:
The Winged Boots are in a pyramid in the south-west corner of Hell. You'll need to navigate around the lava rivers to get to the pyramid. Inside there is a false wall, and in the next room you can purchase the Winged Boots for 40,000 gold.
In short though:
Michael2_3B wrote:
I finally finished the game! Had to grind (kill monsters) for several minutes to get enough gold for things... Got the winged boots, got the 5 crystals, and beat Banchor!
I have to say, though, Anazar was much much harder than Banchor was.
We’re did you find the winged boots, I travel the whole map for 3hours now and I can’t find it 🥲🥲
JamesV wrote:
In short though:
I uploaded a small patch of this last night, just a bug fix with one of the enemies not displaying properly, and a tile fixed on one of the map edges that wasn't aligning with the adjoining map..
Banchor: Legend of the Hellspawn v2.0.1
Walkthrough v2.0.1
Walkthrough v2.0.1
dodope56 wrote:
how do i sword
Once you find the sword, press [2nd]. But I'm guessing you haven't found the sword yet.. It's in the Castle Dungeon area, so if you've found your way out through the secret passage, go back in
Mcdonalds_lover_32 wrote:
I have a question so I got the shield in the castle or wherever and how do I use it? Thanks
You don’t need to actively use it, but when certain enemies shoot at you, you will automatically deflect
Ok that makes sense so just like legends of Zelda on NES
Bonjour
Ou sont les bottes ailées s'il vous plait ?
J'ai beaucoup cherché sans succès
Merci d'avance
Merci d'avance
IgorSympa wrote:
Bonjour
Merci d'avance
Merci d'avance
In short though:
In short though:
Do you know how many times you have to hit each boss with your sword to kill it? One idea for a future update would be to display a boss life level bar.
Also, holding down the attack key doesn't work (the sword disappears without attacking more powerfully)
In any case, I've already completed the game once and I think it's excellent.
Thanks Michael for answering the last question
There's no short answer to the boss health vs number of attacks, but:
- There are 3 swords in the game (Blunt, Superior, Legendary), each more powerful than the previous
- The boss health bar is a good idea - if/when I do any future small improvements, I'll add this in!
- Holding down attack to hold your sword out for longer does improve your attack (it damages the boss for every frame that the sword is extended and clipping the boss), but yes you need to manually release and attack again
- So, the ideal attack pattern is to get used to the timing of the longer attacks and repeating
Hope that helps!
Hope that helps!
» Goto page Previous 1, 2, 3, 4, 5, 6, 7 Next
Page 6 of 7
