In 2007, I and several friends dreamed up PartyMode, a sound and lighting/visualization system created with top-of-the-line mid-2000s technology. About 22 speakers were strewn around a lab, a VU meter made of LED-illuminated case fans was controlled by a parallel port and mounted in the center of the room, and some simple software allowed the CRT monitors of every computer in the lab to be taken over as music visualizers. Unfortunately, the building in which this system was built was eventually torn down, and to my unending frustration, I took few photos and even fewer videos of the system. In the mid 2010s, I recreated a miniature version of this system as PartyMode 2.0 in my bedroom, retaining the LED case fan VU meter, but adding a quartet of bright RGB LED elements around the room in place of the monitors as music visualizers, and using the 5.1 speakers of a single sound system. Now, I've moved to a new place, and it's time to think about the next version of the system.
Perhaps unsurprisingly, I'm no longer interested in custom-designing constant-current sources for a few high-power LEDs. Instead, I'm using 60-LED-per-meter WS2812B LED strips, which will be run around the top perimeter of my room (as well as inside shelves and above my desk) and will allow me to replicate many of the original PartyMode 2.0 modes, including music-reactive, low-level nighttime illumination, and the always-popular Candlelight Mode. Controlling these is easy and well-documented, but powering them is a little more complicated. I want to power what in the end is likely to be at least 70 feet (21.3 meters) of LED strip, or 1280 LEDs, which at full brightness is up to 60mA per LED = 77A. I'll need a fair bit of power if I want to run everything at full brightness at the same time (which, admittedly, is unlikely).
The purported 15A 5V power supplies on Amazon come with extremely poor reviews, so of course my thoughts jump to that power supply jack-of-all-trades, reusing ATX PC power supplies. I've done my homework, and discovered two interesting facts:
Other than the 12V rail load requirement, a few of the good options I've discovered include the Zalman ZM400B-APS (for example, this one on eBay (5V @ 40A), assorted Logisys supplies (like this one, 5V @ 36A but with a minimum 1A draw on both the +5V and +12V rails), the ThermalTake PurePower 480AD (like this one or this one, 5V @ 40A), or the Antec True330 like this one, 5V @ 30A but an 800mA minimum 12V load.
Any thoughts, either from general electrical engineering expertise or experience with this type of project?
- Older power supplies tend to have more 5V current available relative to their overall rating, which is what I need.
- Most of these switching-mode ATX power supplies have a minimum 12V load required to regulate the 5V rail properly, which is not what I need
