Hello all,
This is my first time posting on this forum. I have been having a peculiar problem on my TI-84 Plus CE regarding C++ programs. I am trying to create simple 3D graphics for a game I am working on, but the calculator is crashing when I attempt to run the program The code compiles without errors or warnings on the latest CE Toolchain.
My code is below:
main.cpp:
The calculator crashes when I run this program through Asmhook or Cesium. The line from (0, 0) to (100, 200) is drawn correctly, but the lines that I am trying to draw are not working. After I trigger GetCSC() to exit the program, the calculator goes entirely blank for about five seconds and then reboots, showing the "Validating OS" message. I have verified the line positions, and they are all within the screen's boundaries. I have also compiled all the non-graphical parts of the code on GCC, and they work as intended. Does anyone know why this may be happening?
Thank you,
srupuduflupudu
My code is below:
main.cpp:
//#include <iostream>
#include <tice.h>
#include <graphx.h>
struct point2
int x;
int y;
struct point3
int x;
int y;
float z;
typedef point2 point2;
typedef point3 point3;
point2 p2from3(point3 p3_1);
class face3
public:
point3 p3_1;
point3 p3_2;
point3 p3_3;
point3 p3_4;
point2 p2_1 = p2from3(p3_1);
point2 p2_2 = p2from3(p3_2); // converting 3D points to 2D screen positions
point2 p2_3 = p2from3(p3_3);
point2 p2_4 = p2from3(p3_4);
void draw()
// gfx_FillTriangle(p2_1.x, p2_1.y, p2_2.x, p2_2.y, p2_3.x, p2_3.y); // 2 triangle generation
// gfx_FillTriangle(p2_2.x, p2_2.y, p2_3.x, p2_3.y, p2_4.x, p2_4.y);
gfx_Line(p2_1.x, p2_1.y, p2_2.x, p2_2.y); // drawing lines in the shape of the face outline
gfx_Line(p2_2.x, p2_2.y, p2_3.x, p2_3.y);
gfx_Line(p2_3.x, p2_3.y, p2_4.x, p2_4.y);
gfx_Line(p2_1.x, p2_1.y, p2_4.x, p2_4.y);
int main()
gfx_Begin();
face3 plate;
plate.p3_1.x = 50;
plate.p3_1.y = 100;
plate.p3_1.z = 2;
plate.p3_2.x = 120;
plate.p3_2.y = 100;
plate.p3_2.z = 2;
plate.p3_3.x = 120; // setting position and dimensions of the face "plate"
plate.p3_3.y = 120;
plate.p3_3.z = 1;
plate.p3_4.x = 100;
plate.p3_4.y = 120;
plate.p3_4.z = 1;
plate.draw();
gfx_Line(0, 0, 100, 200); // this line is drawn correctly, interestingly
while (!os_GetCSC())
gfx_End();
return 0;
point2 p2_1;
p2_1.x = ((p3_1.x - 160) / p3_1.z) + 160;
p2_1.y = ((p3_1.x - 120) / p3_1.z) + 120;
return p2_1;
Thank you,
srupuduflupudu
