Ok so my ti 84 plus CE likes to just randomly clear its ram , regardless of what I'm doing. Should I try to fix it , or am I better off buying a new one. I have already tried completely resetting it, and reinstalling the OS , and it still does it. Anybody have any ideas? Or know where I could get a cheap replacement
cheap CE's will be hard to come by. Good luck finding a replacement that is less than $100.
I don't know how you could fix this. Maybe if could describe what caused the problem, or identify what you were doing before the problem occurred, or if it has always happened.
What version is your TI-84 Plus CE? The latest update could be responsible for clearing the RAM randomly, or you could have an outdated version, which can be solved with updating via TI-CONNECT CE.
You can check the version by pressing 2nd, +, then 1.
it happened after i updated to OS 5.1.5 . is has always happened after the update, and there is no way to downgrade. i have a warranty from Walmart, but im not sure whether it covers this or not.
Hmm, right now I am thinking, maybe you should dump your ROM, run a checksum on it, and compare it against that of somebody who also owns a CE (assuming the same OS version).
I cannot imagine Walmart or at least Texas Instruments not honouring warranty for such a new device.
i would dump the ROM with tilp? Im not entirely sure how to do that i think its covered under warranty though, because i looked at the receipt an it says 2 -year warranty, and its not even 1 year old.
I did, i removed the battery and checked it after i put it back it. I dont think the battery was the problem, but hey you never know.
I know I'm two days late to this conversation but....TI replaces all calculators within one year of purchase unless the unit has physical damage. They don't repair any calculators. The "2" year warranty from Walmart or SquareTrade is a joke because they will refer you to TI during that first year.
Yes you are correct, that's exactly what they did . don't worry a out being late .
