How do you display sprites from appvars in ice
I have 5 sprites in a appvar and I need to display them.
I haven't used ICE in a while, but I believe you would do something like this:
sum(1,"appvar name","r")→SPRTVAR              // Opens the appvar slot for reading
sum(5,SPRITEA,1,/*(width*height)+2*/,SPRTVAR) // Reads the first sprite into SPRITEA
sum(5,SPRITEB,1,/*(width*height)+2*/,SPRTVAR) // Reads the second sprite into SPRITEB
sum(5,SPRITEC,1,/*(width*height)+2*/,SPRTVAR) // Etc.
sum(5,SPRITED,1,/*(width*height)+2*/,SPRTVAR)
sum(5,SPRITEE,1,/*(width*height)+2*/,SPRTVAR)
sum(3,SPRTVAR)                                // Closes the appvar slot
Then you would just treat those 5 variables as regular sprites
That works. I’ve done that before. If you want to read them at different times, you can copy the pointers into an array and use that.
thank you so much! Very Happy i have been playing around with that but could not find a solution.
Edit: It didnt work for me. here is what i did.
sum(0
det(0
sum(1,"CLASHLOG","r")->SLOT
sum(5,ºMAINPLAY,1,6582,SLOT
det(62,MAINPLAY,0,0,3,3
Pause
det(1
sum(0
You might also want to review the html documents attached in the zip file for ICE, they contain all sorts of useful and helpful information. I like to keep printed out copies of them handy.
sum(0
det(0
Pause
det(1
sum(0
Fixed it!
sum(0
det(0
det(62,°MAINPLAY,0,0,3,3
Pause
det(1
sum(0
