#include <tice.h>
int main(void)
    os_ClrHome();
    uint8_t i;
    for (uint8_t i=0; i<100; i++){
        os_PutStrFull("Hello\n");
    while(!os_GetCSC());
    return 0;
Why doesn't this code properly make? It gives many syntax errors. Is there anyway to program in C++ instead of C? And what version of C does the SDK use?
C89: https://github.com/CE-Programming/toolchain/wiki/FAQ#syntax-error-identifier-var-not-defined-within-current-scope
The toolchain will be released with llvm support soon which removes these limitations.
feverdreme wrote:
#include <tice.h>
int main(void)
    os_ClrHome();
    uint8_t i;
    return 0;
The default version of the CE toolchain is the ZDS one, with a compiler by Zilog, that follows the C89 standard. One thing that isn't allowed in C89 for example is defining new variables not at the start of a block, so that uint8_t i; in your case. You can resolve this by moving its definition one line higher, and also remove the uint8_t from the for loop:
#include <tice.h>
int main(void)
    uint8_t i;
    os_ClrHome();
    for (i=0; i<100; i++){
    return 0;
However, there is a community-developed alternative LLVM-powered toolchain in development which works decently well already and will hopefully be released soon (and also supports C++, for example). It is already usable though. Like Mateo says,
...however it's been "soon" for several months now. You'd be best off using the prerelease and helping its development by looking for bugs too. github
